Remote Desktop Manager 2024.3.13.0​
Oct 7, 2024
  • DVLS 2024.3 is required with this version (only if you're already using DVLS)
  • Added dashboard warning to google drive datasource to help for migration
  • Added support for External Federation (SSO) authentication mode to One Identity Safeguard
  • Added support for view limit with Send shareable links
  • Added variable GATEWAY_LISTENERS with Gateway Tunnel bind points
  • Allow changing gateway order in SSH Gateway entries
  • Improved "add software" UI clarity
  • Improved duplication feature by removing "Add" permission check at source (the permission is checked when saving instead)
  • Improved offboarding window
  • Improved profile selection in Website entry
  • Fixed a flickering issue when opening the My Account Settings forms
  • Fixed a possible null reference exception when first loading the temporary access requests
  • Fixed an issue with Hashicorp vault standby nodes
  • Fixed duplication in offline mode issue
  • Fixed inconsistencies with user vault rights
  • Fixed issue showing copy button for domain field in overview
  • Fixed issue with Add permission check when duplicating a shortcut in the root
  • Fixed issue with folder creation from Contact entries
  • Fixed issue with TN3270 terminal hanging when server can't be found
  • Fixed local specific settings not working on the user vault root
  • Fixed not seeing Sub Connections private key when browsing for private key in file explorer entries
  • Fixed onboarding issue when canceling Hub business process
  • Fixed possible error with the MRUs in Hub
  • Fixed potential issue with "discover" feature for certain websites
  • Fixed vault settings buttons in user vault
Remote Desktop Manager Free 2024.3.15.0​
Oct 22, 2024
  • Improvements:
  • Added option to override the RDP client name
  • Added the option "Allow password in variable" in My Privileged Account
  • Fixed Workspace plugin not detecting user vault entries when having websites in the shared vault that don't have the permission "Connect (Execute)"
  • Improved "Export all host list" to resolve inherited and linked hosts
  • Improved error handling when exporting with Powershell in Hub
  • Improved the application to not steal the focus
  • Improved the offboarding window
  • Improved the quick search to not restore the main application when a connection is opened externally or undocked
  • Fixes:
  • Added an option to translate simulated Unicode to scan codes to fix the "Type clipboard" not working in the web VMWare console
  • Fixed a possible unhandled exception with the port scan
  • Fixed display issue when selecting recipient for in app messages
  • Fixed error when opening a session using a privileged account credential
  • Fixed http browser linker not detecting User Vault Entries when having websites in the shared vault that don't have the permission Connect (Execute)
  • Fixed issue resolving "$" in Powershell script parameters
  • Fixed issue resolving credential configured on RDP/SSH over Delinea Secret Server proxy entries in the User Vault
  • Fixed issue where the user vault's root dashboard displayed the root dashboard of the shared vault
  • Fixed issue with "My account settings" not being saved in an SQLite data source
  • Fixed issue with a user vault entry configured to use a Delinea Secret Server proxy from the shared vault not resolving the credentials properly
  • Fixed issue with variables not being resolved in a Powershell script's parameters
  • Fixed One Identity Safeguard's policy resolving
  • Fixed permissions not being editable in templates
  • Fixed possible crash when offline data is corrupt
  • Fixed problem for widgets in user vault
  • Fixed templates being exported with the global vault
  • Fixed users being able to view the logs of all vaults from the activity logs when using it from their user vault
Remote Desktop Manager Free 2024.3.16.0​
Oct 29, 2024
  • Marked Google Drive entry as deprecated
  • Added "legacy profile handling" option for Chrome as System Setting and GPO
  • Added GPOs to restrict adding datasources to only certain types
  • Added Grant temporary access to context menu
  • Added options to prompt for confirmation and cancel tab closure when log-off timeout is reached
  • Improvements to password list view
  • Increased border thickness for grip size in secure note dashboard
  • Fixed an issue with url encode in richtext document
  • Fixed buttons not working in system settings user template
  • Fixed HDPI Issues and prevent double scaling of application on launch in HDPI
