Remote Desktop Manager Free 4.5.1.0
    • VERSION 4.5.1.0 (March 6th 2018)
      • Added an option to reduce the navigation tree font size
      • Added option in SSH shell for the scroll reset on display
      • Remember the full screen mode in the Last saved start up window style
      • Fixed a possible DNS issue with the add-on download and Google Analytics
      • Fixed possible crash in ARD/VNC session due to non null terminated strings
      • Fixed some possible erros with the VPN linked
Remote Desktop Manager 4.5.2.0
  • VERSION 4.5.2.0 (March 19th 2018)
    • Added "Download and install now" option for the update dialog
    • Added an option to Expand all folders on filter
    • Added an option to set the maximum item count in the filter combobox
    • Added import from network scan
    • Added Import support for multiple applications
    • Added Services to inventory report
    • Added support for Microphone permission in Chrome embedded
    • Improved the reconnect with the tabbed form
    • Fixed a possible issue with the check browser extension version and the no internet connection setting
    • Fixed a possible lock with the SSH Terminal
    • Fixed an issue with the collapse on clear filter
    • Fixed an issue with the Enter key pressed and the navigation pane undocked
    • Fixed issue with the virtual folders not appearing in the folder selection window
Remote Desktop Manager 4.6.0.0
VERSION 4.6.0.0 (May 29th 2018)
  • Added Google Cloud support
  • Application is now 64-bit
  • Added $PARENT_INFORMATION_IP$ to allow the resolving in the session name
  • Added a Copy Name action
  • Added a thumbnail refresh setting
  • Added an option to hide the default templates (RDP, Wayk, SSH...) in quick connect
  • Added an option to hide the Open (Prompt for credentials)
  • Added browse shortcut button to LogMeIn
  • Added default ribbon option on start
  • Added FreeRDP smart card redirection support
  • Added Include Diagnostic option to error reports
  • Added Keep selection on clear filter option
  • Added option for GSS API credential delegation for SSH native
  • Added Pause and Resume to SFTP download and upload
  • Added Pause/Resume Google Cloud download and upload
  • Added Pause/Resume transfer support for FTP SCP WebDAV
  • Added remember the choice in FrmUpdateAvailable, and made the default "download and install now"
  • Added the email as username for the Copy username and the email account
  • Added the folder column for the Recent view
  • Added the session context menu in the Recent entry list
  • Added Wayk Tool
  • Changed Terminals import to allow importing the tags as groups or as tags
  • Changed the auto update to be async
  • Deprecated Remote Assistance
  • Improved Amazon S3 browser
  • Improved the application exit with opened session message
  • Improved the Azure Table Storage explorer type
  • Improved the error handling for Devolutions Online Drive
  • Improved the SSH to keep session history after disconnect
  • Minor UI fixes
  • Prevent ARD/VNC view from stealing focus when switched to and then off
  • ScreenConnect fixed issue with versions under 6.6 because of the user display name
  • Sticky password import now imports password lists and links them to the appropriate website
  • Web browser find shortcut now takes into consideration the "enable keyboard shortcuts" option
  • Fixed a possible crash with the search in the Hyper-V console
  • Fixed a possible issue with the undocked mode and the default monitor configured
  • Fixed an issue with blank screen when using WebRTC and Google Chrome embedded
  • Fixed an issue with Chrome Remote Desktop
  • Fixed an issue with XenServer dll missing
  • Fixed an thumbnail issue with RDP fullscreen
  • Fixed AWS connection issue with Linux machines
  • Fixed escaping quote issue in Team Viewer password
  • Fixed filter collapse behaving different when clearing and when emptying the filter
  • Fixed Google Cloud Log to file
  • Fixed Google Cloud potential error
  • Fixed HTML export where username was shown even when the value was empty
  • Fixed issue when RDP connection using IP address also used custom domain override
  • Fixed issue where pressing the cancel button of Apple Remote Desktop entry's credential prompt causes an unnecessary error message
  • Fixed potential crash with TFTP paths
  • Fixed rename issue with SCP
  • Fixed WinSCP directory download issue
  • Fixing issue with Html export showing the connection's properties twice
  • Fixing rename being enabled locations where it couldn't perform its task properly
Remote Desktop Manager 2019.1.36.0
  • VERSION 2019.1.36.0 (July 4th 2019)
    • Implemented remote path, local path and private key settings in WinSCP
