Remote Desktop Manager Free 2021.1.21.0
Version 2021.1.21.0 (April 8th 2021)
Improvements:
  • Added action to RDP entries to check the server authentication type
  • Added new import for VNC viewer (RealVNC) using .vnc file
  • Added RDP display specific setting for "Center on screen"
  • Added support for Hub Personal offline mode read-only
  • Improved CSV export for Webbrowser, VNC and VMWare entries
  • Removed useless forced prompts for DOD and Hub data sources
Fixes:
  • Fixed "Export All Hosts" button for user vault not working
  • Fixed an entry data loss when deleting shortcuts in XML data source
  • Fixed an issue causing multiple log prompts when viewing credit card info
  • Fixed issue where exporting options could cause credentials to be lost if the option to keep credentials was unchecked
  • Fixed issue where user vault was affected by disable export vault menus
  • Fixed UI freeze when locking application through File -> Lock Application
Pobieranie:
Remote Desktop Manager Free 2021.1.22.0
Version 2021.1.22.0 (April 13th 2021)
  • Added "Interactive authentication in terminal" option to SSH tunnel and SSH port forward
  • Added Copy OTP to contextual menu of session tabs
  • Added new features to the AWS console (Volumes, Snapshots, Elastic IPs, Route 53)
  • Added show files in tree view and show hidden files option to SSH Shell entries
  • Added support for sub connections on all entry types
  • Removed Rebex SSH Shell, Tunnel and Telnet
  • Fixed an issue in XML data sources where changing the selected entry in offline mode doesn't update the dashboard
  • Fixed an issue with the focus in search filter
  • Fixed bug where One Time Password was always visible on web browser
  • Fixed bug where the username was empty when viewing password on a Dameware entry
  • Fixed bug with Putty port forwarding not saving properly
  • Fixed issue saving values in RVTools entry
  • Fixed issue with global shortcuts and minimized RDM not working properly in certain cases
  • Fixed OTP/MFA not sent to DWL
  • Fixed possible issue with windows in SSH appearing behind the application
Pobieranie:
Remote Desktop Manager Free 2021.1.23.0
  • Version 2021.1.23.0 (April 15th 2021)
    • Added a "Server" property to Microsoft L2TP VPN to make it separate from the name
    • Added message when Copy > Clipboard has no valid target due to missing permissions
    • Added option to get domain from generic fields for Passwordstate entries
    • Added options to have windows centered on parent rather than monitor. Also set first load to be done per parent rather than monitor
    • Updated embedded Chrome
    • Fixed a possible issue with Embedded Edge
    • Possible fix for SSH windows being stuck in background
Remote Desktop Manager Free 2021.1.25.0
April 21, 2021
  • Fixes:
  • Fixed a hang when viewing AWS domains on a region other than us-east
  • Fixed an error when moving items in the "last opened connections"
  • Fixed inventory report in Hub Personal that was throwing an exception when running it and added more exception handling in Hub Personal
  • Fixed issue with global shortcuts with minimized RDM not giving proper focus to the application
  • Fixed Password List sorting
Remote Desktop Manager Free 2021.1.26.0
  • VERSION 2021.1.26.0 (May 1st 2021)
    • Removed "Use legacy terminal" option
    • Removed HP RGS libs
    • Removed third party PDF viewer like Acrobat Reader
    • Removed Visio embedded viewer
    • Added import logins from both Microsoft Edge and Mozilla Firefox
    • Added main application minimum size to options and reduced minimum width to fit Navigation Pane
    • Added more exception handling and "isOffline" cases in Hub Personal
    • Added starting location for SFTP with SSH shell entries
    • Added support for mRemoteNG import to SSH Shell entries
    • Fixed an issue causing data sources using a DUO setup with variables to stay "not connected"
    • Fixed an issue causing the data source auto refresh to return to it's default value
    • Fixed an issue with web browsers using 2 different ports when connecting through a secure gateway
    • Fixed issue where terminal could be hidden while using "Interactive authentication in terminal"
    • Fixed missing "Open VPN" and "Close VPN" buttons in ribbon when a folder is selected
    • Fixed password usage report crashing with empty password list
    • Fixed possible issue where sessions added via DWL were not displayed in RDM
    • Fixed small UI issue in password prompt where "remember me" button showed when not supported
Remote Desktop Manager Free 2021.1.32.0
  • VERSION 2021.1.32.0 (May 28th 2021)
    • Changed the default value for SSH remote monitoring to No
    • Improved the browser extension management dialog to open the selected browser
    • Fixed a possible deadlock when the Windows background changes
    • Fixed an issue in overview where the default browser was not used to navigate
    • Fixed multiple issues with a "Custom" S3 File Explorer connection
    • Fixed possible crash when certain backups had a non-parseable date
    • Fixed possible crash when host is wrong and using custom DNS
  • VERSION 2021.1.31.0 (May 21st 2021)
    • Added an option to change the status bar color
    • Added an option to change the title bar color
    • Added Remote Monitoring Footer for SSH Shell entries
    • Fixed possible crash when importing entries with "change ID" selected
  • VERSION 2021.1.30.0 (May 19th 2021)
    • Added a missing dll from the portable version
    • Added support for check is online to most entries
    • Fixed issue where we did not clear the VPN settings of previously selected VPN types in already existing VPN entries
  • VERSION 2021.1.29.0 (May 18th 2021)
    • Added remote credential guard support in embedded RDP session
    • Added Manufacturer and Model information columns to column chooser
    • Added Username Format to Web site entries
