Remote Desktop Manager 2026.2.18.0​
SECURITY​
  • Zaloguj lub Zarejestruj się aby zobaczyć!
    Added a prompt to review and trust unknown or changed VNC server RSA-AES keys before connecting
IMPROVEMENTS​
8
  • Added a cancellable progress window while authenticating to Keeper, so RDM no longer becomes unresponsive during Keeper login, two-factor, and device approval prompts
  • Added a creation time, CPU usage and assigned memory columns to the Hyper-V virtual machine list
  • Added a smart card Kerberos certificate logon option for RDP entries, along with the group policy that turns it off
  • Added an "Apply theme to WebViews" option so web entries follow the current RDM theme
  • Added handling for OpenSSH certificate signed for an sk-ed25519 and sk-ecdsa key
  • Added informational tooltips to Passwordstate fields
  • Improved the SSH shell logging prompt so you can proceed without logging instead of having to cancel the connection
  • Redirected user, vault, user group management to the web interface when on a DVLS workspace and RDM is a 2026.2 version while the server is 2026.3
FIXES​
37
  • Fixed a crash when revealing an attachment's password in Devolutions Cloud workspace
  • Fixed an insufficient rights error when working offline, where every administrative permission was denied
  • Fixed an issue exporting entries while offline in a Devolutions Cloud vault
  • Fixed an unhandled error when pasting into the AI Assistant chat input
  • Fixed changes to a PAM provider's checkout policy not being applied correctly
  • Fixed Devolutions Cloud activity log entries showing raw internal names instead of readable, translated messages
  • Fixed DVLS embedded login not loading entries after using the "Have trouble logging in" link
  • Fixed focus issues when opening entries as undocked windows
  • Fixed folder names not resolving their variables in the suggested file name when exporting entries
  • Fixed FreeVNC file transfer issues with drive listing, remote paths, and the overwrite prompt
  • Fixed Intel AMT entries connecting to localhost instead of the target host
  • Fixed intermittent flickering when using multiple SSH Shell entries together
  • Fixed license assignments being lost when you cleared the user search in license management before saving
  • Fixed MAC address discovery failing on Host entries
  • Fixed nmon renderering incorrectly in SSH terminal entries
  • Fixed Quick Connect remaining usable even when the "Disable quick connect" policy was enabled
  • Fixed RDM freezing on startup when connecting to a Devolutions Server workspace
  • Fixed RDP entry type option controls being cut off when the options window is at its minimum size
  • Fixed RDP NTLM authentication failing when the account's UPN suffix differed from the Active Directory domain name
  • Fixed SFTP not preserving timestamps in certain cases
  • Fixed SSH Shell multi-line copy of ANSI-colored terminal output drops spaces around colored tokens
  • Fixed terminal rendering to apply anti-aliasing settings which are without effect right now
  • Fixed terminal sessions using both a gateway and session recording failing when interactive authentication took longer than the gateway's recording timeout
  • Fixed the 1Password results window opening behind the main application window
  • Fixed the 1Password window prompt opening behind the RDM main window
  • Fixed the copy host button doing nothing for ControlR entries in the entry overview
  • Fixed the country being cleared when editing a user in SQL Server workspaces
  • Fixed the credentials section staying visible in folder properties for folder types that do not support credentials
  • Fixed the Devolutions login window not accepting keyboard or mouse input when RDM is used through a remote session
  • Fixed the KeePass (Direct mode) key file browser opening as "Save as…" instead of "Open"
  • Fixed the KeePass entry properties database file picker in Direct mode opening as "Save as..." instead of "Open"
  • Fixed the most recently used entries list being empty in a Devolutions Cloud workspace
  • Fixed the most recently used list overriding the dashboard in a shared vault
  • Fixed the Password Depot credential picker so folders can be expanded and entries inside them selected
  • Fixed the To Do list letting users add items to entries they don't have permission to edit
  • Fixed the x64 and ARM64 app launchers being built against the wrong .NET runtime
  • Fixed unsupported (out-of-date) RDM versions still being able to load vaults when blocked by minimum-version requirements
Remote Desktop Manager 2026.3.9.0​
IMPROVEMENTS​
10
  • Added a group policy to control the clipboard clearing delay
  • Added a title bar menu to undocked session windows
  • Added an option to move the quick search box from the title bar to the status bar
  • Added back the group policy that hides the top bar
  • Added back type-ahead search in the entry tree, so typing jumps to the matching entry
  • Improved Microsoft SQL Server workspaces by restoring connection pooling with Windows authentication, with clearer messages when the connection fails
  • Improved session tab behaviour, so tabs size consistently, resist accidental undocking while dragging, and stay in sync with the Tab list pane
  • Improved the CyberArk error message shown when an account has no connection component available, instead of failing silently
