Remote Desktop Manager 2025.3.20.0​
Version 2025.3.20.0​
DVLS 2025.3 is required with this version (only if you're already using DVLS)
Improvements​
  • Added command for pasting clipboard in typing macro and terminal command
  • Added edit to password generator for policies
  • Added port support in the CSV import
  • Added support for adding new virtual machines in Proxmox
  • Hide SSH key information when creating an SSH key entry
  • Improved behavior so users without vault access can be selected in entry permissions
  • Improved password history display granularity
  • Improved the sealed entry dashboard to display the seal information and tags
  • Minor improvements to onboarding UX
Fixes​
  • Fixed "no vault access" appearing in grids when it shouldn't
  • Fixed an error when configuring a cyberark data source
  • Fixed an issue where opening 2 websites via the same Devolutions Gateway would fail for the second one
  • Fixed error in CyberArk datasource configuration
  • Fixed error when switching data sources
  • Fixed errors with certain AI assistant modes that weren't working properly
  • Fixed HDPI issue in clean up manager
  • Fixed Hyper-V error states and crashes
  • Fixed incorrect clipboard message when using Terminal copy text feature
  • Fixed issue where Bitwarden credentials were lost because AccountId property had been renamed
  • Fixed issue with inherited PAM permissions
  • Fixed issue with mode selection when editing local password policies in Hub Business
  • Fixed possible issue with deadlock in streaming recorder certificate callback
  • Fixed username and password field absent in AnyIdentity providers
  • Potential fix for issue with SSH key agent crashing
Remote Desktop Manager 2025.3.21.0​
  • Improvements:
  • Added 3Dconnexion and ePadLink devices to RDP device redirection
  • Added configuration to disable tools in AI components
  • Added Password Generator button to Password Policies window
  • Improved "move to vault" by performing the action server-side for Devolutions Server
  • Improved Proxmox to support creating Proxmox LXC containers
  • Fixes:
  • Fixed "Prompt on connection" wasn't displayed in dashboard when using folder filter
  • Fixed an issue where PAM checkouts weren't identified in the navigation pane
  • Fixed an issue where variables in my privileged account where overwritten by their value
  • Fixed ClipboardCopyMethod policy not letting users handle settings correctly in File-Settings when active
  • Fixed issue with certain shortcut keys in Avalonia views
  • Fixed issue with code page CP850 in SSH terminal
  • Fixed issue with synchronizers (Azure, Jamf, Netbox) fields settings tab where values were saved even on cancel
  • Fixed issue with underscore character not being escaped in Avalonia views
  • Fixed issue with WebView2 crash during disposal
  • Fixed jump timeout issue when RDP is taking too long to connect
  • Fixed port knocking infinite loop
  • Fixed potential issue with NetApp devices not accepting text input in SSH
  • Fixed resolving variables from user vault search credentials
  • Fixed selection issue when editing a password policy
Remote Desktop Manager 2025.3.22.0​
  • Improvements:
  • Added a CAPS lock indicator in login prompts
  • Added a setting to specify the nav bar position (bottom. top or side)
  • Added CyberArk PSM HTML5 connection support for Web entries
  • Added older 3DConnexion (Logitech) devices in RemoteFX redirection
  • Batch edit can now be launched at the root to change all entries in the vault
  • Improved asset overview to show linked owner and site
  • Improved UI performance with large vaults
  • Minor improvement to load AI models dynamically rather than from a static list
  • Set user agent on HttpClient for OAuth/OpenIddict requests to Devolutions Server
  • Variables in user vault entry names will now be resolved when using "Find by name" credential mode
  • Fixes:
  • Fixed a crash when a non-admin edits gateway permissions
  • Fixed an issue where editing PAM JIT groups would remove the configured custom display names
  • Fixed an issue where proxy localhost and host exclusion settings weren't sent to the terminal
  • Fixed an issue where the gateway permissions window was wrongly displaying vault access information
  • Fixed an issue where the Workspace browser extension notification would make application flash infinitely
  • Fixed an issue where vault tags weren't loading when editing an entry's tags
  • Fixed Bitwarden csv organizations import
