Remote Desktop Manager 2024.2.8.0​
Jun 17, 2024
  • DVLS 2024.2 is required with this version (only if you're already using DVLS)
  • Added Entra ID dashboard entry
  • Added FortiClient IPsec entry
  • Added Shell Script entry
  • Added Splashtop Dashboard entry
  • Added vault content type feature
  • Removed deprecated Google Cloud implementation
  • Removed legacy settings concerning password policies in credentials and folders, as well as legacy setting to add entries in folders
  • Added "Enable DPAPI cryptography on local files" option by GPO
  • Added "Learn more" link to KB on first configuration of CyberArk data source in initial setup confirmation
  • Added a checkbox to display only the recent online backups
  • Added a new $CREDENTIAL_LINKED_NAME$ variable
  • Added a New Script action to the script dashboard
  • Added all session tools to script dashboard
  • Added an icon when top panel is hidden to allow the right click menu
  • Added auto type action for Username, domain, password and OTP
  • Added Base station username to Wifi data entry
  • Added clipboard buttons in the overview
  • Added cursor blink rate setting to SSH Shell
  • Added double click for quick copying in Password List View (Dashboard)
  • Added editing AD object MemberOf groups in AD dashboard
  • Added global RDP option for credential injection mode
  • Added ID matching synchronization to VMWare, HyperV, Lansweeper, Bitwarden, EC2, KeePass and Spiceworks synchronizers
  • Added inherited credential mode on management tools
  • Added initial virtual smartcard support in MSTSC (RDP)
  • Added look up search support in linked hosts and credentials
  • Added Name field for Password list item
  • Added option to choose whether to close the remote jump session or not
  • Added OTP and URL synchronization to Bitwarden synchronizer
  • Added possibility to include favorites when importing/exporting entries in RDM format
  • Added profiles for syntax highlighting
  • Added prompt for version mismatch to clarify behavior for users
  • Added Quick search in trayicon menu
  • Added refresh button for licenses in license management
  • Added script target to connection logs
  • Added selectable expiration time in Devolutions Send
  • Added setting to prevent deletion of files in temporary folders
  • Added support for "allow OTP retrieval" in Bitwarden credential entry
  • Added support for "file://" in documentation markdown
  • Added support for changing host to inherited in batch edit
  • Added support for CyberArk cloud keep alive through identity API
  • Added support for cyberark dual control request
  • Added support for IsAnonymous parameter on connection to telnet terminal
  • Added support of "Let Windows Decide" option for terminal (Powershell, Command Line)
  • Added syntax highlighting configuration in SSH Shell and in system settings
  • Added the data source list in Quick Search
  • Added the IP address from Network adapter in the inventory report
  • Added the possibilty to move or create a new tab group
  • Added Web-based reports for DVLS
  • Allow closing non-connected entry from the Group tab pane
  • Allowed editing the status in entries directly
  • Disable revert and delete from attachments history options when only View permission is assigned
  • Improved clipboard diagnostic
  • Improved CyberArk dashboard and data source to default to CyberArk's favorites
  • Improved datasource MFA settings requiring additional confirmation when set to "None"
  • Improved datasource VPN to support types SSH Tunnel and Port Forward
  • Improved Execute Macro/Script to no longer be modal and usable from an external application with a global shortcut
  • Improved favorites, vault list, data source list, recents and opened entries to be dockable and available in the Window ribbon
  • Improved flow when checking in multiple entries
  • Improved handling of certificate validation in Netwrix feature
  • Improved multiple checkouts scenario workflow
  • Improved navigation pane behavior to auto hide panel when clicking anywhere in the bar
  • Improved recovery code to require "View Password" permission to view the recovery code
  • Improved SFTP settings in SSH Shell to be allowed modification even when SFTP not shown by default
  • Improved support for editors and documents in "stored in database" mode to be allowed in templates for SQL Server and SQLite
  • Improved synchronization support for shortcuts
  • Improved temporary script folder to create a subfolder to store the scripts in
  • Improved the message for users without a licence to make it clearer
  • Modernize the password strength UI
  • Simplified the Secret Server credential selection UI
  • Fixed an issue in DVLS credential entry causing password protected vaults (vault master password feature) to be accessible without password
  • Fixed "remember my choice" for protocol handler in chrome web entries
  • Fixed an issue causing the what's new page to be opened multiple times