    • Improved the Devolutions Account login
    • Improved TRP recording file format
    • Multiline paste warning window now saves the state of the "details" button
    • Reworked Serial Port terminal implementation
    • Fixed issue possible loss of data when adding a Document session while offline
    • Fixed issue where import of web entries was always created on root with the CSV import
    • Fixed issue where S3 explorer would throw multiple errors and become unusable while using it
    • Fixed issue with enter key in telnet returning an extra line
    • Fixed possible freeze while opening website session
    • Fixed VPN/SSH/Gateway tab inheritance issue
    • Fixed Windows Password GPO issue introduced by Windows Hello changes
  • VERSION 2021.1.27.0 (May 7th 2021)
    • Added a new Quick Search with Ctrl+Spacebar
    • Added support for linked host
    • Added Windows Hello support in Lock
    • Added "Windows key on the remote computer" option in contextual menu for undocked FreeRDP sessions
    • Added an File->Options setting to specify the default web browser to use for opening web sites
    • Added an option to OpenVPN allowing the use of existing configuration files
    • Added Answerback option to SSH Shell for XTerm
    • Added custom OTP to credential entries
    • Added navigation combo for Windows Explorer as an option
    • Added RDP Hyper-V local access with current user credentials support
    • Improved Clipboard paste, when choosing "change Id" every subsequent paste will change the new entry Id
    • Improved multi-line paste warning in SSH and Telnet to allow modifying the clipboard before sending it
    • Improved pasting in SSH and Telnet to fix possible issues with long pasted values
    • Resolved possible issue where user vault was empty when offline
    • Fixed issue with tab title when launch for .rdp
    • Fixed issues with Favorite and Private Vault folder state on save and load as well as columns
    • Fixed Wayk and FreeRDP incorrect control size with system DPI awareness
Remote Desktop Manager 2021.1.35.0
  • Fixes:
  • Fixed a possible crash when using multiple gateways
  • Fixed issue where copy OTP was not working properly on entries without a password
  • Fixed issue where logs on View action was not working properly on crashes
  • Fixed issue where Microsoft Edge didn't autofill the proper password
  • Fixed issue with Key Agent crashing RDM on usage
Remote Desktop Manager Free 2021.1.36.0
  • Version 2021.1.36.0 (June 10th 2021)
    • Fixed 1Password integration
    • Fixed a saving issue when using a master password in Keeper credentials
    • Fixed an issue with the Chocolatey console where some packages were missing
    • Fixed issue where notifications status of expiration for credit cards was not handle correctly on the day of expiration
Remote Desktop Manager Free 2021.1.40.0
July 7, 2021
  • Improvements:
  • Added error message to SSH monitoring status bar when the information are not available
  • Fixes:
  • Fixed an issue preventing status editing on sub-connections
  • Fixed an issue with Wayk typing macros and typing clipboard features
  • Fixed Is Favorite advanced search
  • Fixed issue where "Referenced by" for contacts was not handling sub connection properly
  • Fixed issue where username format was not working properly for VMware sessions
  • Fixed issue with Connect button in Hyper-V console
  • Fixed Wayk scaled checkbox and virtual resolution setting
Remote Desktop Manager Free 2021.2.16.0
October 8, 2021
  • Added multi export and multi import proper support for templates
  • Improved error handling for wrong paths in Terminal logs
  • Fixed an issue resulting in an empty template selection prompt when no template is specified in a host entry
  • Fixed broken lock when using Windows Logon or Application Password Without encryption
  • Fixed issue where the the "List sessions" tool in the macro script tools didn't appear
  • Fixed issue with Alt+Backspace not working in SSH
  • Fixed missing "ping" tool from dashboard and context menu
Remote Desktop Manager Free 2021.2.22.0​
November 4, 2021
  • Improvements:
  • Added cust # to columns and Asset to Folder Dashboard
  • Added custom color for tree view when entry in used
  • Added fix to prevent RDM closure on wrong key to Yubikey
  • Added Japanese language
  • Added URLs and Equivalent URLs edit option to web browser batch edit
  • Fixes:
  • Fixed issue where duplicate Chrome connection with clear cache on start up would throw an error
  • Fixed issue with context menu not showing in Devolutions Terminal
  • Fixed null reference when editing a folder in the favorites
Remote Desktop Manager Free 2022.1.12.0​
February 17, 2022
  • Improvements:
  • Added "always launch application on external protocol request" in LogMeIn entry
  • Added diagnostics for Webview2 (Edge embedded) installation status
  • Fixes:
  • Fixed RDP ping issue while using inherited host
  • Fixed some minor issues
Remote Desktop Manager 2022.1.20.0​
March 15, 2022
  • Improved:
  • [BC] Improved encryption of user and local overrides, not backwards compatible with prior versions of RDM
  • [BC] Removed the support for RDP5 and RDP6
  • Added an option to configure the timeout on ARD session
  • Added batch image change color support
  • Added PowerShell 7 to PowerShell (Local)
  • Added shortcut values for tilde key (OemTilde)
  • Added timer close to View Password
  • Addeds dynamic resolution support for FreeRDP
  • Improved DVLS authentication
  • Fixed:
  • Fixed issue resolving $PASSWORD$ variable
  • Fixed issue with custom OTP key field staying revealed if revealed once
  • Fixed issue with Read/Write offline mode in user vault not working as expected
  • Fixed issue with spaces in SecureCRT password
  • Fixed new entries with virtual folders in Hub Business that didn't go in the folders when they were not already existing
  • Fixed some issues with FreeRDP
