Monkey's Audio 12.53​
Version 12.53 (March 17, 2026)
  1. Changed: Switched from CAPEInfo to IAPEInfo in calls like CreateIAPEDecompressEx2 to avoid needing the full declaration.
  2. NEW: Added a note to the installer of the 64-bit on an older OS that the 32-bit works on XP, Windows 7, etc.
  3. Changed: Made the constructor of CSmartPtr explicit to avoid ambiguous assignment with an equal operator.
  4. NEW: Added the function CreateIAPEInfo to the exports.
  5. NEW: Added an IAPETagField interface to allow walking a tag using an interface.
  6. Changed: Incremented the library interface version due to the changes (now 15).
Monkey's Audio 12.55​
  • Changed: Updated to Visual Studio Insiders 11612.153.
  • Changed: Moved field definitions to IAPETag.h from APETag.h.
  • NEW: Added a CreateIAPETag function to the exports.
  • NEW: Added APE_GetUTFNFromUTF8 and APE_GetUTF8FromUTFN to the exported functions.
Monkey's Audio 12.58​
  1. Changed: Automatically choose the platform based on known macros (like __linux__) when nothing is set already.
  2. Changed: Renamed the new exports from APE_GetUTF8FromUTFN and APE_GetUTFNFromUTF8 to just GetUTF8FromUTFN and GetUTFNFromUTF8.
Monkey's Audio 12.60​
  • Changed: Updated the comment on APE_INFO_TAG to denote it returns an IAPETag interface now.
  • Changed: Put APE_ in front of the macros in APEInfo.h.
  • Changed: Switched the versioning define to work around the compiler seeing build numbers as octal when they start with zero (please report any issues).
  • Changed: Removed GetName(...) from IAPEIO because it was never used and was not safe against buffer overruns.
Monkey's Audio 12.61​
  • Changed: The about box builds fonts using the same system scaling that the main user interface uses (and honors the font size setting).
  • Changed: Updated to Visual Studio Insiders 11626.173.
  • Changed: Updated to the modern common controls for a little nicer UI.
  • Changed: Switched to a different sizing method for the toolbar (please report any issues).
Monkey's Audio 12.64​
  • Changed: The list of pages in options auto-sizes based on the font selection (previously large font selections could cause truncation).
  • Changed: Did some work on the toolbar layout (removed vertical spacing, size independently, etc.).
  • NEW: Added a File Info toolbar button.