  • Fixed an issue to avoid prompt new version available if download on application closed is selected
  • Fixed an issue with unsupported characters with variables in shortcut macros
  • Fixed comment issue in SSH Key Dashboard
  • Fixed discrepancies between the AD sync and the preview
  • Fixed errors with certificate document type
  • Fixed file explorers overwriting their tab titles
  • Fixed Hub issue with attachment password decryption
  • Fixed issue resolving local variables (settings) in certain scenarios
  • Fixed issue where download recording was not working properly in root dashboard
  • Fixed issue where reconnect all was not re-doing the gateway process
  • Fixed issue where Slack would bring the application to front
  • Fixed issue where temporary access wasn't respected in PAM dashboard
  • Fixed issue where Website and Host were showing the same information for overview
  • Fixed issue with append and prepend OTP to password in hub
  • Fixed issue with application not opening in the correct window state at startup
  • Fixed issue with double prompt when copying OTP
  • Fixed issue with the upgrade prompt choices
  • Fixed load from System Information Report from the context menu not working
  • Fixed possible crash with secure desktop
  • Fixed possible HttpListener errors when closing application
  • Fixed possible issue where database upgrade prompt was not displayed
  • Fixed PowerShell Script linked with "before close" event keeps looping
  • Fixed proxy settings options requesting credentials when set to "No proxy"
  • Fixed RDM Cmdlet tool to always use PowerShell 7
  • Fixed secure note not displaying properly on overview
  • Fixed SSH Key Credential not canceling when closing prompted window
  • Fixed temporary access request not visible when sent to a user group on DVLS
  • Fixed the "All vaults" search setting not working via the main menu
  • Fixed time filter not working properly in Logs
Remote Desktop Manager 2024.2.11.0​
Jun 20, 2024
  • Added auto-submit checkbox to Delinea Secret Server two-factor prompt
  • Improved the launching of CyberArk accounts by relying on the Prerequisites
  • Fixed an issue when adding new scripts via the script dashboard
  • Fixed an issue with session tools execution being logged under an incorrect connection ID
  • Fixed context menu losing focus when console host terminal is launched
  • Fixed dynamic credentials not resolving correctly
  • Fixed dynamic credentials UI not working in user vault
  • Fixed issue where folders weren't appearing in tree because of the scope setting
  • Fixed issue where the popular tab wasn't visible when adding entries in SQLite
  • Fixed issue with double prompt when copying empty OTP
  • Fixed issue with some entry types still being available from creation when restricted by the vault content type
  • Fixed number of privileged account displayed in PAM dashboard
  • Fixed other possible issue with "no enterprise license found" with certain types of licenses
  • Fixed possible error when editing an entry and having access to no credentials
  • Fixed UI issue when using legacy option "Navigation bar on top"
Remote Desktop Manager 2024.2.12.0​
Jun 25, 2024
  • Fixed an issue where the Execute permission was never validated for sessions started from the PAM dashboard
  • Added Asciicast recording choice for terminals in DVLS
  • Improved Bitwarden synchronizer to sync URL in the host field of session entries
  • Fixed Delinea secret server token never refreshing
  • Fixed issue where My Account Settings were lost under certain circumstances
  • Fixed LastPass URL encryption issue
  • Fixed multiple issues with VMRC keyboard inputs
  • Fixed password resolving issue for OpenVPN / Greenbow VPNs
  • Fixed possible issue copying credentials in Hub datasource
  • Fixed SCCM error messages not handled properly
Remote Desktop Manager 2024.2.13.0​
Version 2024.2.13.0 (June 28, 2024)​
  • Added domain to search box for Password List view prompt and dashboard
  • Added header search mode for Password List in Dashboard
  • Added possibility to remove folders from favorites when the folder is in a different vault
  • Added proper support for new secret server 'delinea.app' platform
  • Added RoboForm V9 importer support
  • Added the possibility to close the Dashboard from the embedded menu
  • Removed validation check on API Key for BeyondTrust entries since it's not always required
  • Fixed a possible error when adding a new entry right after a full refresh
  • Fixed a possible UI threading error when enabling resource monitoring on SSH sessions
  • Fixed a small issue with the click navigation pane to hide
  • Fixed an issue where opening a session with a template would show the template's name in the header
  • Fixed an issue with the add-ons and inherited host not enabled
  • Fixed an issue with the date sorting in custom report
  • Fixed an unwanted offline prompt when checking the health of an unavailable Devolutions gateway
