DziadDalf
cFosSpeed 10.51 build 2342
x Fixed "nsclear" and "ns -clear" commands: number of total/max TCP & UDP
sessions wasn't properly cleared.
x Current connections dialog would not start. Fixed. This bug was introduced
in beta 2341.
cFosSpeed 10.51 build 2341
- Updated prioritization list (settings.ini).
DziadDalf
cFosSpeed 10.51 build 2344
x Link speeds were sometimes not properly initialized. Fixed.
x Route finding trace output had double time stamps. Fixed.
- Removed WMI and keyboard LED support. All variables / values are available
via our built-in web server.
DziadDalf
cFosSpeed 10.51 build 2348
* If there exist several routes to the Internet simultaneously, cFosSpeed can
now use all of them for Traffic Shaping. This is especially useful if you
have a balancing setup, e.g., one LAN adapter and one mobile adapter in use
at the same time.
* Added "spd flush_usage_logs". Speeded "spd flush".
+ To save processing power, the cFosSpeed service now uses routing / address /
interface change notifications to monitor route changes instead of a
periodic timer.
+ Optimized handling of how used programs are tracked and stored. It is now
faster and more consistent.
+ Used tech from cFos Personal Net to make the internal Webserver of the
cFosSpeed service more responsive.
+ Added -json and -raw options to "spd ports" and "spd speed_info".
+ "spd pcnt" will only work if new flag global_counters is set to 1. Enable
with "spd gset global_counters 1".
+ Added time to "X" type line of metadata dump. This line is printed when a
TCP or UDP connection is killed.
x Fixed a Unicode encoding bug in JSON output.
x Fixed a bug where the cFosSpeed status window would not regard the position
of the system taskbar with auto-arrange. Thanks to George H.
- Removed the option to disable the taskbar icon. You can use the Windows
taskbar configuration dialog to hide the taskbar icon if you want.
- Added more common programs to the prioritization list (settings.ini). Thank
you for all your program suggestions!
Mohammad.Poorya
19 Wrzesień 2018
On a Bike!
cFosSpeed 10.51 Build 2349 Beta
Changes in 10.51 Build 2349 Beta:
  • Added a new API to get current connections info, which is 20(!) times faster than the old one.
  • The current connections dialog now displays a CPS history of the last 15 secs. It uses our new API.
  • Reduced the time the window reacts in "click-through auto" from 4 to 3 seconds.
Download | Beta -
DziadDalf
cFosSpeed 10.51 build 2352
+ For click-through-auto mode, you can now configure the time needed to switch
off click-through (the time you need to hover the mouse pointer over the
cFosSpeed window). To change that time, set the key
click_through_time=<secs>
in file %LOCALAPPDATA%\cfos\cfosspeed\user_data.ini, section [All]. Default
is 3 secs. Thanks to leon479959891 for the suggestion.
x Hopefully fixed sporadic freeze that was introduced in beta 2350.
- Support for Windows 19H2, November 2019 Update.
DziadDalf
cFosSpeed 10.51 build 2353
+ The advanced current connections dialogs now also uses the new, faster
API. Connections are now prioritized with regard to the network adapter
if multiple adapters are in use. Thanks to MSI for the suggestion.