    • Improved the Keeper integration
    • Updated XenServer DLL from 6.0.0.1 to 7.0.0.0
    • Fixed issue with aggressive multi prompts on database folders when you have a faulty connection string
    • Fixed issue with Host import missing the template selection
    • Fixed possible crash when changing masterkey
  • VERSION 2019.1.35.0 (June 28th 2019)
    • Added correct unicode (UTF 16) support in file operation (SSH)
    • Added network path conversion to UNC in Terminal
    • Added verbose to help diagnose SSH jump host issue
    • Removed the automatic DODB data source configuration sync
    • Updated embedded Chrome libraries
    • Fixed a sorting issue with online backup history
    • Fixed inherit issue with filename in session recording
    • Fixed issue with unlocking RDM on DODB datasource if the Devolutions account uses 2FA
    • Fixed unlock issue with DPS
  • VERSION 2019.1.34.0 (June 21st 2019)
    • Added "username" search mode in the select credential window
    • Added 1920x1080 to the RDP display presets
    • Added a Required mode to the pwned check
    • Added an error message and warning for when the vsphere does not support embedded mode
    • Added checks for whitespace only in the name of Vaults, Roles and Users
    • Added support for dynamic credentials and RD Gateway
    • Fixed "show subconnections" not working in favorites view
    • Fixed clipboard loopback (text copied on server triggered local clipboard callback, sending text to server in VNC
    • Fixed install path resolving and ID disappearing for VMware Workstation and VMRC entries respectively
    • Fixed international keyboard characters not handled correctly in VNC
    • Fixed issue saving group settings if changing the group name at the same time
    • Fixed issue where Private Vault was not working with SQL Azure Integrated Authentication
    • Fixed issue with custom credentials not working
    • Fixed issue with reveal password button not showing in My Personal Credentials and My Personal Private Key
    • Fixed issue with synchronizers not doing the duplicate check properly in the private vault
    • Fixed issue with using "edit (special action)" in private vault causing an entry settings wipe
    • Fixed keepass plugin installation issue
    • Fixed the broken delay on sending commands to the Terminal
    • Fixed VMWare VM list issue
    • Terminal password is now prompted correctly, without referring to 2FA
  • VERSION 2019.1.32.0 (June 18th 2019)
    • Added diagnostic for Devolutions Account Login
    • Added thumbnail support for all the Consoles (AD, Terminals, AWS...)
    • Added thumbnail support for embedded Chrome
    • Changed the default value for session recording to be inherited instead of root. Also added inherited as a choice to the filename
    • Improved the thumbnail with a context menu and a color indicator related to the tab color
    • Fixed a thumbnail scroll artifact
    • Fixed a tree view refresh issue on edit
    • Fixed an issue with the certificate prompt behind the main window
    • Fixed possible crash when unable to write logs in Devolutions Terminal
    • Fixed quickconnect "close after connect" not working
  • VERSION 2019.1.31.0 (June 13th 2019)
    • Added duplicate check feature to the VMWare synchronizer
    • Fixed an issue with Keeper
    • Fixed interactive authentication, bug introduced with new feature of 2FA NOT on Terminal authentication
    • Fixed issue with filter buttons when private vault is selected
    • Fixed jump host for SSH
    • Fixed Terminal session recording
  • VERSION 2019.1.30.0 (June 12th 2019)
    • Add 2FA support in SSH terminals without need for interactive auth
    • Changed Database folder connection string to support $PARENT_NAME$ and delayed variable resolving when Inherited
    • Added robustness with font size and window size in Terminal
    • Fixed issue fetching credentials in connection strings
    • Fixed issue where editing an entry in the duplicate report would make you lose your selection
    • Fixed Webview entry with Password List credential repository showing double password list prompt on View Password
Remote Desktop Manager 2019.1.38.0
  • VERSION 2019.1.38.0 (July 12th 2019)
    • Added a fallback to password authentication if the key agent fails in SSH
    • Added Citrix Netscaler as an available session type when applying a VPN/SSH/Gateway
    • Added option in Chrome embedded to disable loading messages
    • Added the status message display feature to all entry dashboards
    • Backspace mode is now correctly supported in Terminal
    • SSMS Add-on changes to support SSMS 18
    • Fixed Google Cloud path handling to allow item names with spaces