  • Fixed issue where the application might be unresponsive when opening a session
  • Fixed issue with RDP API hooking on Windows Server 2016
  • Fixed properties button incorrect state when selecting folder
  • Fixed restore last opened entries not working in the user vault
  • Fixed the option "Always launch application on external protocol request" for Edge and Chrome
  • Fixed UI issue where users were not visible in entry permissions in Hub
  • Fixed Winbox duplicated port with the alternate host prompt
Remote Desktop Manager 2024.3.19.0​
Nov 25, 2024
  • Added support for importing from KeepassXC (csv, xml)
  • Added option to allow server generated mouse movements in RDP
  • Added possibility to select credentials while doing a quick connect
  • Enabled Google Drive data source restricted mode
  • Improved X.509 certificate parsing in certain scenarios
  • Removed unused Dropbox policy
  • Fixed a possible index out of range exception when launching an entry in the trayicon
  • Fixed a possible null reference exception when viewing an entry's password
  • Fixed Account/MRU image issue
  • Fixed an issue where using environment variables in the Sqlite database name would wipe the data source configuration
  • Fixed Azure PIM responsiveness
  • Fixed guid parsing issue when saving windows terminal profiles
  • Fixed incomplete entry save when sending folder via message in dvls datasource
  • Fixed inherited dynamic value not being taken into account with RDP/SSH over Delinea Secret Server proxy entries
  • Fixed issue saving Secure Note entry in shared templates for SQLite
  • Fixed issue with alternate host prompt for Websites
  • Fixed issue with Azure Bastion when using inheritance
  • Fixed issue with Edge and Chrome (WebView2) blank new window in some instances
  • Fixed issue with LastPass getting an error when using Duo
  • Fixed issue with Work Area Screen for RDP when inherited from local settings
  • Fixed potential crash when progress prompt is shown
  • Fixed potential crash with missing Arial Bold font
  • Fixed typos in policy display names and normalized capitalization for policies
  • Fixed Vault Access Request not showing in the dashboard
Remote Desktop Manager 2024.3.20.0​
Dec 4, 2024
  • Added a "Tile layout" feature to quickly arrange embedded views
  • Added RustDesk executable override
  • Improvements to clarity and feedback to the password list view window
  • Removed case sensitivity for first synchronizations name matching
  • Fixed a niche issue where granting temporary access for Execute would give all permissions relating to a random permission set
  • Perform host mismatch check in certificate validation component
  • Fixed additional issue with Azure Bastion and inheritance
  • Fixed an encoding issue with special characters in typing macros
  • Fixed an issue where the RDP title wouldn't appear in Work Area Size mode
  • Fixed an issue where the requested permission set wasn't displayed in the temporary access window after a grant
  • Fixed an issue with closing external sessions while RDM is minimized to trayicon
  • Fixed issue where activity logs was slow to open
  • Fixed issue where attachments could be saved without meeting the password template requirements when set to Default with a System setting
  • Fixed issue where certain generated SSH keys were not compatible with OpenSSH
  • Fixed issue with "use IP address instead of host" not loading in VMWare synchronizer entry
  • Fixed issue with Execute download action not working in embedded browser
  • Fixed issue with Password Templates taking into account unchecked criterias on Hub
  • Fixed issue with shortcuts sometimes duplicating when tree view is undocked
  • Fixed issue with Windows Admin Center not loading
  • Fixed PAM vault account sorting
  • Fixed silent errors when opening an RDP session with dynamic resolution
  • Fixed VMWare Dashboard not working with User Specific Settings
Remote Desktop Manager 2024.3.29.0​
  • Added home button to update window (change history)
  • Added logs when exporting documents from the datasource
  • Added multi select support in File Explorer entry
  • Improved the documentation performance
  • Fixed an issue where the overview does not handle the none in inheritance
  • Fixed batch edit issue in local context
  • Fixed issue where the User Vault button was shown in Hub Personal despite not being supported
  • Fixed issue with multi line embedded scripts not working in remote powershell
  • Fixed regression in Edge browser for VMWare vCenter file downloads
  • Fixed session tools not starting with the right credentials
