Remote Desktop Manager 2026.1.14.0​
Version 2026.1.14.0​
DVLS 2026.1 is required with this version (only if you're already using DVLS)
Improvements​
  • Added multi session support for AI Assistant
Fixes​
  • Fixed a possible loss of user specific settings on after creating an instance of a DVLS data source and connecting to it
  • Fixed Active Directory Dashboard duplicating group membership when editing a group
  • Fixed issue where session tools would not be disabled in the dashboard when selecting a credential entry
  • Fixed issue where Typing Macros executed through "Execute in the current tab page" run several times
  • Fixed issue where unlocking RDM could lead to everything being disabled and unusable until a force refresh
  • Fixed issue with opening multiple embedded Windows Te
Remote Desktop Manager Free 2026.1.22.0​
  • Improvements:
  • Added a group policy to control the visibility of the 'Copy to YubiKey' option
  • Added convert action for deprecated embedded credentials plus quick access through overview warning
  • Added multi-select support when selecting contacts in "Link existing contact" prompt of Software entry properties
  • Excluded PAM vaults from secure message vault selection
  • Removed PAM vaults from Devolutions Server credential vault selection
  • The SSH terminal compact display now remembers the last selected folder between sessions
  • Fixes:
  • Fixed a possible login issue with 1Password
  • Fixed a potential error with custom folders in favorites
  • Fixed an issue where system proxy mode "No Proxy" silently bypasses Devolutions Gateway
  • Fixed crash for missing session type in NetBox synchronization
  • Fixed crash when copying a password with missing source IDs in Hub data sources
  • Fixed duplicate built-in PAM providers appearing in the Add Provider list
  • Fixed filter prompt not appearing when using the shortcut
  • Fixed freeze issue when the DVLS pre-authentication proxy fails
  • Fixed freeze when cancelling the Azure VMs sync login
  • Fixed offline security reconfiguration unnecessarily triggering on every file -> settings save
  • Fixed password list items requiring an item selection when opening history from an item
  • Fixed performance issues when filtering entries and when importing large .rdm files
  • Fixed possible crash when loading the cache
  • Fixed SSH entries not supporting certain PuTTY extensions
  • Fixed SSH sessions not being able to scroll up when using Codex or BYOBU
  • Fixed Tasks no longer showing up for SQLite data sources
  • Fixed templates with "prompt with list" credentials not loading the prompted folder
  • Fixed the Zoho Vault credential integration and added region selection and CAPTCHA support
  • Updated Netwrix Password Secure integration for the 2026 version
Remote Desktop Manager 2026.2.7.0​
  • Fixed passwords being loaded into Quick Search for users who lack the required permissions
Improvements​
11
  • Added a gateway connectivity test to the PAM service
  • Added a group policy to hide the Quick Connect prompt confirmation message
  • Added a quick connect button for when the status bar is too narrow to show the full control
  • Added a refresh of access requests when manually refreshing the vault
  • Added a restriction preventing privileged accounts from being added without a license
  • Added a right-click menu to the Password Analyzer for quicker access to actions
  • Added the ability to select a host entry as a template in host entries
  • Added the username format option to My Privileged Account and My Personal Credentials modes
  • Improved extracting a credential entry so it copies the owner entry's permissions to the new credential
  • Removed the check-out status row from folder overviews
  • Restored the 'Open as SFTP/SCP' option for all session types
Fixes​
19
  • Fixed a 1Password single sign-on error that could occur after multiple logins
  • Fixed a 403 error on startup when loading Hub permission assignments
  • Fixed a black artifact appearing when opening a dialog
  • Fixed a possible error during quick connect in a terminal services session
  • Fixed a potential crash when closing the application
  • Fixed a PowerShell injection vulnerability in VMRC connections
  • Fixed agent connections so they survive an RDP reconnect
  • Fixed an incorrect argument passed to SSMS after its latest updates
  • Fixed an issue when moving or duplicating a folder that contains a virtual folder
  • Fixed an issue where a user with the "Deleted entries" permission could not restore or delete history