    • Fixed issue sending username in Wayk entry in SRD mode
    • Fixed MAC algorithm negotiation to skip matching MAC when the matching cipher has an implied MAC in Terminal
    • Fixed quick connect VNC not prompting for username password
    • Fixed the problem where it was impossible to get access to the "Ping" contextual menu Macro/Script/Tool option with a Web Browser
Remote Desktop Manager 2019.1.41.0
  • VERSION 2019.1.41.0 (August 1st 2019)
    • Added an option in QuickConnect to allow range open format
    • Fixed an issue with the DOD lock
    • Fixed issue where the duplicate menu button wouldn't appear on a folder if it is empty
    • Fixed Terminal when scrollback limit is reached, colors remain aligned
  • VERSION 2019.1.40.0 (August 1st 2019)
    • Added "Session recording" settings in private vault
    • Added a reverse search for tags
    • Added Alternate Host information in overview
    • Added an option for enabling remoteGuard on RDP sessions
    • Added an option in GreenBow settings to make it possible to force the replace config file
    • Added Jump debugging when starting RDM via command line, RDMA Agent will now start RDM 64-bit if/when available
    • Added support for custom server startup in SFTP
    • Added support for job title and department in MySQL user settings
    • Added the possibility to add the Alternate Host field as a column in the treeview
    • Added the possibility to do a search using the Alternate Host field
    • Added vault selector menu in tray icon
    • Improved the Devolutions Account login and automatic refresh connection token
    • Improved the thumbnail overview (colored border and tooltrip with details)
    • Changed the default value in Terminal for the keypad mode in the options to reflect the putty defaults
    • Fixed "Object reference not set to an instance of an object" when using Set-RDMCurrentRepository cmdlet
    • Fixed an issue in Terminal with copy from the normal screen and detect line ending in blank
    • Fixed an issue when backscroll limit is reached in Terminal
    • Fixed an issue when database is empty all actions (add, edit, delete, ...) were disabled
    • Fixed in the Terminal the keypad initial mode setup and the keypad application mode itself
    • Fixed issue with Allow Password In Variables in private vault
    • Fixed issue with Azure MySQL user creation/login
    • Fixed issue with CurrentLoggedUsername when not logged into any datasource yet
    • Fixed issue with password analyzer showing private entries even if not asked when opening it a second time
    • Fixed possible crash when trying to resolve parent
    • Fixed possible crash with powershell cmdlet loading due to variables
    • Fixed possible issue with AxelViewer addon
    • Fixed the issue where "Synchronizer Entries (.RDM)" "Action on entry mismatch" "Make expired" doesn't make them expired
    • Fixed the issue where "Synchronizer Entries (.RDM)" were doubling folder entries
    • Fixed the issue where the dashboard password display was hidden when editing in User specific settings
    • Fixed the issue where using variables in website url were not working properly
    • Fixed type availability session general
    • Fixed UI issues with email notifications
    • Fixed website loading issues in Chrome embedded and added option to disable script same-origin policy
    • Improved the Terminal rendering performance
    • Minor UI fixes
  • VERSION 2019.1.39.0 (July 23rd 2019)
    • Added a loading message on changing entries status
    • Added an option specifically to disable analytics
    • Added an option to make ticket number required in comment prompt
    • Added error handling to lucid login
    • Added recording indicator in tab image and options to change how the indicator appears
    • Added wait progress to reports
    • Changed Office embedded as deprecated due to not being supported anymore
    • Changed visible state of "allow password in variable" checkbox depending on the "view password" right to increase security
    • Improved portability for RDM
    • Improved the view permission in DODB to actually hide the entries instead of disabling them
    • Fixed 401 with DODB when sharing client
    • Fixed Addon translation
    • Fixed autorefresh issue when the root settings are opened
    • Fixed chocolatey dependencies
    • Fixed conversion issue between Putty > SSH Shell where port wasn't transferred correctly
    • Fixed issue resolving $COMPUTER_*$ variables when using different group types
    • Fixed issue where the last usage logs were only visible on a DPS data source
    • Fixed issue where the properties button of a folder was grayed out when the previous selection was a regular session. Also fixed multiple issues with the clipboard buttons in a folder's session menu and dashboard
