Remote Desktop Manager 2020.1.20.0
What's new in Remote Desktop Manager Free 2020.1.20.0:
  • Improvements:
  • Added "Default Information Settings" support for new entries created by DWL
  • Added default Wayk authentication type handling in external session
  • Added option to close macros window after executing + start macro with enter
Remote Desktop Manager Free 2020.2.4.0
  • New Features:
  • Add support for vault image
  • Added Centrify credential type
  • Added Generic CSV Import with field mappings
  • Added Linux inventory report
  • Added Passportal Importer
  • Added possibility to record and download SSH session in native format (.trp)
  • Added SSH key generator ecdsa and ed25519 keys support
  • Added SSH key generator Pkcs1, Pkcs8, OpenSSH or Putty key formats support
  • Added support for SQL Server on AWS
  • Added support for time-based access per user
  • Added the possibility to add a master password to access a vault
  • Vault overview dashboard
  • Improvements:
  • Add mySQL data source in database entry type
  • Added "Delete All From All Vaults" button from entry history
  • Added an option to change the size of the result window when the filter needs to prompt a window
  • Added Chrome to PDF viewer engines and removed DevExpress PDF Viewer
  • Added dashboard layout reset
  • Added IsConnected and IsOffline attributes in the PowerShell module PSDataSource object
  • Added missing content for creating Security Groups in AWS
  • Added new option to automatically flag as closed logs older than the specified amount of days
  • Added option to hide expired notifications if expired for longer than the specified amount of days
  • Added option to remove the count badges in the dashboard
  • Added policy to force password template in password generator tool
  • Added Powershell user object property to show if user has Private Vault
  • Added ReferencedBy to SSH tunnel and port forward
  • Added single cell selection and cell copy in data reports
  • Added SSH rsa-sha2-256 and rsa-sha2-512 algorithms for client authentication
  • Added svg support for connection custom image loaded from disk
  • Added the ability to use keyboard shortcuts in all supported connection lists
  • Added the Equivalent URLs feature to the web browser entry
  • Added the option to open a connection in a specific pane
  • Added the resolving of variables in tab groups when inherited
  • Added wait progress when using CyberArk credential
  • Added Wayk external chat window
  • Allowed admin to ignore forced password template
  • Allowed admin to open or edit a session that is checked out by another user
  • Changed default time based usage settings
  • Changed the Excel export format to xslx
  • Improved Amazon AWS Dashboard
  • Improved events for web site entries
  • Improved the macOS inventory report
  • Improved the SSH key generator with more options
  • Improved two factor "trust this device" feature for LastPass entry
  • Private vault & user-specific changes are now stored in the offline file independent of vault
  • Removed the custom field limits from 5 to unlimited
  • Updated DPS data source to allow RDM authentication token persitence (option) to disk
  • Fixes:
  • Disabled the Duplicate Connection button when the connection has session recording configured on it
  • Fixed administration logs display issues when exported in csv in foreign languages
  • Fixed an issue with the "Save As" in report
  • Fixed blank vault in activity logs when the vault is deleted
  • Fixed command line export for activity Log report
  • Fixed DOD offline not working properly without internet connection
  • Fixed issue when sending password containing "^" to SSMS
  • Fixed issue where forced password template setting could be bypassed by using a password complexity then using the password generator
  • Fixed issue with useless offline password prompt when opening options
  • Fixed moving folders always going back to the top of the tree
  • Fixed possible bug where the offline file sometimes gets deleted when toggling between two data sources
  • Fixed RDM extension manager that doesn't detect browser extension installations that aren't in the default browser profile in Chrome/Firefox/Edge
  • Fixed RDM freeze when unlocking with opened undocked sessions
  • Fixed SCP directory copy and added moving remote folders
  • Fixed synchronizers not working when starting from command line
  • Fixed tab key not usable in Wayk remote session
  • Fixed the command execution in SCP and SFTP
  • Fixed variable resolving in the HTTP Browser linker when $CURRENT_CLIPBOARD$ was used in URLs
