Process Lasso / Process Lasso Pro Beta
Status
Zamknięty.
Process Lasso 9.8.0.25 BETA
9.8 beta:
Highlights:
- New CPU core utilization graph, split into NUMA nodes, that supports multiple processor groups
- Improve foreground process awareness with Governor-As-Service
- Additional fixes and enhancements (see details)
Details:
(25) GUI: Cosmetic to application power profiles configuration dialog
(25) GUI: IdleSaver config dialog: when enabled for first time, set default idle time of 15 seconds
(25) GUI: Change application power profile and High Perf mode browse button to select only basename
(23) Updater: Enhance integrity checks
(21) GUI: Update Russian and French
(21) GUI: Have core performance counters poll at configured GUI refresh speed
(21) Core: Adjust handling when pathname of a process isn't immediately available
(19) GUI: Process context menu item 'Induce Performance Mode' now adds basename to list instead of pathname
(19) GUI/Core: Fix to /configfolder command line argument
(19) All: Internal refactoring surrounding log and config path over-rides
(17) GUI: Add setting disable progress bar themes in new 'View / Performance' submenu
(17) GUI: Change icon on 'Restart Process Lasso' message box
(9) GUI: Improve behavior when graph is too narrow to display CPU core utilization and/or RAM load
(7) GUI: New CPU core utilization graph, split into NUMA nodes, that supports multiple processor groups
(3) All: Minor adjustments to licensing and activation
(3) Core: Improve foreground process awareness with Governor-As-Service
(1) GUI: Dark Mode tested to Win10 19624
Process Lasso 9.8.0.45 BETA
Highlights:
- Refactored CPU core graphs; split into NUMA nodes, supporting multiple processor groups <
- Improve foreground process awareness with Governor-As-Service (GaaS)
- Make ProBalance option 'Ignore children of foreground' default to on
- Add 'Always on top' option
- Add parked core count to status bar
- Add option to hide CPU core graphs
- Fixes and enhancements (see details)
Details:
(45) Pre-release checks, language updates, and code review
(43) GUI: [beta2beta] Adjustments to CPU core graph sizing
(41) GUI: Restore 'Show CPU core graphs' option
(41) GUI: On open, instanteusly populate instead of waiting for first GUI refresh interval
(39) GUI: F5 (refresh) now also updates filtered view and system tray icon
(39) Installer: Improvements to command line parsing
(37) Tools: Remove CPU core graphs from ThreadRacer
(35) GUI: [beta2beta] Adjust CPUEater demo to work more seamlessly with 'ignore children of foreground'
(31) GUI: Add parked core count to status bar
(31) Core: Apply new GaaS foreground awareness to 'ignore children of foreground'
(31) Core: Make 'Ignore children of foreground' ProBalance option ON by default
(29) GUI: Add Always-On-Top option to View menu
(27) GUI: Cosmetic to application power profiles configuration dialog
(27) GUI: Fix an issue with /startwithprofile command line parameter
(21) Core: Improve reliability of Performance Mode rules
(19) GUI/Core: Fix an issue with /configfolder command line parameter
Languages: Update Russian, French, Sloevnian
Languages: Restore Japanese
Process Lasso 9.9.0.7 Beta
June 26, 2020
  • Core: Adjustments to Keep Running and Watchdog process launch behavior
  • GUI: Change default button on Application Power Profiles config dialog
  • Core: Fix an issue with Keep Running failing to launch some console apps due to DETACHED_PROCESS flag with CreateProcess
  • GUI: Default 'ignore problematic processes' to False
  • GUI: Show WSL and protected processes, though user won't have access to act on them
Process Lasso Pro 9.9.0.19 BETA
9.9.0 beta:
Highlights:
+ Show WSL and protected processes
Details:
(19) Core: Allow Application Power Profile rules to be combined with 'Induce Performance Mode' on the same process [experimental]
(13) GUI: Add 'Options / Power / Always start Process Lasso with power profile'
(7) Core: Adjustments to Keep Running and Watchdog process launch behavior
(1) GUI: Change default button on Application Power Profiles config dialog
(1) Core: Fix an issue with Keep Running failing to launch some console apps due to DETACHED_PROCESS CreateProcess flag
(0) GUI: Default 'ignore problematic processes' to False
(0) GUI: Show WSL and protected processes, though user won't have access to act on them
Status
Zamknięty.