  • Improved the ribbon to be more compact, moving overflowing groups into a popup
  • Removed VNC Viewer Plus from the available VNC client selections
FIXES​
34
  • Fixed a crash when a DVLS workspace returned a truncated response through a proxy, which now falls back to offline mode instead
  • Fixed a crash when closing the undocked session tab menu
  • Fixed advanced search results not refreshing after checking an entry in or out, or changing its status, from the right-click menu
  • Fixed being prompted twice for the email address when signing in to a Devolutions Account
  • Fixed browsing SecureCRT session names raising an error instead of opening the session browser
  • Fixed copy actions being hidden on the credential and data entry dashboards
  • Fixed CyberArk single sign-on failing
  • Fixed docking the navigation pane into the session tab area
  • Fixed embedded web views losing their state when a session tab was undocked or re-docked
  • Fixed entry names containing square brackets being truncated in the navigation tree
  • Fixed global keyboard shortcuts not triggering when the application did not have focus
  • Fixed local templates missing from the quick connect template list
  • Fixed non-square custom entry images being distorted in the entry properties image preview
  • Fixed password history being offered on an entry that has not been saved yet, where using clear history saved the entry prematurely
  • Fixed ProtonPass login failing
  • Fixed re-docked session tabs being forced to the first index
  • Fixed session recording producing blank captures for SSH and Telnet sessions
  • Fixed session tabs starting an unwanted drag and undocking themselves after a missed mouse button release
  • Fixed switching the active icon buttons inside fields not working when pressing the tab key
  • Fixed terminal sessions losing keyboard focus after the multi-line paste warning was dismissed
  • Fixed the "Group by" choice in the workspace selector not being saved
  • Fixed the background color of the Quick start page
  • Fixed the Default vault being missing from the list of editable vaults in SQL Server workspaces
  • Fixed the Discover button in website entries failing to detect the page's fields
  • Fixed the embedded web browser resizing its page when hovering a link; the link target now appears in the browser's own status bar when that option is enabled
  • Fixed the entry tree scrolling back to the selected entry every time it refreshed
  • Fixed the error shown when opening the current page of an embedded web session in an external browser, which now uses the system default browser
  • Fixed the File Explorer session being unable to navigate to shared network paths
  • Fixed the filter results popup not appearing when the navigation pane was hidden
  • Fixed the PIN requirement prompt reappearing on Devolutions Cloud workspaces when the configured iteration count was below the minimum the workspace requires
  • Fixed the ribbon height to match the previous version's layout
  • Fixed the universal installer shipping only the build machine's native components, leaving other architectures without the components they need
  • Fixed unpinned auto-hide panels opening with the wrong dimensions
  • Fixed Windows Terminal sessions closing when the session lost focus
Remote Desktop Manager Free 2026.3.12.0​
  • Improvements:
  • Added a My check-outs widget to the navigation rail, listing your check-outs, pending requests and approvals with Check in, Request extension and Cancel request actions
  • Added an option in the Local to Cloud migrator to set the Devolutions Cloud workspace as the default workspace after migration
  • Improved session tabs: reopening last sessions keeps tab order and the active tab, the docked navigation pane appears in the tab list, and closing a background session no longer steals focus from other applications
  • Improved the auto-hidden navigation pane to focus the filter box when opened, if the filter is placed in the navigation pane
  • Improved the network tools (Ping, Traceroute, Port scan, Diagnose, WHOIS and others) with faster host name resolution, clear errors for unknown hosts and a steady ping interval
  • Fixes:
  • Fixed "Select in navigation pane" from the all vaults search results selecting the wrong item for a folder in another vault
  • Fixed adding entries in DVLS PAM vaults failing with a "not found" error
  • Fixed auto-typing the username or password not reaching the embedded session
  • Fixed certificate export always saving with a .cer extension regardless of the selected format
  • Fixed Cisco AnyConnect VPN sometimes losing the password because it was typed before the prompt appeared
  • Fixed collapsed (auto-hide) panes, such as the navigation pane, missing a separator line
  • Fixed custom password complexity minimums being reset to defaults when navigating between tabs in entry properties
  • Fixed deleting old backups showing an unnecessary error when a backup folder could not be removed, for example while OneDrive was syncing
  • Fixed Devolutions Cloud gateway diagnostics always showing the Devolutions Agent as not installed
  • Fixed embedded RDP sessions switching to full screen leaving a stray window, and the full-screen toolbar's "Restore" and "Embedded" buttons not working
