Remote Desktop Manager 025.2.14.0​
  • Added codepage CP850 to SSH terminal
  • Added custom parameter resolving for Embedded and Command types in Powershell
  • Added log view to proxmox console
  • Added Select in Navigation Pane for the Referenced By section
  • Added UI to set privileged session monitoring permission in DVLS
  • Added Username column in the Bitwarden select prompt
  • Allow resizing of all vaults search result
  • Improved Azure PIM activation and approval behavior
  • Fixed a possible SQLite crash with an invalid rdd imported
  • Fixed an issue where "prompt on connection" credentials wouldn't work when selecting a user vault credential
  • Fixed an issue where certain templates couldn't be linked in an AD sync template
  • Fixed an issue where importing a key in the SSH dashboard would not keep the comment
  • Fixed an issue where pam usage policies weren't correctly applied when inheriting an OTP
  • Fixed an issue where SSH tunnel connections would generate a random port instead of using the configured one
  • Fixed certain interactions not working in PAM vault when the current shared vault is locked
  • Fixed crash when adding/removing Cyberark favorite in Cyberark datasource
  • Fixed documentation not prompting for save when changing connection with modifications in plain text
  • Fixed invalid prompt with syncs in Hub
  • Fixed issue refreshing User Specific Settings in Hub
  • Fixed issue using PPK v3 SSH keys
  • Fixed issue when selecting the active shared vault in the Linked (External Vault) mode while in the user vault
  • Fixed issue where AWS IAM users list doesn't show when at least 1 users has a null tag list
  • Fixed issue where offline folder duplication on DVLS datasource wouldn't open edit validation prompt
  • Fixed issue where OpenSSH key agent wasn't taken into consideration
  • Fixed issue where PowerShell entries of filename type created temp files
  • Fixed issue with 1Password "Remember this device"
  • Fixed issue with creating another and opening immediately
  • Fixed issue with encrypted parameters in Powershell entry
  • Fixed issue with local proxy
  • Fixed issue with manually entered PAM password not saving
  • Fixed issue with search bar when browsing variables
  • Fixed issue with SSH key agent when multiple keys are loaded
  • Fixed issue with the "Always ask password" in Secret Server
  • Fixed Linked external vault not loading empty on a previously empty selection
  • Fixed multi-select for Terminal Services dashboard
  • Fixed multiple issues with the protocol handler and command line when not allowing to change hosts
  • Fixed Netwrix Password Secure missing in My account settings
  • Fixed null engine error in connection log report
  • Fixed PAM entries having prompt for comment on view password
  • Fixed possible COMException when authenticating to OneIdentity with an External Federation
  • Fixed possible null reference when opening a WinBox entry
  • Fixed session recording on Quick Connect
  • Fixed sub entries collapsing when double clicking the parent
  • Fixed windows terminal color schemes not loading
  • Fixed winrm errors with remote tools
Remote Desktop Manager 2025.2.21.0​
  • Added double click to SFTP treeview
  • Added multi-select support in the SFTP explorer
  • Added option to set default Keyboard functions key mode for terminals
  • Added progress bar to several exports
  • Added support for Proxmox remote consoles
  • Added the possibility to drop nodes anywhere in the SFTP explorer datagrid section
  • Increased the Splashtop session's wait time to embed external windows
  • Optimized the duplicate entry report
  • Fixed a crash when cut/pasting nodes in the SFTP explorer
  • Fixed a possible crash when clearing FileExplorer transfers
  • Fixed a possible crash with multi-threading and Gravatar image
  • Fixed an error in Network Scan when Gateway is not supported by the data source
  • Fixed an issue where creating an entry from a template would not carry the TemplateSourceID
  • Fixed an issue with Devolutions Gateway Management when using an HDPI screen where the dashboard would freeze
  • Fixed crashes when browsing the AWS console
  • Fixed embedded sessions being undocked having application name in their title
  • Fixed error report issue in Tag Management in local datasources
  • Fixed error when you have two licenses with the same ID
  • Fixed file explorer progress staying at 0%
  • Fixed issue sending credentials via email in DVLS
  • Fixed issue to respect the authentication level setting in FreeRDP
  • Fixed issue where canceling CyberArk PSM prerequisite prompt still launched the session
  • Fixed issue where URL encode setting was removed in Website for the external mode
  • Fixed issue with Sophos Connect logging credentials in event viewer by injecting in the standard input instead
  • Fixed issue with SSH agent process hanging when closing application
  • Fixed issues with prompt for credentials when going offline in user vault on a DVLS datasource
  • Fixed Jump as inherited being displayed as functional in tree view when parent aren't set
  • Fixed possible error when sending message
  • Fixed possible refresh error when doing PAM automatic check-in
  • Fixed tree view not properly loading connections after refreshing from a disconnected data source
  • Fixed umlaut characters not always being exported/imported correctly under csv format
  • Fixed visible state of network adapter selection button
Remote Desktop Manager 2025.2.26.0​
  • Added a fallback on user@domain when the username format is UPN but the UPN is empty
  • Improved "elevate shell" feature to not replace the locale
  • Improved password generator "copy to clipboard" to separate passwords with newline instead of comma when in "legacy" copy mode
  • Fixed a possible duplicate issue when executing the same synchronizer multiple times simultaneously
  • Fixed an issue where a failed SFTP upload would delete the local file
  • Fixed an issue where you could edit an entry that was already checked out
  • Fixed CyberArk account custom domain field not resolving
  • Fixed focus issues with WinSCP and PuTTY
  • Fixed issue where prompt for parameter on open option didnt prompt when opening a PowerShell terminal entry
  • Fixed issue where requesting a check out through a Hub Privileged Account credential entry would check out the entry for the requested approver instead of yourself
