Remote Desktop Manager 2022.2.16.0
  • Version 2022.2.16.0 (July 11th 2022)​
    DVLS 2022.2 is required with this version
    • Added an error message to passportal when the password fetching fails
    • Added an option to enable compatibility mode for file dialogs
    • Added Batch Grant Access to system settings permissions
    • Added Case Sensitive and Partial Password search to password usage
    • Added different connection modes to quick connect
    • Added force user override migration setting and GPO
    • Added prompt for folder if different on revert changes
    • Added send secure message support for Hub Business
    • Added support for environment variables in SSH Shell
    • Allow to specify password age of an entry
    • Changed URL verification in Website and Website (legacy) entries when using variables
    • Improved the DVLS security dashboard checks and recommendations
    • Fixed a focusing issue when starting a website entry with a Typing Macro event
    • Fixed an issue causing a data source disconnection on lock
    • Fixed an issue preventing a user from editing the user vault settings
    • Fixed an issue when exporting grid images with Excel
    • Fixed bug with dashboard out of sync with tree view
    • Fixed issue were existing WinSCP were using 21 instead of default port
    • Fixed issue where changing datasource and answering yes to a documentation save prompt would cause an error
    • Fixed issue where custom port was not working properly when using inherited or linked host in a RDP connection
    • Fixed issue where minimizing with Windows + D would ignore the application lock
    • Fixed issue where Password Hub credential entry would not display all your vaults
    • Fixed issue where you could not save .html documents as a welcome page
    • Fixed issue with CSV synchronizer not supporting templates anymore
    • Fixed issue with RDP saving previous host when changing from custom to inherited or linked
    • Fixed OpenConnectionMode console switch not working when the entry is set to external
    • Fixed sessions not restarting after an RDM update
    • Fixed with closing VPN and append OTP to password
Remote Desktop Manager 2022.2.17.0
July 14, 2022
  • Fixed an issue where Windows Hello wouldn't be taken into account when using the ForceLogin GPO
  • Fixed data source wiping issue due to load sensitive being missed
  • Fixed issue with RDP host value being invalid
  • Fixed issue with Url loosing parameters when using external
  • Fixed possible crash with RDP
  • Fixed resolving for macros Password Hub Business data source
Remote Desktop Manager 2022.2.20.0
  • Version 2022.2.20.0 (August 10th 2022)​
    DVLS 2022.2 is required with this version (only if you're already using DVLS)
    • Improved Duo 2FA workflow when canceling
    • Improved the Hub Business performance with large vault
    • Modified multiple CSV importers to import Website entries instead of Website (legacy) entries
    • Updated Dashlane CSV import to reflect current fields
    • Fixed a potential VMware dashboard load issue
    • Fixed broken embedded MSRDC ActiveX connection with latest release
    • Fixed credential linking issue with OTP in Juniper Junos Pulse VPN
    • Fixed display issue in terminal
    • Fixed exception caused by double click on root dashboard's repository selection
    • Fixed infinite loop when selecting favorite on launch
    • Fixed issue where Default value of "Before connection message prompt mode" didn't work as expected
    • Fixed issue where resurected documentation would never shown on the root until you restart RDM
    • Fixed issue with Session Recording visibility not changing in website entries
    • Fixed issue with website conversion losing equivalent URLs values
    • Fixed possible crash when closing RDM
Remote Desktop Manager Free 2022.2.21.0​
August 30, 2022
  • Added missing fields when converting from Website to Website (legacy) and Website (legacy) to Website
  • Fixed Edge losing focus when using a delay on a typing macro
  • Fixed missing default actions and UI issues with Folder Read Only
Remote Desktop Manager Free 2022.3.23.0​
November 21, 2022
  • Fixes:
  • Fixed an issue when the Overview tab page is hidden
  • Fixed an issue with Sophos and Open VPN
  • Fixed an issue with the Webview2 freezing the workstation
  • Fixed data entries overriding their group tab settings when viewed
  • Fixed third party licenses accessibility
  • Removed documentation deleted history from Hub data source
  • Removed User groups selection from Sending Secure Message for DVLS
Remote Desktop Manager Free 2022.3.28.0
Improvements:
  • Added missing progress bars for batch edits
  • Added OTP handling to several terminal and clients
  • Added possibility to change default working directory to Powershell session
  • Added support for private mode with Edge external mode
  • Added warning when saving a license with no one assigned
  • Improved Keyword search quick filter
  • Improved license management window for clarity
  • Improved policies handling with Local Group Policy Editor
  • Show warning message to only display if customized
Fixes:
  • Fixed a possible encryption race condition issue
  • Fixed a possible issue with the UI in Terminal Services
  • Fixed an issue with Hub Personal documentation search
  • Fixed crash in CSV import wizard
  • Fixed duplicated DVLS data source keeping the old refresh token
  • Fixed issue when loading specific settings using "My privileged account" for the credentials
  • Fixed issue where VPN Mode was lost when changing VPN Type
  • Fixed issue with "local echo" in Telnet
  • Fixed navigation options filter issue
  • Fixed null reference exception in CyberArk account selection
  • Fixed possible crash in FreeRDP when no username is configured
Pobieranie:
Remote Desktop Manager Free 2022.3.31.0​
January 17, 2023
  • Added support for TLS 1.3 with Bitwarden
  • Allow for Connection Type sorting in Entry Security Analyzer
  • Fixed an issue with SSH Terminal events called more than once during authentication
  • Fixed an issue with unnecessary prompts when going online
  • Fixed CSV import for visionAPP (ASG)
  • Fixed import issues with certain characters for .csv
  • Fixed Internet Explorer embedded doesn't open pop-up window
  • Fixed issue with user specific settings in Hub when multiple entries had the same ID
  • Fixed port saving in WinBox
Remote Desktop Manager Free 2023.1.18.0
Version 2023.1.18.0 (March 30th 2023)
DVLS 2023.1 is required with this version (only if you're already using DVLS)
Improvements
  • Changed value for Search Ribbon shortcut to "when not in session" by default
  • Forced wait progress to "window" when downloading custom installer
  • Improved support for Azure Bastion
Fixes
  • Fixed a possible context menu issue in HDPI
  • Fixed custom images not visible on all entries for non-advanced datasources
  • Fixed error when doing a multi vault export and added result view
  • Fixed maximize minimize not working in documentation
  • Fixed some issues with KeePass
Pobieranie:
Remote Desktop Manager 2023.1.20.0
  • Minor UI fixes
  • Reverted to old custom image behavior for advanced datasources
  • Fixed ADMX file for Microsoft Intune
  • Fixed date pickers not using the right datetime format
  • Fixed the "hide user groups" usage in the user selection
  • Fixed title showing in attachment on delete
  • Fixed UI to show remote credential guard setting properly
Remote Desktop Manager 2023.1.23.0
  • Version 2023.1.23.0 (April 20th 2023)​
    • Added folders to Entry and Password Analyzers
    • Added support for opening pages with Azure Conditional Access in embedded Edge
    • Improved Password generator copy to clipboard
    • Fixed Advanced Search issues with sub entries
    • Fixed domain not supported in username format for iDrac entries
    • Fixed import of a single, linked RDP file
    • Fixed Open console setting not saving on RDP entries
    • Fixed possible issues with credential resolving in RDP
