Remote Desktop Manager 2024.1.15
Version 2024.1.15.0 (March 11, 2024)​
  • DVLS 2024.1 is required with this version (only if you're already using DVLS)
  • Added CyberArk data source settings support for LDAP and RADIUS accounts
  • Fixed issue preventing export when on a legacy Hub Personal datasource
  • Fixed possible issue where System or User vaults didn't load
  • Fixed SSH connections not working with private key authentication
  • Fixed various UI issues
Remote Desktop Manager 2024.1.18
Version 2024.1.18.0 (March 19, 2024)​
  • Added an option to specify a custom temp folder
  • Added Expand and collapse buttons in Smart Folder dashboard
  • Added GPO to clear browser cache when closing the application (Chrome-MSEdge)
  • Added GPO to disable Session Recording
  • Added Server roles as variable
  • Added Softwares column in tree and list view
  • Improved Active Directory synchronizer to new LDAP stack
  • Increased the maximum timeout setting in post login SSH commands
  • Minor performance improvement to load the Script dashboard content
  • Fixed Active Directory synchronizer error when using FastViewer template
  • Fixed an issue with the tags in Account information tab when automatically signed in
  • Fixed assign tags regression
  • Fixed CyberArk dashboard Connect disabled for accounts in the favorites pane
  • Fixed filter not clearing correctly when switching nav pane selection
  • Fixed issue caused by setting a PAM checkout time higher than the configured maximum
  • Fixed issue where starting RDM in without a network connection would not prompt to go offline
  • Fixed missing ref folder in installation
  • Fixed possible crashes with CyberArk integration
  • Fixed process architecture in the main window footer
  • Fixed SFTP freeze when closing remote connection
Remote Desktop Manager 2024.1.21.0​
Apr 3, 2024
  • Added "Learn more" link to KB on first configuration of CyberArk data source in initial setup confirmation
  • Added option (on by default) to override powershell execution policy
  • Added RDP setting to disable UDP transport
  • Added support for AD Sync LDAP NOT Filter
  • Added support for any connection type through Azure Bastion
  • Changed minimum value of input delay on the filter
  • Possible fix for proxy issues in Hub
  • Fixed issue with permissions when using move from edit special actions
  • Fixed 1Password OTP not working with QR Code
  • Fixed a possible crash with invalid language names on first load
  • Fixed AD Sync LDAP with inherited credentials
  • Fixed AD sync preview crash
  • Fixed AnyConnect icon issue
  • Fixed batch edit User Specific Settings not working on multiple folders
  • Fixed CyberArk AAM credential failing to resolve username with some version of CyberArk
  • Fixed issue converting OTP information when converting username/password entry to website
  • Fixed issue showing system vault SSH gateways in SSH Shell, SSH Tunnel and Portforward entries
  • Fixed issue where default was not selected when entering password generator
  • Fixed issue where empty template groups were showing when trying to convert with template
  • Fixed issue where search was not resolving all variables
  • Fixed issue where template list didn't load in certain contexts
  • Fixed issue with PAM checkout time selection
  • Fixed multiple issues showing macros/scripts/tools in the context menu and dashboard depending on context
  • Fixed playing remote recordings and closing embedded view while playing causing a freeze
  • Fixed possible freeze with SQLite data source
  • Fixed potential issue with metadata in Hub
  • Fixed reconnect failing when using RDP and CyberArk pvwa
  • Fixed secure desktop ACL causing memory corruption
  • Fixed the potential log issue on close continuous ping
  • Fixed unsupported RDP keyboard layouts
  • Fixed vault search field POS1, END and navigation keys not working
Remote Desktop Manager Free 2024.1.28.0​
May 1, 2024
  • Improved VNC and RDP authentication in specific scenarios
  • Fixed issue where RD Gateway password could be revealed without view password permission
  • Fixed issue where SSH gateway password could be revealed without view password permission
  • Fixed issue with wrong check for failed embedding in certain scenarios
  • Fixed QR code issue in 1Password
  • Fixed session recording causing the RDP to not close when connecting through an unreachable gateway
  • Fixed UI for batch overriding settings in Website entries (Web browser extension section)
Remote Desktop Manager Free 2024.1.31.0​
Jun 4, 2024
  • Improved RDP macro logoff by using scancodes instead of vkcodes
  • Fixed "Load From Inventory" tool failing when using user specific settings for tools credentials
  • Fixed entries in connections tab of Play List Editor being duplicated when creating a new play list
  • Fixed PAM usage policies not being taken into account when using specific settings
  • Fixed possible HttpListener errors when closing application
  • Fixed possible issue with variables not resolving in the correct way
  • Fixed send message issue with linked credentials
  • Fixed System information report failing when fetching antivirus informations on Windows Server