  • Fixed issue where the data source could be readonly when it shouldn't
  • Fixed issue where the mismatch version warning showed while in offline mode
  • Fixed issue with non-printable characters in ProxyLocal command for terminal
  • Fixed password list duplicating its content if move to itself
  • Fixed possible error when deleting favorite folder
  • Fixed System Vault contact not showing referenced by entries in contacts
  • Fixed the checkout action when editing entries
  • Fixed timing issue with Sonicwall NetExtender
  • Fixed windows hello facial recognition sometimes failing during authentication and closing Application
Remote Desktop Manager 2025.2.28.0​
  • DVLS 2025.2 is required with this version (only if you're already using DVLS)
  • Added confirmation prompt to certificate expiration overriding entry expiration
  • Added lowercase mode to username format
  • Added message when ITGlue server not found
  • Added OTP support to Delinea Secret Server credential entry
  • Added the "Select full desktop / switch monitors" special command to VNC toolbar
  • Changed font color for read only control in dark theme
  • Explicitly set PSM Connection to "Warn me" if the setting is not in the CyberArk provided rdp file
  • Improved behavior of the "Vault (shortcut)" entry when used from the user vault
  • Improved closing error message with Watchguard SSL VPN since it requires administrator rights
  • Only expand root when displaying delinea account list
  • Reduced powershell event minimum value from 10 to 5 seconds
  • Updated Passbolt MFA validation code field to be consistent with other MFA features
  • VNC entry properties will now properly reflect their default settings
  • Fixed "open with template" being accessible in Password List without View Password right
  • Fixed "open with template" with no execute rights
  • Fixed a crash when opening the SFTP panel in an SSH via Delinea proxy session
  • Fixed a possible crash on duplicated SFTP commands
  • Fixed an issue where cancelling the file browsing in the Keepass sync settings would wipe the old filename
  • Fixed an issue where the dashboard was showing PAM checkout times in UTC instead of local
  • Fixed an issue where the proxy credential settings were wrongly disabled
  • Fixed an issue with saving entry permissions in Hub data source
  • Fixed azure PIM expiration warning when selecting long durations
  • Fixed error with vault history
  • Fixed folder names not resolving variables when browsing linked vault credentials
  • Fixed issue in telnet where local echo isn't working correctly
  • Fixed issue when accessing a sub entry from the favorites section and the online sync of the favorites is not working
  • Fixed issue when canceling Duo prompt letting you stay logged in
  • Fixed issue where closing a session linked to a tunnel will close all sessions linked to that tunnel
  • Fixed issue where custom MSI installer ignored the embedded data source configuration on ARM64
  • Fixed issue where interacting with shared templates required the "add in root" permission
  • Fixed issue where IP was overwritten in HyperV when doing a light refresh
  • Fixed issue with IP address disappearing in Hyper-V Dashboard entry
  • Fixed issue with prompt for opened sessions on close when they aren't real actual sessions
  • Fixed issue with ProtonPass fetching credentials in certain circumstances
  • Fixed issue with terminal where logs in overwrite mode set to prompt will always prompt even if the file doesn't exist
  • Fixed issue with user vault loading shared vault when disconnect on idle triggered
  • Fixed possible crash when applying the Windows accent color
  • Fixed possible error when applying a custom tile layout
  • Fixed possible negative values in the password template settings
  • Fixed site column in folder overview not loading information properly when using a linked connection
  • Fixed the VPN_HOST variable for VPN addons
  • Fixed upload and download in SSH ZModem
  • Fixed user vault not loading collapsed states correctly when switching datasource
Remote Desktop Manager 2025.2.29.0​
  • Added option to have password list "copy username" grid button follow the entry's username format rather than copying what is shown in the grid column
  • Added missing logs for OTP prompt on connection
  • Fixed 1password DUO MFA issue
  • Fixed a possible error when browing Netwrix accounts
  • Fixed application moving to current display while file menu is opened
  • Fixed automatic synchronization not always acquiring credentials correctly in DVLS datasources
  • Fixed certain variables resolving issues
  • Fixed Folder entries view not loading system macro correctly in context menu
  • Fixed full screen toggle with RDP launched session
  • Fixed image disposal in file explorer causing RDM crash & freeze
  • Fixed issue preserving template's AllowMultipleConnections setting in Convert with Template
  • Fixed issue where connection via Azure Bastion fails when browser is already logged into an account without the required permissions
  • Fixed issue where password analyzer's password strength/length/occurence columns weren't sortable
  • Fixed issue with playlist filter and variables in connection name
  • Fixed issues with remote recording for IronRDP/VNC
  • Fixed log accuracy when viewing OTP through View Password
  • Fixed possible error when opening the script dashboard twice
  • Fixed possible infinite loop when loading DVLS user
  • Fixed potential thread error on SSH disconnect
  • Fixed Proxmox username/password validation when using credential repository
  • Fixed script dashboard not disabling properly when changing datasource
  • Fixed terminal algorithm not saving properly in Settings
Remote Desktop Manager 2025.3.16.0​
Version 2025.3.16.0​
DVLS 2025.3 is required with this version (only if you're already using DVLS)
Improvements (8)​
  • Added a "Clear all in-memory credentials" button for the My Account Settings
  • Added an option to revert back to the old search function
  • Added broadcast support for Telnet sessions
  • Added distinction for synchronizer logs - Automatic vs Manual execution
  • Added Policy to disable AI Assistant-related features
  • Added reconnect and duplicate buttons to SSH toolbar
  • Added Salesforce Cloud integration
  • Improved reconnecting when using undocked containers
