Działa Wam w tym Firefox ?
Some versions of the browser Firefox are not working correctly inside of the platform. We recommend you to choose a different version or another browser. It is also desirable to close the application before the opening inside of the platform.
Programs on top left are NOT there like in the picture on the web page because that corner is filled with programs for quick launch. You can assign these buttons to applications that frequently use yourself.
Notepad needs for testing protection against spyware before the registration of the program. You can assign this button any other application.
The program works with Firefox . However, with some versions there is a problem. Its not our fault. Program compatibility is a global problem. We know many cases when large companies have application compatibility problems. This is a common situation in the market of software development.
dinosaur07
29 Marzec 2016
COVERT Pro 3.0.33.28
I tu:
Thanks a lot for the installer for the 3.0.33.28 version as starting from the current version all license terms are changed but not in the favour of users and all the lifetime licenses are automatically converted to yearly licenses. EDIT: the installer doesn`t work with another key except the giveaway key. :(
S
spamtrash
Tu byl sobie post, ale @Kamelka ma pretensje ze jestem "ich ekspertem do wszystkiego". Wiec juz nie ma.
