Remote Desktop Manager Free 2025.1.25.0​
Mar 14, 2025
  • Changed license validation URL from
    to
    . Make sure your network allows access to this URL
  • Fixed "Run script via RDM agent" not loading scripts
  • Fixed a possible error when a session automatically closes
  • Fixed an error when assigning an empty license
  • Fixed DVLS PAM credential not taking the "Allow OTP retrieval" setting into account
  • Fixed error at startup when you have an application name override
  • Fixed error when trying to launch a PSM connection with the CyberArk dashboard with no prerequisites prompt
  • Fixed issue where incorrect form was used in BeyondTrust Password Safe
  • Fixed issue with BeyondTrust password safe entry when saving without a linked credential
  • Fixed issue with the treeview's incremental search and some special characters
  • Fixed possible error when adding a script in the script dashboard
  • Fixed possible error when saving entry in Hub Personal data source
Remote Desktop Manager Free 2025.1.27.0​
Mar 27, 2025
  • DVLS 2025.1 is required with this version (only if you're already using DVLS)
  • Marked Netwrix Password Safe as deprecated
  • Improved log for "Used by" event for credentials
  • Supremo Remote Desktop is now available by default
  • Fixed favorites "Select and open" action
  • Fixed issue playing back recordings through context menu instead of button
  • Fixed Legacy clipboard to not send secure formats by default
  • Fixed potential crash when importing with network scan
  • Fixed Secret Server being very slow to load with more than a 1000 secrets
Remote Desktop Manager 2025.1.30.0​
Apr 9, 2025
  • Added "Copy username and password" to default entry actions
  • Added better LDAP full text search query to AD dashboard
  • Added double click action and shortcut binding to rename tabs
  • Added german dictionary for passphrase generation
  • Added GPO to hide browse host button
  • Added new navigation option to only show opened sessions
  • Changed the min/max value of the Tab page max width to be between 20 and 300px
  • Entries can now be deleted without checking out, unless already checked out by another user
  • Improved iDRAC to try port 443 when negotiating the connection
  • Improved logs accuracy when auto typing and using OTP
  • Improved message accuracy when failing to go online from an offline datasource
  • Improved message clarity when moving entries to another vault fails in Hub
  • Trim leading space(s) from WebView2 cache path
  • Fixed AD dashboard search threading
  • Fixed Barracuda launch error
  • Fixed disconnect logic for Barracuda
  • Fixed Enter & double-click of tree view of Favorite tab
  • Fixed error at startup when you have a corrupted XML in your UpdateHistory file
  • Fixed issue opening RDP via secure gateway in Hub
  • Fixed issue where focusing a password textbox would try to resolve the password and get blocked by Hub on the server's side
  • Fixed issue where script variables weren't resolved properly
  • Fixed issue where tags weren't loading in advanced search
  • Fixed issue where the dashboard customization did not save
  • Fixed issue with filename exceeding system limit for local recording
  • Fixed missing override issues in MRU view
  • Fixed Most Recently Used (MRU) actions
  • Fixed possible crash in tab group context menu
  • Fixed possible crash when using FreeRDP over RD Gateway
  • Fixed possible error in CyberArk
  • Fixed possible error when loading backup history
  • Fixed possible error with the log menu
Remote Desktop Manager 2025.1.31.0​
Version 2025.1.31.0 (April 16, 2025)​
  • Added "Populate from vault" in IP list entries
  • Allow user to disable Avalonia composition modes
  • Fixed asset -> location fields not appearing in dashboard overview
  • Fixed Cisco Firepower autofill
  • Fixed CyberArk PVWA entry to account configured with RemoteApp enabled not working properly
  • Fixed CyberArk to Cloud instance not taking its API URL from the bootstrap settings
  • Fixed exporting as HTML not always prompting for a path
  • Fixed issue where custom autofill scripts were not running without field detection
  • Fixed issue with local recorder with full size resolution
  • Fixed issue with resolving variables for SSH key dashboard and other specific contexts
  • Fixed missing button to add roles in password list item
  • Fixed password reveal issue in attachments
  • Fixed possible vault loading loop
  • Fixed refreshing issues in Task list
  • Fixed synchronizers causing hanging update messages in the status bar
  • Fixed tree view not updating when closing a connection with the filter "show only opened sessions" active
  • Fixed variable not resolving properly when Delinea credential is used with SSH/RDP Delinea entry
  • Tentative fix for the Windows Accent Tracking issue
Remote Desktop Manager 2025.2.13.1​
Jun 4, 2025
  • Added "linked (external vault)" feature (SQL Server)
  • Added "Pending approval" workflow including a new status and a way to configure it by default