  • Fixed DVLS messages timestamps being displayed in UTC
  • Fixed inheriting connection string from database folder in Hub datasources
  • Fixed issue in Password policy advanced settings mode, where minimum length would sometimes incorrectly load when modifying the policy
  • Fixed issue in Telnet where you couldn't type in the terminal
  • Fixed issue where drag&drop to move entries didn't work in DVLS
  • Fixed issue with canceling the transfer of folders in file explorers
  • Fixed issue with maintenance expired at startup
  • Fixed issue with migration on first load in Hub
  • Fixed issue with SFTP not displaying the directory contents when using Wing FTP
  • Fixed issue with theme in release notes
  • Fixed small issues in the AI assistant flow
  • Fixed the "Do this for all conflicts" option not working in file explorers when transfering folders
Remote Desktop Manager 2025.3.23.0​
Version 2025.3.23.0​
Security and Breaking changes​
  • Breaking changes Removed the legacy Netwrix password safe import option - Use the generic CSV importer instead since it's more flexible
  • Breaking changes Reworked the TeamPass integration to support the password and to work with the latest version - To keep using older versions of TeamPass, stay on a previous release of Remote Desktop Manager
Improvements​
  • Added a vault selector to the PAM account connect prompt
  • Added default installation path to TeamViewer when path can't be found through registry
  • Added Password generator option to certain features (SSH Key and Certificate generator, Create a shareable link)
  • Added support for sending a password through the runas command via GSudo in command line and local Powershell sessions
Fixes​
  • Fixed a potential Native Messaging issue causing the process to remain alive when an IPC call failed to return
  • Fixed an issue where opening the release notes or product news would start the session recording
  • Fixed an issue where the Windows terminal session would always prompt for custom parameters
  • Fixed issue where WinForm Avalonia view leaked the return key capture
  • Fixed issue with privileged session view dropdowns filtering out the content while typing
  • Fixed issue with the reorder playlist causing an error prompt
  • Fixed lost focus on navigation pane when navigating with keyboard
  • Fixed norwegian language breaking markdown editor
  • Fixed Pam checkout approval from messages issues
  • Fixed the Pleasant password account selection not getting enabled when selecting SSO
  • Fixed VPN SSH not saving/loading gateways
Remote Desktop Manager 2025.3.25.0​
  • Security and Breaking changes:
  • Security Fix Fixed issue where the API key in the AI Assistant entry wasn't encrypted - Existing entries should be re-saved to apply the fix, and an automatic migration step will be available in 2026.1
  • Improvements:
  • Accomodate connection delays in MsRdpEx remote recording
  • Added additional triggers and dispatched events on certain webpages to ensure they correctly detect when WebView2 autofill has filled the login fields
  • Added attachments tab to VPN entries
  • Added Delinea secret's MFA challenge support
  • Added fallback for UltraVnc installation path
  • Added handling for Smart Folder to navigate to folder on double click if no special actions are detected
  • Added support for multiple SANs in certificate generator
  • Added unified take_screenshot MCP action
  • Fixes:
  • Fixed "Keep template host on quick connect" no longer working when launching quick connect with a typed-in host
  • Fixed a crash with the Psono dynamic credentials
  • Fixed an issue where local powershell setup commands were sent to the remote host
  • Fixed an issue where the Pleasant password account settings couldn't be saved
  • Fixed an issue where the Psono entry selection was not available
  • Fixed an unwanted prompt for command line parameters
  • Fixed autofill issue with Microsoft Internet Explorer (deprecated) web login
  • Fixed canceling session with recording not closing the tab correctly
  • Fixed duplicate nodes when viewing Hyper-V cluster
  • Fixed focus session not working with Host type entries
  • Fixed incorrect launching interaction with X509 certificate credential
  • Fixed issue in X.509 entry where certain certificates couldn't be read
  • Fixed issue saving SSH entries with no gateways in custom mode
  • Fixed issue using variables in TeamViewer ID field in templates
  • Fixed issue with Dameware not sending password between quotes