  • Fixed issue in CyberArk dashboard and handle the prompting of a reason and the ticket number based on account prerequisites
  • Fixed issue with run script window not showing the script selection
  • Fixed issue with security provider crashing
  • Fixed multiple potential errors in certain various scenarios from error reports
  • Fixed OnePassword view password broken when OTP setting is on and there is no OTP on entry
  • Fixed possible error when opening Password Complexity report window
  • Fixed potential error when adding a session to an existing playlist
  • Fixed recently used session entry from another vault not opening
  • Fixed some favorited folder actions not working
Remote Desktop Manager 2024.2.16.0
Version 2024.2.16.0 (July 17, 2024)
  • Added option to display description in connected tab tooltip
  • Added OTP entries to business user and vault
  • Added warning when using local credentials with schedulers in synchronizers
  • Improved Checkout and added handling of Comment and Approval requirements for RDP/SSH over Delinea Secret Server proxy entries
  • Removed Devolutions Send options when DVLS datasource does not have Internet access enabled
  • Fixed a visibility issue with the VMWare "Use IP address instead of host" setting
  • Fixed issue in Hub Personal causing multiple roots error
  • Fixed issue where the updater didn't clean up the temporary files
  • Fixed issue with Duo configuration in Data source MFA
  • Fixed possible freeze on startup when prompting for data source password (SQLite)
  • Fixed potential error when editing a user
  • Fixed RSA login bugs with VNC
  • Fixed Secret Server SSO stuck on stay logged in page
  • Fixed VMWare "Folders" fields not saving properly
Remote Desktop Manager 2024.2.170​
Version 2024.2.17.0 (July 30, 2024)​
  • Added a warning for the cloud backup feature when the "no internet connection" setting is configured
  • Added configurable timeout for certificate revocation check
  • Added groups and notes information to Splashtop computers
  • Added Remote command, chat and file transfer actions to the Splashtop dashboard
  • Added support for Check Out extension and Check In on opened RDP/SSH over Delinea Secret Server proxy entries
  • Added support to override "RDP/SSH over Delinea Secret Server proxy" configured credentials settings
  • Disabled major version mismatch feature (DVLS and Hub) to improve workflow
  • Improved auto submit option in Secret Server MFA to support 8 characters
  • Removed legacy GPO - "Disable Azure Interactive Persistent Login"
  • Renamed SSH shell to SSH terminal
  • Fixed an issue where private keys weren't resolved on DVLS datasources
  • Fixed an issue where the prompt for proxy password wouldn't show on Proxy tunnel sessions
  • Fixed crash when opening .RDM file that contains no openable entry
  • Fixed cyberark dashboard preventing screensaver from firing
  • Fixed execute typing macro from tree view not resolving credentials properly
  • Fixed find by name (user vault) being available inside the user vault for private keys
  • Fixed issue when using "disconnect on lock" and "automatically reconnect on activity" breaking the dashboard
  • Fixed issue with duplicated sub-entries in local templates when doing a "convert with template" action with template groups
  • Fixed issue with invalid port when using Tetnet via Devolutions Gateway
  • Fixed issue with OTP variable not refreshing in typing macros
  • Fixed possible crash where PAM license was checked with Hub Personal
  • Fixed possible Devolutions Send errors by updating packages
  • Fixed possible hang with RDP through proxy tunnel
  • Fixed possible null reference in Azure PIM entry
  • Fixed potential issue in recently used navigation tree
  • Fixed regex validation of WinSCP prompts to support german
  • Fixed timing issue with Secret Server cloud SSO in certain circumstances
  • Fixed UI issue in SSH key generator when loading private key from existing file
  • Fixed WinSCP session not embedding the proper form when OTP being prompted
Remote Desktop Manager 2024.2.18.0
Version 2024.2.18.0 (August 7, 2024)
  • Added "Norwegian Bokmål (Norway)" support as a language
  • Added Copy Username@Domain option in Copy Credentials
  • Added GPO to prevent non-admin users from editing the Gateway tab in RDP entries
  • Added HTTP Response debug level for profiling
  • Added missing .rdp file properties for AAD-related fields
  • Added option to exclude ambiguous characters in password generators
  • Added Tab Group override to User/Local Specific Settings
  • Allow manually synchronizing in offline mode when read-write is enabled
  • Improved bell behavior for terminal to also bold the title in visual mode
  • Improved cyberark dashboard to auto reconnect when refresh triggers 401 error
  • Improved favorite vaults to be displayed in 'all vaults' section
  • Renamed the default "Welcome" page to "Getting started with Remote Desktop Manager"
