DziadDalf
FosSpeed 10.21 build 2287
+ Added curr_max_rx and _tx variables that hold the current line speed, in
contrast to maxrx, maxtxacked and maxtxraw that hold the maximum speeds
ever achieved. These variables are also available for skins and WMI as
curr_rx_scale and curr_tx_scale.
- Changed avg_time settings: 2 sec for the PPPoE/A, PPTP, AAL5 and VDSL modes,
4 sec for all others, including adaptive. This setting is the minimum
time for speed measurements to calculate max speeds, so it evens out spikes
in traffic speed.
x Fixed a possible CPU hog in the cFosSpeed service if adapters had empty
names.
DziadDalf
cFosSpeed 10.21 build 2288
+ The Metro skin now has a button in the right lower corner to toggle the
current speed variables and the new current max speed variables. So you
always can check what speed your connection achieved recently.
x Fixed empty values in usage graph, thanks to Stef.
x Fixed help links in settings dialogs.
DziadDalf
cFosSpeed 10.25 build 2310
x Fixed a bug where cFosSpeed LAN port would appear and disappear every
minute or so. Thanks to stdedos.
x The link speed of the network adapter is now always the current link speed,
instead of the maximum link speed.
- Switched to latest compiler.
DziadDalf
cFosSpeed 10.27 build 2320
* Added installer checkbox to allow us to occasionally (max. once a year!)
collect some anonymous meta data from your connections (we clear out your IP
address). This is to help us develop a new and improved form of traffic
class detection. Please switch it on, we need real live traffic data to
develop this new feature.
For a detailed list of collected data, see
+ Added new games / programs to the program prioritization settings.
Thanks all for your suggestions!
+ Added L7 detection of certain QUIC packets.
+ Improved evaluation of the User-Agent string for the L7 protocol detection.
+ The L7 protocol data field now contains the HTTP Host header field in
addition to the Content-Type.
+ Improved "spd ports" display.
x Fixed a spurious problem with opening the browser. Thanks to Stefan
Waldmann for bug report.
x Fixed detection of IPv6 address of router.
x When using "spd cons" or the advanced connection overview, the sorting will
now sort TCP and UDP connections together.
x Fixed detecion of UDP protocols.
- Traffic Shaping setting is now by default "not cooperative" owing to the
fact that usually there are other non-cFosSpeed clients on the LAN as well
(smartphones, consoles, etc.)
DziadDalf
cFosSpeed 10.27 build 2322
+ Added new TCP counter in "spd netstat": Data segments. This will only be
increased if the segment is non ACK-only. It now allows for a more
accurate calculation of resent percentage.
x More fixes for broken reporting.
x Fixed meta data dump that was almost never dumping.
DziadDalf
cFosSpeed 10.27 build 2323
+ When using "spd tcb" command you can now add a wildcard to specify which
connection to display, like "spd tcb 8.*:80" or "spd tcb 8.*:*".
x Fixed an old bug that could have lead to erroneous detection or rejection
of RST segments in cFosSpeed.
