Remote Desktop Manager Free 2023.2.17.0​
July 18, 2023
  • Added a warning for the removal of MySQL/MariaDB datasources
  • Added offline documentation to Hub Business
  • Added setting for "show IP address" in terminal service console
  • Added warning for MySQL and MariaDB being unsupported starting with RDM 2023.3
  • Allow rename user on SID mismatch on SQL Server data source
  • Disable the verbose option for putty when the connection type is not PLink
  • Hub improve load connections performances
  • Improved error message handling when missing View Password right
  • Improved the custom report
  • Improved the file explorers to start in the default directory configured on the server
  • Separated folders and entries in Password Safe
  • Updated the Pleasant Password API version from v4 to v6
  • Use same post login interface for telnet as ssh entry
  • Fix password history not showing after import in Hub Personal
  • Fixed "Open Embedded SFTP/SCP" not keeping all of the original entry's data
  • Fixed "Wait for IP on adapter" prompt not closing
  • Fixed connect via gateway not working with a different connection type
  • Fixed custom fields not refreshing
  • Fixed Devolutions Gateway VPN showing up in unsupported datasources
  • Fixed DNS not resolving host properly
  • Fixed DVLS checkout ticketing system
  • Fixed DVLS PAM checkout not working on an SQL datasource
  • Fixed failed login on Cyberark privilege cloud
  • Fixed Hub PAM credentials checkout not working on DVLS datasources
  • Fixed issue sending password for Kitty application
  • Fixed issue using DVLS PAM in the user vault
  • Fixed issue where template group could be created without name
  • Fixed issue where the privileged account credential type wasn't available in the DVLS user vault
  • Fixed issue with template macros in system vault
  • Fixed issues with Cisco ASDM
  • Fixed jump mode in datasources without user vault
  • Fixed multiple attachment issues in Hub
  • Fixed recurrent calls in get vault for Hub
  • Fixed sorting not working correctly in Network Scan tool
  • Fixed sub entry adding from template
  • Fixed various miscellaneous issues
Remote Desktop Manager Free 2023.2.18.0​
July 20, 2023
  • Improvements:
  • Added help button for Bitwarden that links to documentation
  • Enabled embedded mode for Winbox with a warning
  • Improved Active Directory wildcard searches
  • Removed "override entry name" from template groups since the option was never supported
  • Fixes:
  • Fix for "Allow Drag and Drop" user setting not working
  • Fix for empty security group dropdown
  • Fixed custom fields name issues in column header
  • Fixed folder selection after moving folder
  • Fixed issue with final onboarding step prompt
  • Fixed issue with parent variables with "open with template"
  • Fixed issue with reconnect causing a crash
  • Fixed local path issues in file explorers
  • Fixed looping issue in file explorers
  • Fixed possible crash with PAM dashboard
  • Fixed saving OpenVPN and Sophos as templates without restrictions
  • Fixed SQLite seeing Temporary Access settings
  • Tentative fix for possible crash when switching vaults