  • Fixed entries appearing duplicated in the navigation tree when a vault was loaded from the offline cache
  • Fixed entries saving with a password that fails its password complexity policy, or with required fields left empty
  • Fixed keyboard shortcuts not working for open modes unpinned from the Open with parameters submenu
  • Fixed PAM propagation script configurations losing WinRM settings such as the trusted certificate thumbprint and CredSSP on save
  • Fixed PAM SSH key accounts not being listed when choosing a privileged account as the private key in SSH entries
  • Fixed port pickers suggesting ports are already used by other entries in settings such as OpenVPN, Devolutions Gateway and port forwarding
  • Fixed PowerShell sessions in Windows Terminal or the embedded console garbling the display when recalling command history with the resize window option on
  • Fixed pressing Enter a second time with "Filter the tree list only on Enter key press" not opening the highlighted entry
  • Fixed Proton Pass sign-in failing when a CAPTCHA was required; a verification window now opens to complete it
  • Fixed repeated or duplicate browser sign-in prompts for DVLS workspaces behind an Entra ID pre-authentication proxy
  • Fixed some issue where embedded RDP sessions kept memory after their tab was closed
  • Fixed SSH sessions using an SSH key breaking when terminal compression was enabled
  • Fixed templates with custom or linked images showing no icon in the Quick Connect template menu
  • Fixed text boxes selecting all their text when a dialog opened or after switching back to RDM with Alt+Tab
  • Fixed the "Save and open" button missing when editing an entry
  • Fixed the computers list in the Import Computers wizard missing its filter box and no longer checking all selected rows at once
  • Fixed the desktop extension's passkey sync prompting for the password of locked vaults
  • Fixed the Devolutions Cloud gateway ruleset showing allow rules in the deny list and not saving rule changes to the server
  • Fixed the DVLS workspace username prompt requiring a password when only a username was needed
  • Fixed the keyboard focus indicator not showing on the default button of prompts, or after switching back to RDM
  • Fixed the main menu or quick access bar turning blank after switching window style, and the Dashboard tab being blank when Quick Start was shown at startup
  • Fixed the main window title no longer showing the active tab title, and restored the application name in dialog window titles
  • Fixed the Manage broadcast window blocking the rest of RDM while open
  • Fixed the offline sync settings for documentation and documents not inheriting from higher folders when a folder was set to Default
  • Fixed the request vault access list showing no vaults for DVLS workspaces on newer servers
  • Fixed the spreadsheet editor in document entries, which no longer blocks the interface while an Excel file loads
  • Fixed the SSH key agent reloading the previous vault's keys after switching workspaces
  • Fixed the user groups search being case-sensitive and behaving inconsistently
  • Fixed the Windows credential prompt not being centered when launching an embedded RDP session
  • Fixed user avatars not showing in the pending checkout requests dialog, which only displayed initials
Remote Desktop Manager 2026.3.15.0​
  • Improvements:
  • Added a document versions action to the View menu of document entries stored in the database, to download or restore any previously saved version (SQL Server, and DVLS 2026.3.10.0 or later)
  • Added an experimental built-in video decoder option in Options > Recording > Playback, so session recordings can play on Windows Server hosts without a VP8 decoder
  • Added support for session-specific one-time passwords with Sophos Connect VPN
  • Improved terminal rendering speed in SSH sessions, so typing lags less
  • Improved the RDP error shown when NTLM authentication is blocked on the remote computer
  • Improved the search boxes of the Password List, the View list windows and the entry selection dialogs to follow the filter mode set in Options (treat space as AND or as OR)
  • Improved update security by verifying the Devolutions signature of the downloaded installer before launching it
  • Fixes:
  • Fixed "Browse..." in the CyberArk account selection window not keeping the browsed safe in the Safe list, and canceling resetting the selection to the first safe
  • Fixed "Show/Focus navigation pane at startup" not opening the navigation pane when it is set to auto-hide
  • Fixed a newly created entry not being selected in the navigation tree of the user vault
  • Fixed an "@" character that could be typed into an RDP session when switching focus between the session and other applications
  • Fixed application freezing while resolving Password Manager Pro credentials when session recording is active
  • Fixed Copy username and password pasting nothing in Chromium-based applications such as Slack, Teams and web browsers
  • Fixed Delinea Secret Server single sign-on stalling when the "Keep me logged in" page was not shown
  • Fixed Devolutions Cloud workspaces becoming unusable, with a misleading "has been disabled" message, after the server returned an invalid URL during sign-in
  • Fixed double-clicking an entry with sub-entries in the navigation tree also expanding it instead of only opening it