  • Fixed converting a synchronized entry with a template so the entry is still recognized on the next synchronization
  • Fixed entries not refreshing after batch editing their hosts
  • Fixed license assignment when editing a user in DVLS
  • Fixed loss of Linked (vault) credentials, SSH keys, proxies, and gateways when a Hub Personal data source is converted to Hub Business
  • Fixed management views opening the same window multiple times on the Free edition
  • Fixed shortcut keys not always being displayed correctly after they were modified
  • Fixed the calendar date picker not respecting the user's culture
  • Fixed the private key dropdown not loading keys when on the User Vault tab
  • Fixed the proxy bypass list not handling regular expressions correctly
Remote Desktop Manager 2026.2.11.0​
  • Improvements:
  • Added a Remote Command option to SSH Tunnel entries in the Advanced tab
  • Added an Undocked Windows mode to choose how undocked sessions open (Tabbed, Grouped, or Standalone)
  • Added back the Caps Lock indicator on the application login prompt
  • Added back the Parallels 2X Client add-on
  • Added Proxmox credential type support in the free version
  • Added support for both pageant and openssh modes at the same time in SSH key agent
  • Added the missing option to import RDP files
  • Excluded PAM vaults from SSH key linked vault selection
  • Improved ControlR add-on authentication by replacing privileged access token login with Username, Password, and Bearer Token options
  • Improved performance on Devolutions cloud workspace
  • Removed the no longer functional "Show Application Tools Tab" option from the UI layout settings
  • Removed the SFTP panel splitter when the section is hidden
  • Fixes:
  • Fixed a crash that could occur when a window was closed during initialization
  • Fixed a crash when the DisableToolsMenu group policy was enabled
  • Fixed a data refresh issue with Devolutions cloud workspaces
  • Fixed a possible crash caused by invalid color conversion
  • Fixed an issue where only one Windows Terminal process could be opened at a time
  • Fixed an issue with the Enter key and multiple selections in the favorites view
  • Fixed and restored the editable context menu
  • Fixed attachments not being sent via shareable link on SQL Server workspaces
  • Fixed copy to YubiKey not appearing for PAM domain users
  • Fixed creation date sorting in the task list
  • Fixed embedded credentials not being displayed in user-specific settings
  • Fixed embedded RDP sessions not filling the screen in full screen mode when using Smart Sizing
  • Fixed file selection when exporting certificates
  • Fixed GPT 5.5 model availability in the AI Assistant
  • Fixed Hub workspace entries becoming inaccessible
  • Fixed incorrect connection status shown in the favorite view for opened connections
  • Fixed integrated security not filling the username automatically
  • Fixed layout issues in the play list macro script selection dialog and added double-click support to confirm selections
  • Fixed missing due date color indicators in the task list
  • Fixed PowerShell sessions launched with Run As credentials to display a proper error message when the launch fails instead of silently failing
  • Fixed several UI issues in the prompt for pasting multi lines in terminals
  • Fixed single-line break pasting triggering a multi-line warning in terminals
  • Fixed SQL Server workspace being incorrectly forced into in-memory caching mode after an edit
  • Fixed SSH Shell issue where selecting the tab did not properly focus the terminal
  • Fixed task list column layout not saving and drag-and-drop not working
  • Fixed the calendar date picker watermark to use the current culture instead of the operating system culture
  • Fixed the default mode for the account life cycle policy
  • Fixed the default paths for the SCCM add-on
  • Fixed the file browser so the All Files filter now shows files with no extension
  • Fixed the linked picture not being saved when adding a new contact entry
  • Fixed the tab list not auto-hiding when closing entries from its context menu
  • Fixed undocked sessions pulling the main window to the front
  • Fixed View Password showing an encrypted value on checked-out entries
  • Fixed YubiKey fields not receiving automatic focus when the window opens
  • In Software license entry type, fixed some issues ("Assigned to" dynamic text not accurate when creating entry). Also fixed not being to manual input licenses in contacts