  • Resurect entry now also includes attachments
Remote Desktop Manager Free 2020.2.12.0
What's new in Remote Desktop Manager Free 2020.2.12.0
June 8, 2020
  • New features:
  • Improvements:
  • Added a custom installation path setting to the Checkpoint Smart Console addon
  • Added a customizable delay to the smart reconnect when logging on an rdp entry
  • Added access to the comment and the ticket number in before open connection powershell ($RDM)
  • Added batch edit for the "More custom fields"
  • Added certificate prompt diagnostic feature
  • Added clipboard Diagnostic
  • Added default action to information entry type
  • Added DirectX hardward acceleration support
  • Added Domain support to ShrewSoft VPN
  • Added global option for RDP authentication level
  • Added logs for remote commands (including inventory report)
  • Added options in advanced search to show sub-connections and parent connections
  • Added password generator to these types of entries : Host - FTP - FTP (third party) - SCP - SFTP - Telnet
  • Added possibility to "Change ID" when importing sessions
  • Added Secure Gateway support for SSH
  • Added Secure Gateway support RDP external mode
  • Added settings validation and better error handling to the OTP entry
  • Added support for copy from remote application in Terminal
  • Added support for using existing OTP entries in OpenVPN (and SophosVPN)
  • Added the domain_controller variable
  • Added the equivalent urls in dashboard overview for website entry types
  • Added the option "Move to current display" in the taskbar options
  • Added the option to link an existing OTP entry in a Website entry
  • Added the Proxy and Jumphost tabs to SSH tunnel and SSH port forward entries
  • Added 'Use over secure gateway' checkbox during batch edit
  • Improved performances for the password analyzer when exporting
  • Improved S3 credentials support
  • Improved secure gateway for Firefox and Chrome embedded entry
  • Improved Terminal buttons and scroll wheel management
  • Improved the port forward overview
  • Improved the Terminal performance
  • Improved TheGreenBow VPN to close specific tunnel related to entry rather than stop the VPN application altogether
  • Possible fix for Intel AMT timeout
  • Prevent RDM closing when opening an .RDD file with it
  • Fixes:
  • Fixed an export issue when using the filter with the navigation pane unpinned
  • Fixed carriage return in public key from SSH key generator
  • Fixed Checkpoint smart console not using the default installation path when the custom one doesn't exist
  • Fixed connection status showing "Locked" instead of "Not connected" in certain login conditions
  • Fixed edit password template not deleting the old template
  • Fixed issue where a data source folder would be created in the local app data at every RDM launch
  • Fixed issue where copying HeidiSQL connection's username and password reported an error "Nothing to copy to the clipboard
  • Fixed issue where error messages would lock the UI in a VMRC session when RDM is minimized
  • Fixed issue where getting an error message in a VMRC would reveal the ribbon buttons while the application is locked
  • Fixed issue with certificate errors and authentication in iDRAC entry
  • Fixed issue with documents stored in database
  • Fixed issue with offline mode refresh showing connections without view rights in the tree
  • Fixed multiselect in VMWare console dashboard
  • Fixed OpenVPN simultaneous connections not working properly in certain cases
  • Fixed possible crash in Chrome with autofill
  • Fixed protocol handler filter when using quotes
  • Fixed runas with custom credentials for command line and powershell entries that use credentials from the credential repository
  • Fixed some memory leak in FreeRDP, ARD, VNC and VMRC
  • Fixed stuck keys on remote machine with Alt-Tab with Wayk embedded
  • Fixed Terminal and double click and triple click now work as expected when overriding with shift in alternate screen applications
  • Fixed the "Open entry on template list only" option. Now only allows the entry creation if there's a corresponding template
  • Fixed TheGreenBow VPN config import error on first use
  • Fixed VPN link not resolving credentials
Remote Desktop Manager 2020.2.13.0
What's new in Remote Desktop Manager Free 2020.2.13.0
June 12, 2020
  • Improvements:
  • Added model information to Referenced By on dashboard
  • Added possibility to view OTP in view password
  • Added the custom DNS server field to the folder entry (only for types that support variables) along with the $CUSTOM_DNS_SERVER$ variable