    • Fixed issue with DODB custom permissions not working
    • Fixed issue with reconnect for quick connect sessions
    • Fixed many issues to Google Cloud
    • Fixed port forward crashes
    • Fixed possible crash when applying variables
    • Fixed possible crashes when opening RDM because of GreenBowVPN
    • Fixed the issue where Backup window closed on double click with DOD & XML data source
    • Fixed the issue where 'Connection Type' field was not saved in advanced search
    • Fixed the issue where deleted entries were "openable" in Recent
    • Fixed the issue where Duplicate a sub connection in the tree view was not working
    • Fixed the issue where 'Open with template' doesn't work with status message
    • Fixed the issue where path for sub connections in recent were not shown
    • Fixed the issue where 'Template search path' drop-list was available in View Folder Details
    • Fixed the scroll in "keep tab opened on disconnect" window
    • Fixed unable to create Password List items and WebCustomAutoFillHtmlItems using RDM PowerShell module
    • Fixed wrong parameter in Wake On LAN that could cause issues
    • Force the reload from offline when editing an entry in offline mode and fixed issue where the UI wasn't refreshed
    • Minor UI improvements
    • Removed the "VPN" from the list of type availability. If you want to remove VPNs, remove all VPNs from the VPN section instead
    • Reset Devolutions Account automatic sign in setting
Remote Desktop Manager 2019.2.14.0
  • VERSION 2019.2.14.0 (October 31st 2019)
    Database upgrade required
    • Added "broadcast action" in SSH shell entry
    • Added badge information in dashboard about attachment and documentation count
    • Added Devolutions Password Server (DPS) credential entry
    • Added Password Hub credential entry
    • Added privileged access credentials for DPS
    • Added session recording support for Chrome embedded entries
    • Added system settings for default tags
    • "Hide sub-connections on filter" changed to "Collapse sub-connections on filter"
    • 1Password view password now prompts the My Account Settings window if account setting are empty
    • Add support for synchronizing folders in VMWare synchronizer
    • Added "expected prompt" feature in SSH Shell
    • Added "Expiration" column in password list entry
    • Added "Private Vault" option in credential mode in entries in private vault
    • Added "send break" command for SSH shell entry
    • Added /noconsentprompt to shadow RDP
    • Added 1Password to My Account Settings
    • Added a "Domain" text field in quickconnect
    • Added a "Find" button in web browser entries in the toolbar
    • Added a new permission to edit information without having the global edit permission
    • Added a setting to aumatically close RDM on idle
    • Added a setting to enable form border effects in terminal services
    • Added an add-on manager to the system settings
    • Added an option "Use taskkill to close the VPN"
    • Added an option to control how copy treats lines in Terminal (either preserve wrapping or preserve formatting)
    • Added an option to hide sub connections when filtering the treeview
    • Added an option to keep the alternate host of an entry when converting with template
    • Added an option to keep the existing tags of a Web Browser when doing a conversion with template
    • Added an option to keep the template name when creating an entry
    • Added domain field to the 1Password import
    • Added duplicate user account creation
    • Added email column to the user section of the security management window
    • Added extension for Bitvise
    • Added fallback if gravatar call fails in security management
    • Added file transfer via SSH connection
    • Added GPO "Disable Analytics"
    • Added hyperlinks to more easily copy/paste commands in the macro window
    • Added import of email and custom fields for Mateso Password Safe CSV import. Also fixed possible issue with the import due to quote characters
    • Added informative label for Chocolatey install status
    • Added lock screen to RDM
    • Added Mac Address in filter and Advanced search
    • Added minimizing options (taskbar and trayicon visiblity) on application start and close
    • Added missing column in connection grid view
    • Added multi-selection for add-on installation
    • Added new centralized subscription model support
    • Added new option to verify if the user has checked out entries on close
    • Added option to disable autofill on new tab in Chrome embedded
    • Added option to keep the "check if online" window on top