  • Fixed an shortcut issue with the auto type domain action
  • Fixed crash when adding repository favorite in CyberArk data source
  • Fixed import of backup files not working
  • Fixed issue connecting with CyberArk SAML on certain providers
  • Fixed issue with protocol handler and changing datasource to open entry
  • Fixed issue with Windows Terminal not starting
  • Fixed possible crash in VPN group report
  • Fixed potential error when doing view password on folders found through a search with a collapsed navigation panel
  • Fixed tab groups focus issue when interacting with dashboard
  • Fixed template groups states when refreshing the list
Remote Desktop Manager 2024.2.19.0
Version 2024.2.19.0 (August 9, 2024)
  • Added support for max reconnection attempt on RDP in external mode
  • Improved last opened connection list to no be longer a modal window
  • Fixed folder collapsing when updating templates
  • Fixed issue editing vault variables
  • Fixed issue with Bitwarden not listing all available accounts
  • Fixed possible crash when filtering favorite folders
  • Fixed possible infinite loop when sorting subentry that references its parent as a subentry
  • Fixed secure note overview with DVLS high security vault
  • Fixed unresolved variables in backup file name
Remote Desktop Manager 2024.2.20.0
Version 2024.2.20.0 (August 19, 2024)​
  • Added GPO to prevent launching more than a set amount of entries at once
  • Added support for license management with Microsoft Entra ID dashboard
  • Improved logs with Delinea Secret Server
  • Removed reveal password button for SQL Server custom login
  • Fixed issue sending certain parameters to DBeaver
  • Fixed issue sending password with quote character in Winbox
  • Fixed issue when saving SSH terminal entry in certain scenarios
  • Fixed issue where "version mismatch" trigger happened in wrong circumstance
  • Fixed issue where document in "link to file" mode can't have its path changed
  • Fixed issue with 'most recently used' feature where it was not refreshing upon reaching its max count
  • Fixed issue with "general" section of entries not showing after configuring a VPN
  • Fixed issue with "Open embedded (SFTP)" when using default port resulting in connection failing
  • Fixed issue with CyberArk Privileged Cloud for CyberArk data source
  • Fixed issue with unresolved password with auto-typing feature in Hub
  • Fixed issue with variable resolving when there are whitespace in the value
  • Fixed not being able to edit session type entries while in offline mode
  • Fixed potential null reference exception when using the documentation editor entry
  • Fixed UI issue with prompt for datasource window when adding or editing datasources
Remote Desktop Manager 2024.3.10.0​
Sep 23, 2024
  • DVLS 2024.3 is required with this version (only if you're already using DVLS)
  • Added automatic check-in for PAM accounts
  • Added Barracuda NAC VPN entry (experimental)
  • Added native HP ILO console
  • Added One Identity Safeguard for Privileged Passwords credential entry
  • Added ProtonPass password manager credential entry
  • Marked 1Password local mode as deprecated
  • Marked Dropbox datasource as deprecated
  • Marked Google Drive datasource as deprecated
  • Marked ISL Light Desk as deprecated
  • Marked online backup feature as deprecated (use local backup instead)
  • Removed Aurora Password Manager import
  • Removed using DOD as user vault for SQL Server and DVLS
  • 'Most recently used' feature now saves in user settings for SQL Server instead of locally
  • Fixed an issue where the policies to disable password reveal weren't applied to the password analyzer
  • Added "Application" to grant access (DVLS)
  • Added "check synchronization status" and "reset password" buttons to PAM navigation pane in DVLS
  • Added "move to top" and "move to bottom" for syntax highlighting items
  • Added a copy script action to the script dashboard
  • Added a new option to keep synchronized entries structure
  • Added a setting to modify the wait time before the auto typing
  • Added additional reveal actions in dashboard
  • Added buttons to clear website entry cache on close in several menus
  • Added checks for insecure SSH algorithms in the security dashboard
  • Added copy username to dashboard for PAM Accounts
  • Added duplicate for documents stored in database
  • Added dynamic credential linking in OTP section
  • Added expiration time configuration when sending through Devolutions Send
  • Added export options for custom powershell report
  • Added feature to close opened connections with a double click in the tree view
  • Added feature to limit amount of entries launched at once in System Settings
  • Added GPO to disable password retrieval from CyberArk
  • Added information text in "Add entries" when browsing a limited list
  • Added initialization and migration page for Hub Personal in onboarding
  • Added MFA support to entry security analysis