  • Fixed issue with virtual gateway creation in Hub
  • Fixed PasswordAgent import support
  • Fixed Pleasant password SSO not resolving to the configured host/port
  • Fixed Show password option in the AI settings is not working
  • Fixed the Powershell RDM Cmdlet tool
  • Potential fix for out of memory exception when leaving application running with active sessions
Remote Desktop Manager 2025.3.27.0​
Version 2025.3.27.0​
Improvements​
  • Adjusted Hub Send dialog to match supported workflows
  • Changed default binding mode for certain Keyboard Shortcuts to be more contextually relevant
  • Improved the check for "browse for host" setting to apply to the quick connect selection
Fixes​
  • Fixed an issue where the vault shortcut entry wouldn't navigate to the chosen folder
  • Fixed an issue where vault access requests couldn't be sent on PAM vaults
  • Fixed an issue where you could request access to vaults you already had access to
  • Fixed Barracuda entry attempting to connect with wrong profile
  • Fixed Company not properly loading in folder dashboard in the entries section
  • Fixed issue with SSH entries crashing the application when closing
  • Fixed overview credentials resolving when set to inherited and parent is set to "My privileged account"
  • Fixed port generator incorrectly interpreting which port to include
  • Fixed the ticket enforcement setting not saving
Remote Desktop Manager 2025.3.32.0​
Version 2025.3.32.0​
Improvements​
  • Add column for the "Owner" field in the dashboard and navigation pane
  • Added Devolutions Gateway support to SSH PAM providers
  • Improved double-click behavior in "all vaults" and advanced search to both navigate to folder and launch entries by default
  • Improved how CyberArk session expiration is handled
Fixes​
  • Fixed 'Mandatory on JIT elavation' issues on a PAM SSH account's checkout
  • Fixed 'Unable to connect to your data source' prompting after losing connection even when you switched to another data source
  • Fixed $SESSION_ID$ returning wrong ID when PowerShell macro is executed from RDP session's context menu
  • Fixed administration dashboard failing to load when vault is empty
  • Fixed ALT + ASCII code combinations not producing any characters in SSH terminal
  • Fixed certain entries not respecting the "Disable password saving in vaults" feature
  • Fixed chinese characters not appearing in the settings dropdown menu
  • Fixed connection loss that could occur when refreshing access requests
  • Fixed documentation count not updating in dashboard
  • Fixed empty credential names in Passbolt when using encrypted metadata
  • Fixed error in Hub data source when starting an entry from the favorites tab while not in the vault of the entry
  • Fixed error when creating new containers in Azure Blob Storage file explorers
  • Fixed error when opening Teamviewer with a bad ID
  • Fixed host variable resolution issue in website connections when using custom ports
  • Fixed issue where a force refresh is needed to be able to see a PAM provisioner account's password in Hub data source
  • Fixed issue where external RDP connections could fail due to missing a temp folder
  • Fixed issue where the overview would scroll down a small amount by itself when focused
  • Fixed issues saving properties in SecureCRT and SecureFX add-ons
  • Fixed issues with SSPI module for SSH entry
  • Fixed issues with sub menus not loading in the "menu" ribbon mode's contextual menu
  • Fixed Jump sessions failing to launch
  • Fixed loss of connection with the data source triggering resizing issues
  • Fixed missing access rights when working in the User Vault
  • Fixed privileged account vaults incorrectly appearing in linked external vault credential selector
  • Fixed remote services failing to load
  • Fixed slow performance when accessing temporary access on large vaults for non-admin users
  • Fixed SSH account checkout not working correctly with JIT elevation
  • Fixed SSH Key credentials stored in the User Vault not working correctly when used through inheritance
  • Fixed SSH timeout of 300 seconds not being respected when the connection is really long to establish
  • Fixed the Bitwarden synchronizer creating shortcuts on data sources that do not support them
  • Fixed UPN username format not being applied correctly when using PAM credential entries
  • Fixed VPN auto-close not correctly updating the connection's opened state
  • Fixed wrong check out time displayed in check out widget