    • Added policy to force Windows username and password
    • Added port to Overview when it is different from the default port
    • Added possibility entry management such as "Delete" and "Move to vault" to the last usage report
    • Added possibility reset user passwords with MySQL/MariaDB data sources
    • Added possibility to "throw" a message with an hyperlink in a custom credential's PowerShell
    • Added possibility to ignore the session type on the duplicate check of a VMWare Synchronizer
    • Added prompt for comment for credentials viewed logs
    • Added Server Start Command setting for SFTP entry
    • Added Session tab name field for SecureCRT
    • Added specific settings for RDP multimonitor/span settings
    • Added support for 256 and true color modes in Terminal
    • Added support for batch RDP reconnect
    • Added support for CJK wide characters in Terminal
    • Added support for proportional fonts in Terminal
    • Added support for rectangle selection in Terminal
    • Added support monitor selection to document types
    • Added the option (permission) to disable the documentation tab on selective entries
    • Added the option to logoff (multi-select or specific) RDP entries from the thumbnails view
    • Added the option to verify the folders on mismatch for AD Synchronizer
    • Added the possibility to add Alternate Hosts field as a column on Dashboard and tab Entries
    • Added the possibility to keep the Navigation Panel Structure in Entry Information Report
    • Added the possibility to sort by column in TS session
    • Added the TAG column in export
    • Added timeout for pwned password checks in case the site is unreachable
    • Added toggle option to preserve formatting on copy in SSH shell
    • Added triple click support for full line selection and corrected some selection bugs and flickering in Terminal
    • Attachments features can no longer be used for ReadOnly users (could previously be attempted but would result in crashes). The Save As button for attachments is now linked to the Allow Export setting inside the attachment
    • Changed pwned password behavior when unable to reach the server
    • Changed the edit rights on logs. Users can now only edit their own logs. Administrators can edit all logs
    • Changed the maximum value for RDP custom width/height to 8192 as it's the Windows 10 maximum
    • Created a "Disable quick connect" policy
    • Deprecated Azure Table Explorer
    • Entry variables in the description will now resolve in the tooltip
    • Excluded version from multivault search
    • Folders now keep their last position when switching repository
    • Implemented VM path in backend for VMware Dashboard
    • Improved Mateso PasswordSafe CSV import
    • Improved query performance of some actions on a database with a large number of connection history rows
    • Improved the display of FreeRDP, VNC, ARD and VNRC
    • Improved the private vault filtering when entry set to "prompt on connection"
    • Improved the sort column in import
    • Improved the VPN glyph in the status bar to select the opened VPN
    • Improved user cancel and connection to DODB and DOD datasource
    • In the password analyzer, Password Strength sorts from weak to perfect and Since sorts from shortest to longest
    • Integration of Viscosity VPN
    • Keep folder structure in entry information report
    • Marked BeyondTrust entry types as deprecated
    • Opening a second WinSCP window in embedded mode will embed it as expected
    • Quick Connect now logs open session in the Activity log
    • Rename Root Settings for Vault Settings
    • Renamed CyberArk AIM to CyberArk AAM (Application Access Manager)
    • Reset layout now also resets the Private Vault
    • SSH Agent forwarding will work even if "use agent" is not specified
    • Starting a session through Quick Connect with the enter key now has priority over the website field in the dashboard
    • Support force refresh in Chrome embedded (Ctrl+F5 and Ctrl+click on the button)
    • Update SecureVNCPlugin to the version distributed by UltraVNC
    • Updated Azure Blog Storage Explorer
    • Updated Bitwarden integration to hopefully fix cipher issue
    • Updated Firefox embedded
    • Updated Wayk integration
    • When opening a session from another repository in the favorites view, the favorites tab will stay opened
    • Added a "create" command in Remote Utilities
    • Fixed "Copy Username/Password" issue when enabling Windows 10 Clipboard History
    • Fixed "Tab page title" option with an HyperV Console entry
    • Fixed "unable to change the current vault with Set-RDMCurrentRepository"