  • Added more fields for information in Driver's License
  • Added multi-vault support for temporary access requests done through secure messages
  • Added new 'high priority' feature in messaging
  • Added option in File->Settings to turn off SendKeys for websites
  • Added parent/unparent option for normal users
  • Added processing dialog when deleting or importing specific settings through the list
  • Added re-connect attempt on CyberArk Oauth authentication
  • Added scrollbacklines and colour handling when converting PuTTY to Terminal entries
  • Added security dashboards menu in ribbon
  • Added ServiceNow ticketing service (SQL Server)
  • Added status bar information when launching playlist
  • Added support for bold characters in SSH terminal syntax highlighting
  • Added support for case insensitive regex matching in syntax highlighting
  • Added support for custom syntax highlighting color and added support for transparent colors
  • Added support for CyberArk SSH over PSM Proxy (self hosted)
  • Added support for Devolutions Send expiration with DVLS
  • Added support for import from .rdx file into single vault datasource
  • Added support for linked hosts in Hub
  • Added support for new AD LAPS (on prem) encrypted password
  • Added support for permission sets in temporary access
  • Added support for Prompt on Connection for linked host mode
  • Added support for RDP/SSH over Delinea Secret Server proxy entries to inherit their credential settings from their folder
  • Added support for RDP/SSH over Delinea Secret Server proxy entries to use "My personal credentials" and "My privileged account"
  • Added support for sealing document entry types
  • Added support for SSO in Pleasant Password entry
  • Added support to force entering comment on checkout prompt
  • Added UI to change the sensitivity of custom fields 6 and above
  • Added unlimited parameters for command entries and macros
  • Added variable support in documentation with an option
  • Added view password from the Dashboard overview for the password list item
  • Added warning when copying entries with documents stored in database
  • Changed the default value of the "Mask password" setting to mask the password by default
  • Enabled session recording for WebView2 (Edge, Chrome)
  • Improve website basic authentication by passing creds through header instead of URL
  • Improved alternate host prompt to focus the list and allow keyboard navigation
  • Improved batch user specific modifications to only update the logs once
  • Improved broadcast feature with buttons and shortcuts to toggle all
  • Improved Chrome website backend integration to support more options
  • Improved file backup feature
  • Improved generation of SSH key in SSH key dashboard
  • Improved import permission in Hub datasource
  • Improved keeper searching to include URL and custom fields, as well as search through child folders
  • Improved Native Application Login entry default mode to be Focus or Execute
  • Improved offboarding of users by allowing conversion of user vault to a shared vault and unassigning licenses when deleting a user
  • Improved refresh of user preferences
  • Improved SFTP/FTP/SCP labeling when performing an edit
  • Improved the Add/Update button to allow Save and open session immediatly in entry properties
  • Improved vault access request response view to show what response will be sent
  • Improved Website's 'discover' feature to use WebView2 (Edge)
  • License expiration message made clearer for non-admin users
  • Removed an unnecessary checkout prompt when copying a privileged account username
  • Removed deprecated GPO DisableToolsDevolutionsServerConsole
  • Removed the "Find by name (user vault)" option from SSH key settings in data sources that don't support the user vault
  • Update Entra ID dashboard authentication to use external default browser
  • Fixed a collection modified exception when adding an entry
  • Fixed a freeze issue in the Keeper account selection form
  • Fixed a Hashicorp Vault permission issue when trying to verify the vault health
  • Fixed ActiveTimeValue and DurationValue for activity log exports
  • Fixed an issue in SQL Server where the Add permission could be bypassed when importing entries in a specific folder
  • Fixed an issue where the data source auto refresh would stop working after a few times
  • Fixed an issue where the OTP information would be lost when launching a host entry via a template
  • Fixed an issue where the prompt to go offline would not appear when switching from a local datasource
  • Fixed an issue where the VMWare synchronizer was creating RDP entries without a host
  • Fixed an issue with special characters in website overview URL
  • Fixed bug where parent name on sub entry was not resolved
  • Fixed bug where variable did not work in command line
  • Fixed convert with template name always being kept and added port option
  • Fixed display when exporting permissions to Xlsx
