Remote Desktop Manager 2020.3.17.0
November 15, 2020
  • Improvements:
  • Added a new dashboard warning when using an SQLite data source over a network drive
  • Added Pwned Password check state in data source info
  • Enabled the general settings batch edit for data entries
  • Improved sent telemetry information
  • In OpenVPN and SophosVPN, automatically check "use auth" if "enable automatic authentication" is also checked
  • Minor UI fixes and improvements
  • Removed the application restore when opening an undocked session from the system tray
  • Restored "use auth" checkbox in OpenVPN and SophosVPN
  • Updated download link to ffmpeg
  • Fixes:
  • Fixed issue not prompting for the comment in RD gateway credentials
  • Fixed issue when you renamed a folder but entry names with variables were not refreshed
  • Fixed prefix combobox duplicating its content when saving settings
Remote Desktop Manager Free 2020.3.20.0
  • Version 2020.3.20.0 (December 10th 2020)
    • Added support for PowerShell 7 in PowerShell session type
    • Added "role" section in password lists for MySQL and MariaDB data sources
    • Added Hub Business template support
    • Added support for cursor in ARD
    • Added support Max Reconnect Attempts in RDP
    • Added the logs tab to document entries
    • Changed Google Drive login flow to use an external browser instead of an embedded one
    • Improved port knock feature using our native protocols
    • Resolved some possible issues with "auto go offline"
    • RoyalTS importer now imports secure gateways and the port of every entry
    • Disabled certain buttons when RDM license is expired
    • Fixed a null reference when exporting a passwordList to xlsx
    • Fixed an issue with the default installation path in RDM64
    • Fixed ARD Clipboard.GetText failing and added additional logs to sessions
    • Fixed back the context menu to grids for the Security Management in order to enable export features
    • Fixed behavior for clearing filters
    • Fixed clear filter labels and added new filter options
    • Fixed copy password to clipboard for Hub Business
    • Fixed copy password to clipboard for Hub Personal
    • Fixed crash in Other information entry
    • Fixed HttpBrowserLinker that is slow with variable resolving when the vault has a lot of websites
    • Fixed issue saving HashiCorp Vault My Account Settings
    • Fixed issue when exporting to CSV and containing separator characters
    • Fixed issue where assigning users permission didn't grant proper database level permissions making the permission unusable
    • Fixed issue where multiple menus wouldn't show the proper shortcuts
    • Fixed issue where the Centrify credential entry wouldn't show all your accounts
    • Fixed issue where the synchronizers would delete all their entries if the mismatch action is "Delete" and the connection fails
    • Fixed issue where you couldn't edit de PasswordControlId of a web entry when using the custom PowerShell command special action
    • Fixed issue with variables not being resolved in Key Agent Manager
    • Fixed issue with Wayk quick connect not working
    • Fixed load temporary accesses in dashboard only if data source is ready
    • Fixed New-RDMUser cmdlet in the PowerShell module where the -Password switch was missing when using built-in authentication type
    • Fixed null references related to html export
    • Fixed possible crash in Chrome embedded
    • Fixed quick connect for ARD
    • Fixed small issue with tags when exporting to xlsx
    • Fixed UI issues with RDP entry when choosing a "file" mode
    • Fixed view-only VNC and ARD connections and fixed VNC connections to macOS
    • Possible fix for issue with line skips in terminal
    • Use the wait progress setting to show the DVLS authentication wait progress
Remote Desktop Manager Free 2020.3.21.0
December 14, 2020
  • Fixed an issue where the navigation pane was lost on application startup
  • Fixed invalid calling convention for ARD cursor callbacks in 32bit
  • Fixed issue with the navigation panel passing from "auto hide" to "dock" when selecting a session
  • Fixed issues in the installation paths
  • Fixed issues with the treeview's session menu showing the wrong keyboard shortcuts
  • Fixed possible null exception error for ARD with the monitors
Remote Desktop Manager Free 2020.3.23.0
Version 2020.3.23.0 (December 15th 2020)
  • Fixed copy password in Hub Business User Vault for password list
  • Fixed null reference when assigning shortcuts
  • Version 2020.3.22.0 (December 15th 2020)
    • Added a profiler log to try to find why a user is having performance issue in filter
    • Fixed dashboard expiration text
    • Fixed issue with Enter shortcut causing issues
    • Fixed password history multiple prompt in Hub (Business & Personal) with Password List