    • Fixed 401 error on DODB cloud access token id expiring
    • Fixed a Clouberry Remote Assistance installation path
    • Fixed a performance problem with the thumbnails
    • Fixed a possible upgrade issue with SQL Server
    • Fixed a potential hang on connection close in SSH
    • Fixed a potential hang when the server issues extended data in SFTP
    • Fixed a potential issue with Lastpass credential
    • Fixed All vaults search. Clear filter and display problem when filter is on top
    • Fixed Alternate host field wasn't emptied when saving with setting disabled
    • Fixed an issue with folder entries to display the correct inherited permissions
    • Fixed an issue with Google Drive
    • Fixed an issue with MySQL/MariaDB change password
    • Fixed an issue with smart Folders sub-connections and "Show sub-connections" unchecked
    • Fixed auto focus item on tab select for favorites tab
    • Fixed bug with iDrac. iDrac now renames the "viewer.jnlp" file if it doesn't end with ".jnlp" to fix known issue with iDrac 6
    • Fixed check out required bypass by using the properties shortcut on a folder (entry selected in Dashboard)
    • Fixed color issue with website entry
    • Fixed entry using bitwarden still opening even if canceled
    • Fixed entry using lastpass still opening even if canceled
    • Fixed error when using file transfer in a Wayk session
    • Fixed for activity log times when in DODB
    • Fixed inconsistency with templates and credentials in VMWare synchronizer
    • Fixed issue creating an AD role in a multi-domain environment
    • Fixed issue doing batch actions in the private vault
    • Fixed issue not using the group tab with website and account entries
    • Fixed issue saving properties of MobaXTerm entry
    • Fixed issue where batch editing credentials on data entries wouldn't work
    • Fixed issue where prompt for comment when credential viewed didn't work
    • Fixed issue where the group dashboard didn't handle the visibility of the clipboard buttons when they didn't respect the check out requirements
    • Fixed issue where the treeview becomes undocked when minimizing the application if it's supposed to go to the trayicon
    • Fixed issue where VPN Add-Ons were visible even if they weren't activated
    • Fixed issue with "required" session recording in entries that don't support it
    • Fixed issue with 1Password (web) returning only the first 200 entries
    • Fixed issue with convert with template
    • Fixed issue with deletion in private vault in offline mode
    • Fixed issue with Keeper saving password
    • Fixed issue with macros in SSH when multiple of the same entry is opened
    • Fixed issue with password analyzer listing main vault entries when you aren't an administrator
    • Fixed issue with private vault in offline mode not saving changes properly
    • Fixed issue with the Last Usage Report editor's information tab not handling the export options properly
    • Fixed issue with unlock in offline mode for SQL Server and MySQL
    • Fixed issue with VPNs not showing the green play button properly
    • Fixed issue with Windows Admin Center not sending the port properly
    • Fixed issues with multivault search allowing actions like checkout and specific settings on entries you don't have the view rights to
    • Fixed issues with the change credential batch edit action
    • Fixed issues with Windows 10 Clipboard History & Copy Username & Password not working
    • Fixed jump host connectionSSH ( host address is now resolved on the jump host)
    • Fixed last line feed gets copied now if selected in Terminal
    • Fixed management tool credential resolving issue when using the credential repository
    • Fixed password manager pro call stack error on wrong host
    • Fixed possible "discover" issue in web browser entries
    • Fixed possible comparison issue when trying to get user from cache
    • Fixed possible crash if loading a vault that has leading spaces
    • Fixed possible crash in SSH Tunnel
    • Fixed possible crash when importing in addons
    • Fixed possible crash with WinSCP
    • Fixed possible issue with 1Password web not being able to fetch from certain accounts
    • Fixed possible performance issue data source contained many users and vaults
    • Fixed possible security flaws with the reconnects / keep tab open on disconnect
    • Fixed RDM export duplicating sub connections
    • Fixed RDP smartreconnect issue that occured when splitting the view between multiple entries
    • Fixed Select in Navigation Pane for Playlists and Advanced Search
    • Fixed some UI for bitwarden duo 2FA
    • Fixed SSH RSA key validation
    • Fixed telnet post login commands