  • Improved Tab Group entry editing
  • Fixed:
  • Fixed a bug where the option "Connect if unable to ping/scan" wouldn't ping the target when connecting via a jump host
  • Fixed inventory report null reference exception
  • Fixed issue saving "keep template name on use" checkbox in the template settings
  • Fixed potential Cisco Anyconnect issue by switching from .NET SendKeys to our own sendkey implementation
  • Fixed potential errors when trying to verify the status of browser extensions
  • Fixed Quick bar not keeping its position
  • Fixed some csv export issues in foreign languages (mainly Ukrainian)
  • Fixed the "Move" action when executed outside of the main connection view
  • Fixed the "View" tab of the documentation not handling line-breaks and tabs
Remote Desktop Manager 2020.2.14.0
June 16, 2020
  • Improvements:
  • Added custom fields to the dashboard Overview
  • Added CustomField support for url protocol handler
  • Added SSH Agent support ofr RSA SHA2 signing algorithms
  • Improved backups to save and restore the vault settings
  • Improved error handling of bad data in offline file (force expired)
  • Fixed:
  • Fixed a "clear screen" problem in Terminal
  • Fixed cursor in sidebar allowed click on a second monitor in Wayk
  • Fixed custom fields and entry information not saving properly in certain connection types
  • Fixed custom fields not saving properly in folders
  • Fixed potential crash in tab groups
  • Fixed Proxy Network gateway combobox not being filled
  • Fixed Readonly state to permit copy paste of notes
Remote Desktop Manager 2020.2.15.0
What's new in Remote Desktop Manager Free 2020.2.15.0
June 23, 2020
  • IMPROVEMENTS:
  • Deprecated Intel AMT
  • Added wait progress to cleanup entry history and deleted history
  • Improved CSV Import for Data entries
  • Made the email address in the contact session's dashboard clickable
  • Updated the Rebex components
  • FIXES:
  • Fixed documentation hard to read when using Dark Gray theme
  • Fixed possible freeze when changing display in Wayk
  • Fixed Web browser basic authentication not working with certain username formats
  • It's now possible to send ALT + ENTER in Terminal
Remote Desktop Manager 2020.2.16.0
  • VERSION 2020.2.16.0 (July 7th 2020)
    • Accelerated scrolling while selecting in Terminal
    • Added an option to render html in plain text for secure note
    • Added configurable delay for VPN setting "Go online on disconnect"
    • Added Inspect option (dev mode) for embedded Chrome browser
    • Added more debug logs when migrating the data
    • Added option to change the server type in SFTP and SCP
    • Added regex to advanced search
    • Added support for customizable Advanced UI menus
    • Added support for entries in folders with variables for DWL
    • Added support for multiple Wayk Den connections
    • Added the possibility to customize the default entry image color
    • Added the support for every URL matching type in DWL
    • Allow users to automate data source creation via .cfg using simple Base64 encoding
    • Improved detection of involuntary disconnections in Terminal
    • Improved display performance and improved resizing look and feel in Terminal
    • Improved integrate of Wayk Den & Wayk Now authentication
    • Improved scroll wheel support in Terminal
    • Improved View Password with Domain and OTP fields to only appear if value isn't empty
    • Modified the "Last modified" column in the password usage report to properly reflect the password status instead of the entire entry
    • Resolved possible issue with "Remove Duplicates" in Data Source Diagnostic > Duplicate Folders
    • Simplified Wayk connection mode settings
    • Updated AWS library and added new regions
    • Fixed a bug where opening a vpn linked to a session in "manual" mode would prevent the actual session to also be opened
    • Fixed a few issues introduced with the recent changes made to the "Run as" credentials in command line sessions
    • Fixed a possible RDM focus lost issue when opening a dialog
    • Fixed alt + double click crash in Terminal
    • Fixed an access denied error when executing a macro on an opened session
    • Fixed an issue where batch edit while offline clears the properties of entries
    • Fixed downloading folder with native SCP
    • Fixed GDI leaks in VNC, VMRC and Wayk caused by cursor changes
    • Fixed issue where a document "Stored in database" would stop the duplication of a folder
    • Fixed issue with the "Duplicate" action not being visible on a folder when there is only a document stored in database inside the folder