    • Fixed possible crash in Most Recently Used when using Hub data source
Remote Desktop Manager Free 2020.3.24.0
  • VERSION 2020.3.24.0 (January 6th 2021)
    • Fixed SonicWall VPN password appearing in clear text in the logs if it contains URL encoded character
    • Added a Trim starting/trailing whitespace characters when saving an entry
    • Added an option to disable the "client" mode for OpenVPN/SophosVPN
    • Added override default executable to WatchGuardMobileVPN
    • Fixed a possible crash in embedded Chrome autofill
    • Fixed issue where duplicating an "Information" entry's sub connections would edit the connection instead
    • Fixed issue where the credentials wouldn't be resolved in the after open Typing Macro event
    • Fixed issue where the typing macro of the "Events" tab of an entry wouldn't be usable if it was a "Linked" typing macro
    • Fixed issue with "force show navigation pane on startup" option not working
    • Fixed issue with certain links opening as "about:blank#blocked" intead of loading properly
    • Fixed issue with embedded Chrome session recording sometimes freezing the application
    • Fixed view-only in VNC not working
Remote Desktop Manager Free 2020.3.25.0
  • VERSION 2020.3.25.0 (January 12th 2021)
    • Improved SSMS add-on functionality when using legacy (17 and older) and modern (18 and more recent) versions
    • Fixed Google Drive possible null reference exceptions
    • Fixed some memory leaks
Remote Desktop Manager Free 2020.3.26.0
  • VERSION 2020.3.26.0 (January 19th 2021)
    • Fixed an issue when resetting the layout causing the navigation pane to disappear
    • Fixed GDI leaks in VNC
    • Fixed multiple potential memory leaks everywhere in the application
    • Fixed possible crash when going online
    • Fixed some possible issues with Ctrl+Alt+Del in embedded RDP
    • Improved clipboard reliability for Wayk sessions
Remote Desktop Manager Free 2020.3.27.0
January 26, 2021
  • Improvements:
  • Added low bandwidth connection options in Wayk
  • Added the OS Architecture in the error report
  • Allow user interaction when connecting to a Wayk session
  • Updated Devolutions Protocols to latest version to fix issue with function keys
  • Fixes:
  • Fixed issue sending Ctrl-Alt-Del in RDP when set to "on remote computer" keyboard hook
  • Fixed issue with file explorers creating many temporary files
  • Fixed possible crash in Chrome protocol handler
  • Fixed possible crash in Sophos Connect Client if no authentication type is selected
  • Fixed possible crash when opening Clipboard Diagnostic form
  • Fixed segmentation fault when remote resolution change in Wayk
  • Fixed Send Ctrl+Alt+Delete not working in FreeRDP
  • Fixed UI for Netop Guest add-on
Remote Desktop Manager Free 2020.3.29.0
February 10, 2021
  • Improvements:
  • Updated embedded Chrome
  • Fixes:
  • Fixed an issue where the application would remain non responding after the PC was in hibernation for a short time
  • Fixed arrow key behavior when switching embedded Wayk tabs
  • Fixed deadlock caused by HTTP calls waiting for verify certificate prompt
  • Fixed issue with refresh hosts button in the Hub credential entry's settings
  • Fixed memory leaks in recording and thumbnails
Remote Desktop Manager Free 2021.1.11.0
March 10, 2021
  • New:
  • Added Secure Desktop for masterkey prompts
  • Added support for embedded Microsoft Edge (Chromium)
  • Added support for Microsoft L2TP VPN
  • Added support for Smartcard authentication in SSH Shell, SSH Tunnel and SSH Port forward entries
  • Added the Door Codes information type entry
  • Major security improvement with the Devolutions Web Login integration
  • Updated the Azure Key Vault entry to support the new API
  • We now encrypt the local license information in the configuration file
  • Deprecated Citrix ICA/HDX
  • Deprecated embedded credential source
  • Added restrictions so that the credentials in the web browser entries couldn't be accessed if you aren't connected to the entry's vault
  • Added an expiration timeout to the credential auto fill feature of web browser and website entries
  • Added Secure Command mode to PowerShell and PowerShell remote console
  • Added "custom" option to the unselected tab color setting, and moved the setting to the Tab Bar section of the options
  • Added "Select Vault" button to the favorites View
  • Added a "copy link to page" function to documentation pages
  • Added a setting "Apply Default RDM options when launching external RDP files"
  • Added a zoom option to embedded/undocked RDP sessions
  • Added an option in View Password (Show password hints) to highlight numbers and special chars
  • Added an option to disable the close button in undocked mode
  • Added FOLDER_??? variables
