Process Lasso / Process Lasso Pro Beta
Status
Zamknięty.
Process Lasso 9.8.8.61 Beta
(59) Log: Assorted code improvements
(59) Log: Remove deprecated log format marker file
(59) Log: Add system time field in addition to local time (not displayed)
(59) Log: Adjust log entry data structure
(59) Log: [beta2beta] Fix CSV export hang in prior beta
Process Lasso 9.8.8.69 Beta
(69) GUI: Improve behavior of initial log listview population
(67) GUI: [beta2beta] Fix possible hang on CSV export in prior betas
(67) GUI: Make log listview updates more smooth
(65) GUI/Core: [beta2beta] Change sampling interval to seconds
(65) GUI: [beta2beta] Optimize dump to CSV code
Process Lasso 9.9.4.77 Beta
January 21, 2021
  • (77) GUI: Add up/down buttons to CPU affinity rule config dialog
  • (77) Core: Enforce CPU affinity rules in order configured
  • (77) Core: [beta2beta] Fix issue in prior betas where governor would take excess time to cleanup
  • (77) GUI: [beta2beta] Fix issue with Chinese Simplified translation in prior betas that would cause crash
  • (77) Logging: Log default path when GaaP is now LOCAL_APPDATA instead of APPDATA
Process Lasso 9.9.4.81 Beta
January 22, 2021
  • Install: Do one-time migration of config when Governor installed a normal process, from roaming to local profile
  • Core: Changed default config path when GaaP to LOCAL_APPDATA instead of APPDATA (roaming)
  • Install: Cleanup some deprecated code and file(s)
  • Core: [beta2beta] Fix issue in prior betas where governor would take excess time to cleanup
Ponieważ wersje rozwojowe wydawane są zbyt często (nawet cztery razy w tygodniu), to dodawanie ich nie ma raczej sensu. Temat więc temat zamykam, a chętni mogą Betę pobrać z linków poniżej:
Prosess Lasso Beta:
Prosess Lasso Beta Server Edition:
Status
Zamknięty.