    • Fixed the "Use my RD Gateway credentials for remote computer" option in the RDP Gateway session type
    • Fixed the issue where entries in a playlist wasn't log with the desired account whit "Select Credentials" option
    • Fixed the issue where entries in recent are not shown as their sub entries type
    • Fixed the issue where logs are not shown properly with "Optimize All" in Pack Database
    • Fixed the processing of an escape sequence that caused display errors in Terminal
    • Fixed Typos in Welcome Page
    • Fixed wrong values in OpenVPN and SophosVPN for auth-retry parameter
    • Fixed Zoho vault 2FA double prompt
    • Force us layout to prevent problem when connected to a vmrc server
    • Improved the loading icon in Chrome embedded to be based on the status message update instead of the page loading, as it seems more reliable
    • Minor fixes
    • Possible fix for 1Password not showing the correct vault data
    • Potential fix for the certificate validation freeze
    • Prevent possible Exceptions $DATA_SOURCE_USERPROFILE_*$ variables
    • Reconnect from title bar clears the disconnected status properly
    • Removed the possibility to use different view types in the folder dashboard
    • Removed unnecessary buttons from Playlist (had bugs with data entries anyway)
    • Tried possible fix for F5 Firepass SSL VPN not logging "Open Session"
    • Updated codebase for bitwarden/zoho to fix issue with mobile platforms
    • Updated EssentialObjects to 19.2.30 to fix issue with SaveAs
Remote Desktop Manager 2019.2.21.0
  • VERSION 2019.2.21.0 (December 3rd 2019)
    • Changed the closing procedure of Sophos/OpenVPN entries to make sure every process is killed
    • Improved the KeyAgent integration to support OpenSSH certificates
    • Fixed a bug on HOME and END keys in Terminal
    • Fixed a possible issue with SCP for some Windows Servers
    • Fixed a potential hang or crash on some XTERM directives (OSC, APC, DCS, PM)
    • Fixed custom Macro/Script/Tools missing in the Filter Dialog context menu
    • Reset now also clears the screen in Terminal
Remote Desktop Manager 2019.2.23.0
  • VERSION 2019.2.23.0 (January 7th 2020)
    • Added a non default permission report
    • Added edit permission directly by double clicking the permission summary
    • Added option for "update non-critical fields on mismatch" for Active Directory synchronizer that will update the description if only that field is changed and there is a mismatch action set
    • Added support for remote-controlled window title changing in SSH shell
    • Added support for window title change and icon name change in Terminal
    • Added text search in Terminal
    • Added the option to add VPN routes in batch
    • Allow edit permission directly by double clicking the permission summary
    • Improved multi-account support for DOD, DODB and "My Devolutions Account"
    • Renamed Analytic for Telemetry in options to avoid confusion
    • Fixed a freeze issue with failed recording in SSH
    • Fixed a minor UI issue with the context menu for the connection permission summary
    • Fixed a possible issue with entry text staying bold after disconnect
    • Fixed a Terminal issue with dead keys (accents) that resulted in an extra "D"
    • Fixed an issue with fingerprint check in SSH that uses SFTP for file transfer
    • Fixed an issue with Passportal being unable to connect
    • Fixed an issue with the enter in the grant permission dialog
    • Fixed an issue with the navigation in the report
    • Fixed for after disconnect events being called twice in the case of VPNs
    • Fixed iDrac "viewer.jnlp" file renaming
    • Fixed issue with "prompt for 2FA before going offline"
    • Fixed issue with renaming folders wiping settings while in offline mode
    • Fixed Mouse scroll in Wayk Now sessions
    • Fixed page up/down keys handling in Terminal
    • Fixed permission tab page visible (in the dashboard) when the private vault is selected
    • Fixed quick connect "Auto connect on select template" when citrix netscaler is open
    • Fixed RDS Dashboard not using session credentials
    • Fixed some issues with Key Agent
    • Fixed the issue with KeyAgent not using the passphrase already entered in RDM
    • Fixed to disable the Password analyzer and activity logs when switching to a user that doesn't have rights
    • Fixed UI issue with session recording on new entries
    • Fixed user specific settings from the DPS web interface not updating the Specific Settings column in RDM
    • Fixed user specific settings taking priority on the option Open (select credentials) when using a password list
    • Fixed VPN/SSH/Gateway with custom port and "Connect if unable to ping" making rdm freeze