  • Fixed editing a role's assignees from a vault's role assignments removing existing members that the editor did not list
  • Fixed entry and folder names that use custom variables keeping their old values until a restart after the variables were edited in system settings or application settings
  • Fixed entry permissions not being editable in vault templates, and permissions set in a template being dropped when a vault was created from it
  • Fixed errors when creating, saving or closing spreadsheet documents
  • Fixed failed file transfers in file explorer entries giving no feedback; an error message is now shown
  • Fixed File > Settings prompting to log in to the workspace on save even when no shared setting had changed
  • Fixed focus jumping to an unrelated application after an embedded RDP session disconnected
  • Fixed focus session in the activity logs not selecting the related entry
  • Fixed HTML vault exports, grid exports and built-in HTML reports being cut off after about 1 MB, which left out every entry past that point
  • Fixed Inventory Report entries freezing RDM during a refresh; the scan now runs in the background with progress and a Cancel button
  • Fixed local templates appearing in "Add from template" when local templates are disabled in system settings
  • Fixed passkeys and website logins sent from the browser extension being added to locked vaults
  • Fixed passkeys from the Devolutions Desktop Extension not working when RDM runs elevated, which also logged an "Access to the path is denied" error every second
  • Fixed RDP sessions set to open in full screen connecting at the size of the embedded tab instead of the monitor
  • Fixed reverting a document entry stored in the database from its history, which restored the wrong file or an empty one on SQL Server and did not restore the file at all on DVLS
  • Fixed selecting contacts for a software entry, where the selection dialog could return the same contact twice after its list was refreshed
  • Fixed Telnet sessions ignoring Local echo when it was set to Off, which made every typed character show up twice
  • Fixed the "Can't get exclusive access to known_hosts file" error that appeared when several SSH sessions were opened at the same time
  • Fixed the "Change monitor" button of the full screen session toolbar cycling through monitors instead of showing a monitor picker when more than two monitors are connected
  • Fixed the "There is an error in XML document (2, 2)" error when opening customized default entry settings, or adding an entry of that type, with "Use connection loader optimization" turned off
  • Fixed the "View password" window bringing the main window in front of other applications when it gets focus
  • Fixed the application freezing when selecting a folder that contains many subfolders
  • Fixed the application switching to limited mode (grayed out) when a workspace's stored license had expired even though a portable license was applied
  • Fixed the context menu of sealed entries, especially in Favorites, showing unrelated actions from the previously right-clicked entry; only Unseal, Delete and Add/Remove from favorites are now available
  • Fixed the custom tab title being replaced by the entry name in Apple Remote Desktop (ARD) and VNC sessions
  • Fixed the details pane of the Server logs report staying empty until a row was clicked
  • Fixed the gateway farm health icon in the gateways list showing green while some of the farm's gateways were down
  • Fixed the loading bar of the Jira, HaloPSA and ServiceNow ticketing dashboards staying frozen or invisible
  • Fixed the Modified date of attachments in Devolutions Cloud vaults not being updated when an attachment was added or edited
  • Fixed the one-time password of privileged account (PAM) entries ignoring the combination string and the append or prepend to username options, and going stale while "View password" stays open
  • Fixed the PEDM policy manager keeping stale profiles selected after a refresh, which made the selection grow with each click
  • Fixed the security dashboard recommendation for a default password policy
  • Fixed the settings search box (entry properties, settings, system settings and batch edit) leaving a double-clicked result over the category text of the next results
  • Fixed the Tags field adding the first suggestion automatically while typing; a suggestion is now added only when clicked or with Tab or Enter
  • Fixed the terminal multi-line paste warning not having Yes as the default button, so enter now confirms the paste
  • Fixed the View password window missing its minimize button, and made it always open with the password masked by default
  • Fixed the workspace information view not updating its vault details, such as offline mode and rights, when switching vaults
  • Fixed undocked sessions not opening on the monitor set in the entry's display settings or in the default undocked monitor option
  • Fixed variables such as $HOST$ in the names of shortcut entries resolving to empty values instead of the values of the source entry
  • Fixed VNC entries failing to connect to servers that enforce TLS 1.3 with VeNCrypt X509 authentication
  • Fixed web browser entries freezing for the length of the typing macro's initial delay before the page could render
  • Fixed website entries not filling the password on FortiOS 7.4 and later login pages