  • Fixed dynamic session tools visibility issue in the main ribbon
  • Fixed exporting vault when no selection in tree view
  • Fixed image coloring issues in folders when changing folder type before changing image
  • Fixed image zooming issue when image zoom at 1%
  • Fixed inconsistencies in iLO and DRAC connection settings
  • Fixed issue copying private key data
  • Fixed issue when overriding browser in website entries
  • Fixed issue when restarting app after importing settings
  • Fixed issue where command line and protocol handler sometimes didn't take the "allow host override" system setting into account
  • Fixed issue where connections could be saved as template while offline
  • Fixed issue where logs tab was visible in hub personal
  • Fixed issue where recordings were not available when using FreeRDP
  • Fixed issue with "locked" state not prompting for the password
  • Fixed issue with "open as SCP/SFTP" not transferring the private key from SSH source
  • Fixed issue with Microsoft VPN not getting the proper host
  • Fixed issue with Native Application Login finding application
  • Fixed issue with open VPN connect not working when profile name was not set
  • Fixed issue with recording where it would open when it's required but disabled through the system settings
  • Fixed issues when playing recordings where title was missing and .trp/.cast file were not working
  • Fixed issues with Asciicast SSH remote recording
  • Fixed KeePass plugin file not installed with proper casing
  • Fixed OTP settings not being passed through specific settings
  • Fixed Password List - OTP prompts three times
  • Fixed playlist issue with locating host of moved entry
  • Fixed possible error when getting Duo response
  • Fixed possible issue with illegal characters in file path for SQLite
  • Fixed potential issue with exception handling in DVLS offline mode
  • Fixed public key generation in ssh key credential
  • Fixed recording settings local options being displayed when unusable
  • Fixed resolving variables with linked entries
  • Fixed ribbon and script dashboard not displaying scripts custom images
  • Fixed scrollbar position in gridviews when forcing a selection
  • Fixed the self approval for pam checkouts done from an SQL datasource
  • Fixed Typing Macro issue in "Execute in current tab" mode double click in tree view
  • Fixed typing macros "Execute in current tab" setting not always working
  • Fixed VNC losing port when set in Host field
Remote Desktop Manager 2024.3.12.0​
Sep 30, 2024
  • Improved Greenbow VPN path handling
  • Made Devolutions Send tool in the ribbon pinned by default
  • Fixed 'referenced by' to include missing links
  • Fixed a cache issue when copying the host from the dashboard
  • Fixed an issue where Devolutions Send couldn't send inherited passwords
  • Fixed an issue where overview actions would be performed in the context of a previous datasource
  • Fixed an issue where rights weren't correctly applied in the user vault
  • Fixed an issue where templates could be saved with encrypted passwords
  • Fixed an issue where the prompt to merge offline changes wouldn't appear in the user vault
  • Fixed an issue with edit contact in Asset
  • Fixed assign license button being available on licenses that can't be assigned
  • Fixed AzurePIM entry duplicating into shared vault
  • Fixed batch edit for Asset section Summary
  • Fixed cache issue in Hub when updating entries
  • Fixed control states issue with adding tasks in empty datasource
  • Fixed converting entry with template Username/Password not saving OTP
  • Fixed CyberArk PVWA cred not retrieving safes
  • Fixed display caching issue in document entries
  • Fixed issue for SSH with certain Bitvise server versions
  • Fixed issue where entry name could be saved as empty
  • Fixed issue with CSV export causing error
  • Fixed issue with Custom Variables tab not showing the correct settings in System Settings
  • Fixed issue with disabled remote recording where entries were opening before the error prompt
  • Fixed issue with documentation tab when user has access to no shared datasource
  • Fixed multiple issues with local backup when configured wrong
  • Fixed performance issue in activity log report
  • Fixed performance issue loading temporary access list in Hub
  • Fixed possible crash when discovering website control IDs
  • Fixed possible error when duplicating a document entry with a missing internal document
  • Fixed potential collection changed errors
  • Fixed show password button visibility issue when using GPOs in password analyzer
  • Fixed synchronizers not working in the user vault
  • Fixed the "move to existing password list" not working in the user vault
  • Fixed UI state issue with broadcast all feature
  • Fixed user vault getting cleared after force refresh
  • Fixed variables in powershell parameter are not resolved
  • Fixed vault name when sending user vault entries from shared vault in send message