  • Added dashboard entry for AWS IAM
  • Added dashboard entry for Proxmox
  • Added new permissions for editing VPN/Tunnel/Gateway and editing Session Recording configuration
  • Added new VPN for Cloudflare WARP
  • Added Powershell synchronizer
  • Added privileged session monitoring tool for DVLS
  • Added ServiceNow dashboard
  • Added SQL Server Management entry (doesn't require SSMS)
  • Added support for notifications from DVLS
  • Added support for OneIdentity Privileged Sessions
  • Added support for Tailscale VPN
  • Improved "prompt for connection" choice with linked (vault) mode to use the ID to fix issues with renaming folders — entries saved with this setting in 2025.2 will not be compatible with older versions and the configuration will need to be made again
  • Marked alternative view modes for the navigation pane as deprecated
  • Marked Internet Explorer embedded as legacy — we encourage using Edge as your embedded browser where possible
  • Marked UltraVNC in embedded mode as deprecated and will be removed in 2025.3 - Use FreeVNC instead
  • Our EULA and TOS are now combined into a single master agreement and include our new solution packages
  • Removed Devolutions Online Drive datasource — Use Devolutions Hub Personal instead
  • Removed Online Backup feature — Use file backup instead
  • Added a default option for the Azure Bastion connection mode
  • Added a visual cue to indicate when the session recordings frame rate is overridden by the system settings
  • Added always ask password configuration to bitwarden My Account Settings
  • Added an option to configure the website tab max length
  • Added an option to fill hidden fields in browsers
  • Added authorization message to Temporary access report
  • Added cluster node support in Hyper-V dashboard
  • Added environment variable support for RDM_CONFIG_PATH and RDM_POWERSHELL_CONFIG_PATH
  • Added field selection to Devolutions Send
  • Added format option to public SSH key copy
  • Added inherited option to entry forecolor
  • Added JIT elevation for domain in Hub
  • Added more information to VPN settings when inherited
  • Added new credential mode "use linked host credentials"
  • Added new keyboard shortcut for "Open (use parent folder's credentials)"
  • Added onboarding wizard to the ribbon
  • Added OpenSSH conversion to git signing setup window
  • Added option override to session recording framerate
  • Added paging support for activity logs
  • Added sealed entry feature to linked credentials
  • Added SSL setting for HyperV connection
  • Added support for $connection variable in event scripting
  • Added support for including entries when duplicating a folder
  • Added support for Linked (user vault) to the vpn settings
  • Added Terminal tab settings in PowerShell script
  • Added to LastPass the Option to change between multiple two factors
  • Added UseMsalEmbeddedWebView option
  • Added user group support to message & report an issue recipients
  • Added User specified server name to RDP settings for troubleshooting purposes
  • Improved all vaults filter window result behaviour to close when clicking outside of the result
  • Improved ARD clipboard robustness
  • Improved behavior with session launched with JIT privilege to avoid failing preemptively
  • Improved Hub shortcuts to launch on double click
  • Improved LastPass integration with async library
  • Improved usage of sealed entries with Devolutions Send to prompt for unsealing
  • Moved "clean up activity logs" inside the clean up manager
  • Reworked the SFTP explorer in Avalonia
  • Sub entries will now copy with Ctrl + Drag in tree view
  • Synchronizers can now add new folders when selecting a destination folder
  • Fixed CyberArk PVWA credential not resolving properly when inherited from a parent folder
  • Fixed duplicate entries issue where sub-entries were not duplicated
  • Fixed issue in Secret Server where personal folder ignores root-level folders without secrets
  • Fixed issue where desktop shortcuts and RDM launch commands did not behave properly with playlists
  • Fixed issue where opening application would cause an error while applying the theme
  • Fixed issue where opening the application would cause an error while applying the theme
  • Fixed issue where template groups created multiple folders in Hub Business
  • Fixed issue with Devolutions Send using Password Lists not sending the password correctly
  • Fixed issue with key agent loading the same key multiple times in certain circumstances
  • Fixed issue with Password Depot login and OTP
  • Fixed issues with locked vault interactions
  • Fixed possible error occurring after security provider modification
  • Fixed possible issue with DVLS offline My account settings not saved when going back online
  • Fixed possible issue with slow dashboard loading
  • Fixed UI issue to hide gateway if not supported in quick connect
  • Fixed various copy actions interaction with linked SSH Key in SSH entry
