Remote Desktop Manager 2026.3.18.0​
  • Improvements:
  • Improved editing in Markdown documents (copy and paste, code blocks, footnotes, task lists) and the stability of images, and added a Clear formatting button
  • Improved Network Tools results so they can be selected and copied, with Ping and Traceroute results shown in grids
  • Improved website entries: the Custom host port advanced setting now applies to them
  • Fixes:
  • Fixed "Edit with" in remote file explorers not uploading the edited file
  • Fixed a corrupt offline cache causing an error at startup; the cache is now rebuilt
  • Fixed Actions ribbon tab commands applying to the tree view selection instead of the open session
  • Fixed Active Directory synchronizers logging entries that failed to save as added, and failing to create computers without a DNS host name
  • Fixed Auto typing and Type clipboard on the Home ribbon typing the selected entry's credentials into the active session
  • Fixed clicking in an AI assistant chat's rename box opening the chat and interrupting the rename
  • Fixed column chooser changes in entry lists (folder dashboard, sub-entries, search results) being lost after switching tabs
  • Fixed Copy username and password pasting only the username after the main window was restored from the system tray
  • Fixed crashes when switching tab groups with a session in full screen
  • Fixed CyberArk entry templates and default settings requiring the server, host and username before they could be saved
  • Fixed Devolutions Cloud opening many sign-in prompts at once after a failed background token refresh. Only one prompt opens now, and a cancelled prompt does not reopen on its own for 90 seconds
  • Fixed double-clicking the version in the status bar not starting an update check
  • Fixed Duo push approvals for Keeper credential entries in the Europe, Australia and US GovCloud regions
  • Fixed editing a user group on DVLS not loading its offline setting
  • Fixed entries in a Devolutions Cloud user vault losing their credentials linked from another vault when the vault loads
  • Fixed entries not saving the properties of hidden sections when the entry editor is in simplified view
  • Fixed Find (Ctrl+F, F3) in the documentation viewer and editor
  • Fixed importing user or local specific settings dropping the settings of entries in other vaults, and showing default vault settings under "Unknown"
  • Fixed items in the navigation bar's "More" menu appearing disabled and doing nothing when clicked
  • Fixed Kerberos sign-in failing for RDP entries through a Devolutions Gateway when "RD Gateway is a KDC proxy" is checked
  • Fixed LastPass sign-in with Duo being denied because of operating system restrictions
  • Fixed locked tabs still being draggable, dockable and floatable
  • Fixed Open VPN not working with Website entries
  • Fixed opening an entry linked to Password Manager Pro, or viewing its password, silently doing nothing when no token is configured. My account settings now opens on the Password Manager Pro page
  • Fixed Paste in the embedded File Explorer ignoring files copied in another tab or in Windows Explorer. Ctrl+C, Ctrl+X and Ctrl+V also work now
  • Fixed PowerShell macros, scripts and tools failing on Website entries
  • Fixed remote tools that use session credentials failing with "Incorrect username/password" in DVLS secure, PAM vaults and on high security entries
  • Fixed SSH port forward entries ignoring the default port (22) when used as a VPN
  • Fixed the "No results" message being hidden behind the list in the batch action selection dialog
  • Fixed the BeyondTrust Password Safe dashboard not signing in until the first auto refresh, and asking for MFA again on every refresh after a sign-in was cancelled
  • Fixed the credential selection prompt opening with a folder selected instead of the first credential
  • Fixed the Execute typing macro global shortcut doing nothing on session and macro entries
  • Fixed the Home tab making the ribbon taller than the other tabs in the Simplified ribbon layout
  • Fixed the missing Export button in the User groups and Vault (users and user groups) reports, which can now be exported to HTML
  • Fixed the password generator creating passwords that miss a required character type when every character of that type is excluded. It now shows a message instead
  • Fixed the password strength bar and label showing wrong or cut-off values in the Entry security analyzer after refreshing or sorting
  • Fixed the password strength label sometimes missing in the Entry security analyzer
  • Fixed the tooltip on an embedded session's tab being empty after the tab was undocked or docked again
  • Fixed the Username and Description column toggles in the Favorites panel not showing or hiding the columns
  • Fixed the View OTP window still recording a view every 30 seconds after it was closed
  • Fixed undocked sessions changing the selected tab in the main window when activated
  • Fixed vault permissions set to Inherited showing the vault's last saved value instead of the value inherited from system settings
  • Fixed View password and View sensitive information being greyed out in System settings > Default permissions