    • Fixed multiple prompt from after connect macro
    • Fixed RunAs from credential repository in command line session not enabled on RDM Free
    • Fixed sessions not opening with return key in the filter prompt dialog
Remote Desktop Manager 2020.2.17.0
What's new in Remote Desktop Manager Enterprise Edition 2020.2.17.0
July 20, 2020
  • Improvements:
  • Added a global option for the terminal log path
  • Added Datacenter specific Sync to VMWare Sync
  • Added duplicate removal to diagnostic for DPS data source
  • Added export check specific to Certificates
  • Added file progress to Amazon S3
  • Added option to change the scroll wheel behavior in SSH terminal
  • Added OTP refresh in the "View Password" window
  • Added Passportal in My Account Settings to allow users to specify their own credentials
  • Added Policy to disable sessions events
  • Added possibility to import sessions from a Bitwarden CSV
  • Added possibility to remove confirmation prompt on parameters for Cmd (External application)
  • Added Template Group name change on Copy To
  • Enable use of $USER_PRINCIPAL_NAME$ in DPS data source configuration
  • Improved Csv Generic importer connection type resolution
  • Improved file protection for Csv importers
  • Improved Wayk Den dashboard to group machines
  • Removed possibility to use PAM in a local specific setting credential override
  • Resolved possible timeout issue when creating an Azure SQL database
  • Fixes:
  • Fixed an issue with PassPortal
  • Fixed an issue with TigerVNC
  • Fixed crash when selecting custom image for vault
  • Fixed custom installers saving the Lucid refresh tokens even if the Devolutions Accounts credentials isn't checked
  • Fixed html editor logging an "Updated entry" when viewing properties
  • Fixed Invoke-RDMParentSession cmdlet that was not removing the child session from its original location
  • Fixed issue clearing VPN username and domain when exporting without including credentials
  • Fixed issue in FortiClient when sending the port
  • Fixed issue using an alternate host with a port for SSH Shell, SSH Tunnel, Portforward and Telnet entries
  • Fixed issue where some "Tools" menu buttons would not appear when the "Disable Help" policy was activated
  • Fixed issue where you were prompted to add a value on save even when "Always prompt for value" was checked
  • Fixed issue with CyberArk credential where special characters weren't used properly
  • Fixed issue with KeePass detection not working properly when a database is specified
  • Fixed issue with local session recording for SSH entries if the recording format was set to WEBM
  • Fixed issue with variable resolving in groups when using special characters
  • Fixed issues editing password templates in DPS datasource
  • Fixed macro script tools preparing connections multiple time in external mode
  • Fixed multiple fields not being saved in login account entry and added possibility for infinite web custom fields in login account entry
  • Fixed possible crash in remote printer window
  • Fixed self-hosted Bitwarden freeze when the certificate is invalid
  • Fixed settings from the "Template Settings" tab appearing in the search result even if the tab wasn't visible
  • Fixed Shrewsoft VPN sending wrong parameter
  • Fixed Terminal print output logging to avoid UI freeze when log file is remote (slow)
  • Fixed the force MFA GPO allowing an invalid Yubikey to be entered
  • Fixed username format not taken into account in Firefox Web browsers
  • Fixed viewing entry properties also logging an update when the editor contains a SyntaxEditor
  • Fixed Web Browser sessions that cannot be used by DWL if credentials in them are "My Personal Credential"
  • Fixed web custom field value prompt not accepting more than 3 values
  • Fixed WebBrowser and Website imports using Generic Csv Importer
  • Fixed website being opened when selected from other tabs
  • Resolved possible issue where no connections where displayed when offline
Remote Desktop Manager 2020.2.18.0
What's new in Remote Desktop Manager Free 2020.2.18.0
August 5, 2020
  • Improvements:
  • Added better error handling for SSH Shell, SSH Tunnel, Port forward, Telnet and Serial entries
  • Added Exit menu to Windows taskbar
  • Added support for the numlock key in Terminal (function keys modes VT400 and Linux)
  • Added warning for Type Clipboard feature when the clipboard exceeds a certain amount of characters
  • Added Wayk embedded connection without access control
  • Improved host detection in CSV import
  • Improved restore layout behavior to fix issue with "use tabstrip overflow" option