  • Added hiding actions panel to all dashboards currently with context menu
  • Added Hub Personal documentation support
  • Added increment number name format option when duplicating entries
  • Added multiple file transfers in Wayk sessions
  • Added old password count (more than a year) in password analyzer
  • Added option in SSH Shell to accept server resize requests in undocked mode
  • Added option to hide local license information in the UI
  • Added option to keep View Password window on top
  • Added possibility to override the monitor selection in the User/Local specific settings
  • Added PSM types in New-RDMSession
  • Added recovery codes to OTPs
  • Added sound quality in RDP
  • Added SSH Gateway to SCP and SFTP entries
  • Added support for local web cam in RDP
  • Added support for local webcam redirect through RDP
  • Added support for multiple SSH gateways in the SSH Shell entry
  • Added syntax highlight in the markdown editor
  • Added System and Options settings to change default name of root
  • Added the possibility to view the root history
  • Added the sound quality option to RDP entries
  • Added view OTP and copy OTP buttons in the dashboard, home menu and contextual menu
  • Added warning when pasting multiple lines in SSH and Telnet terminals
  • Changed the default value to "Include folders" in search filter
  • Changed the password font to Consolas to improve visibility
  • Changed update window to not block the application
  • Deprecated GoToAssist
  • Implemented offline mode in read-only for Hub Business
  • Improved data source disconnect with "Go into offline mode if available when disconnecting" and "Automatically reconnect on activity"
  • Improved OTP user interface
  • Improved the documentation editor
  • Improved the Keeper integration
  • Increased maximal offline cache expiration configurable to 180 days
  • Removed mandatory template from CyberArk PSM server entry
  • Reworked OneDrive login with proper OAuth flow and added my account settings
  • Trim starting/trailing whitespace characters when saving an entry
  • Fixed:
  • Fixed $DYNAMIC_PORT$ port variable not resolved correctly for Web Browser entries
  • Fixed $USERNAME$ variable not working in session recording filename when not in custom mode
  • Fixed an issue causing an empty favorites list in Pleasant Password server
  • Fixed an issue causing some variables to not be resolved in the session recording filename
  • Fixed an issue causing the password in the Tools custom credentials to stay revealed after reloading the window
  • Fixed an issue causing VMWare sessions to not use the same group tab as the VMWare console
  • Fixed an issue causing Wayk recording session files to be wrongly named
  • Fixed an issue preventing the template's port to be used when using the template through a macro
  • Fixed an issue with the VMware Dashboard where the user/local specific credentials wouldn't apply correctly
  • Fixed and improved the "Convert PuTTY to PuTTY embedded" action
  • Fixed expired report displaying incorrect data entries
  • Fixed import of VNC, Web browser and VMWare subtype in CSV importer
  • Fixed issue creating entries when DODB has no user vault
  • Fixed issue saving private key information in SSH gateway
  • Fixed issue seeing main vault when the user has no cache enabled
  • Fixed issue when sending $PASSWORD$ variable in macros, and improved clarity on system settings relating to sending the password variables
  • Fixed issue where closing a session in the keep tab opened on disconnect would not update the last opened playlist
  • Fixed issue where converting a web browser to website or website to web browser would lose the entry's OTP settings
  • Fixed issue where multiple gateways weren't taken into account
  • Fixed issue where the navigation tree view would not hide itself when clicking inside an embedded entry if the visibility is set to "Auto Hide"
  • Fixed issue with SSH Gateway not prompting for password when configured to prompt
  • Fixed multiple issues with CSV Import/Export. Also added multiple features and import possibilities to make the generic CSV import more useful
  • Fixed multiple issues with playlist management window
  • Fixed null reference when executing a macro without a linked connection
  • Fixed playlist name when duplicating
  • Fixed possible issue with connection history compare displaying blank right pane
  • Fixed renewal dates notifications not showing for sub-connections
  • Fixed SFTP not working on SSH sessions when connecting via a jump host
  • Fixed sorting in VMware dashboard
  • Fixed temporary access report not sorted by date
  • Fixed the Http browser linker that wouldn't get shared vault's websites when focusing the user vault
  • Fixed Wayk remote executions
