bene
28 Grudnia 2015
Możesz tłumaczyć a do dubla nr. 1 i tak nic nie dociera :zaciesz
You can activate PrivaZer after a promotion, provided you have received the necessary activation key or license code for the promotion. After purchasing or obtaining the promotion, follow the instructions given by the promotion (typically, they will provide you with a key or activation code). You can then enter this key within the PrivaZer application to activate it.
If you are unsure of the process or did not receive an activation key, I recommend checking the promotion's details or contacting PrivaZer's support team for assistance.
Tak oczywiście ale na wersję softu z promocji ale nie dożywotnią aktualizację