  • Improved schema validation check with SQL Server, MySQL & MariaDB data sources
  • Improved the ARD performance settings labels
  • Improved the rendering performance for ARD and VNC
  • Improved Wayk rendering performance
  • Modified the paste algorithm in Terminal and also added a Paste Delay property
  • Moved CSV imports to sub-menu
  • Prevent possible crash when loading XML data source
  • Resolve zoom and scale issues with Wayk session
  • Small optimization for the loading of data sources when creating a custom installer package
  • Fixes:
  • Fixed a bug when the recorded session is bigger than the player's size in Terminal
  • Fixed alternate host getting prompt multiple times
  • Fixed column saving and reset for Favorites and Private Vault
  • Fixed Firefox now showing URL when selected to do so
  • Fixed inventory report issue where the selected options weren't taken into account
  • Fixed issue bringing RDM back to front with tray icon
  • Fixed issue saving the "mask the password" check box state in the View Password window
  • Fixed issue where reselecting the same import type would clear the grid view
  • Fixed issue with inventory report dates
  • Fixed issue with new XML, Google Drive, FTP and SFTP data sources giving a Not Connected status
  • Fixed issue with possible loss of the saved App Password with a DOD or DODB data source
  • Fixed issue with terminal playback (.TRP) on shared drives
  • Fixed Linux inventory report with some OS
  • Fixed looped credentials issue and set auto refresh timer to 5 sec
  • Fixed missing behaviors on Remote Registry
  • Fixed multiple issues with File Explorer entry
  • Fixed multiple UI issues with templates
  • Fixed possible crash in FreeRDP
  • Fixed possible crash in registry editor
  • Fixed possible performance issue with non-admin users when using security groups
  • Fixed potential null reference exception when moving entries
  • Fixed tab selection on opening window
  • Fixed VMWare sync error when selecting specific data center
Remote Desktop Manager Free 2020.3.13.0
What's new in Remote Desktop Manager Free 2020.3.13.0
October 30, 2020
  • Added option to stop saving the value of "mask the password" in the View Password window
  • Allowed port knock on any entry with the event tab
  • Improved smart reconnect on RDP 8.1 by resizing instead of reconnecting
  • Simplified Splashtop mac address handling to avoid errors with certain characters
  • Fixed an exception in ARD multi-monitors
  • Fixed ARD resizing issues
  • Fixed black screen and connection issues with VMRC
  • Fixed issue when saving a Text Editor entry
  • Fixed issue with LINKED_OWNER variables not resolving properly
  • Fixed possible crash in Chrome embedded
Remote Desktop Manager 2020.3.16.0
  • Version 2020.3.16.0 (November 10th 2020)
    • Added "check host uptime" session tool available in the dashboard
    • Added "Show Statistics" button to ping window when doing continuous ping
    • Added browsing button to OTP selection for entries
    • Added custom sorting order to Other (Custom) information type
    • Added double click handling to Hyper-V
    • Added Max width setting for tab pages
    • Added new default path for VMConnect.exe
    • Added Next and Previous button to navigate the entry history compare
    • Added session recording for Telnet
    • Added SSH algorithm support to port forward and SSH tunnel
    • Added tenant database support to SAP Hana add on
    • Changed how logs are shown in SSH Tunnel and Port Forward entries to help performance
    • Changed resolving order of Option and System Settings custom variables so that the Option ones are resolved first
    • Improved logging when using the Password History
    • Improved logging with the OTP entry
    • Improved SSH algorithm support error message
    • Improved tray icon context menu load time
    • Merged "prompt on password revealed" with "prompt on credentials viewed"
    • Multiple performance improvements
    • Fixed an issue causing a not connected state on DPS when starting a session from the command line
    • Fixed an issue with the Gravatar
    • Fixed crash in port knock when using UDP
    • Fixed Dashlane csv import
    • Fixed entry editors when creating in Hub data source
    • Fixed entry history showing the date/time in UTC format instead of local
    • Fixed issue with the Key Agent not working
    • Fixed resize and multiple monitor support in ARD
    • Fixed small UI issues for Temporary Access windows
    • Fixed translation issues in the security provider
    • Fixed variable issue when opening server home page
