Total Commander - wersje rozwojowe
Total Commander 9.0 beta 14
Total Commander 9.0 beta 14 is available now!
You can download it from
This is a public pre-release version! Please be careful!
This time there are also some new functions:
- Secure FTP (FTPS) and HTTP (HTTPS) now work without OpenSSL DLLs! Beta 14 uses functions from Windows found in the file Secur32.dll.
Please report bugs here in the TC 9.0 beta bug report forum, ONE BUG PER MESSAGE! If you reported a bug for beta 1/2, please check whether it has been fixed! There should be a hint in the readme.
IMPORTANT: Currently the new functions are available only in English, Chinese, Czech, Danish, Dutch, German, Italian, Norwegian, Polish, Romanian. More languages will be added soon.
Here is a list of the most important additions:
A list of all corrections, also for previous versions, can be found in the history file.
As usual, the update is free for all registered users.
Christian Ghisler
32 Bit:
64 Bit:
32/64 Bit:
Total Commander 9.0 beta 15
21.09.16 Release Total Commander 9.0 beta 15 (32/64)
Total Commander 9.0 beta 15 is available now!
- New placeholder in multi-rename tool: Converts all composite characters (e.g. separate a and ^) to precomposed characters (â).
- New SSL/TLS implementation: support TLSv1.1 and TLSv1.2, and report the protocol in the connection log.
- Define view mode commands when switching away from a view mode to a different mode. Separate by | (vertical line), e.g. cm_100percent|cm_50percent
- The following internal commands now accept parameters 0 (toggle, default), 1 (true), and 2 (false), except in main menu (* stands for LEFT, RIGHT, and SRC): CM_VERTICALPANELS, CM_*THUMBS, CM_*BYNAME, CM_*BYEXT, CM_*BYSIZE, CM_*BYDATETIME, CM_*UNSORTED, CM_*NEGORDER.
IMPORTANT: Currently the new functions are available only in English, Chinese, Czech, Danish, Dutch, French, German, Italian, Norwegian, Polish, Romanian, Slovenian, Spanish. More languages will be added soon.
Christian Ghisler
21.09.16 Fixed: View modes: Commands defined in view modes were always applied to the left panel only (release beta 15 rev a) (32/64)
21.09.16 Fixed: Do not watch notifications for network drives, it can hang the watch directory thread (32/64)
21.09.16 Fixed: Re-signed all included EXE/DLL files with separate SHA-1 (re-issued) and SHA256 certificates (32/64)
21.09.16 Added: Message dialog with checkbox (e.g. shown on multi-rename name collisions): Show icon, make it look more like the standard MessageBox dialog (32/64)
21.09.16 Added: For the sorting commands like CM_SRCBYNAME, add parameter 4 to sort by additional columns, e.g. CM_SRCBYSIZE 5 adds sort by size, ascending (32/64)
20.09.16 Added: The following internal commands now accept parameters 0 (toggle, default), 1 (true), and 2 (false), except in main menu (* stands for LEFT, RIGHT, and SRC): CM_VERTICALPANELS,CM_*THUMBS,CM_*BYNAME,CM_*BYEXT,CM_*BYSIZE,CM_*BYDATETIME,CM_*UNSORTED,CM_*NEGORDER (32/64)
20.09.16 Fixed: Make sure that when rubberband selection starts in one file panel, it will remain there (32/64)
20.09.16 Fixed: FTP: avoid infinite retries if both PASV and PORT mode fail due to server misconfiguration (32/64)
20.09.16 Fixed: Auto-switching to thumbnails view in directory with images -> one of the images would sometimes not get a thumbnail (64)
20.09.16 Added: Execute view mode commands also when switching between 2 tabs with different view modes (32/64)
20.09.16 Added: Define view mode commands when switching away from a view mode to a different mode. Separate by | (vertical line), e.g. cm_100percent|cm_50percent (32/64)
18.09.16 Added: Support Ctrl+Q (quick view panel) also during quick search. May cause problems like lost cursor with some plugins (32/64)
18.09.16 Fixed: Open background transfer manager without starting any operation in it, then close TC -> warning about running background operations (32/64)
18.09.16 Fixed: Number of folders wasn't updated in footer when network shares were added after reading the network neighborhood (delayed reporting) (32/64)
18.09.16 Fixed: Do not show any network shares in Network Neighborhood (as in TC 8.x) when Allowed= doesn't contain the backslash (32/64)
18.09.16 Fixed: Look of horizontal separators in Configuration - Options - Fonts (32/64)
18.09.16 Added: Multi-rename tool: On Windows NT-based systems, the new placeholder at the start of the new name field converts all composite characters (e.g. separate a and ^) to precomposed characters (a with accent) (32/64)
18.09.16 Fixed: Disable themed caret (cursor in listboxes) by default if WindowBlinds is running. Otherwise no cursor at all may be shown (32/64)
16.09.16 Fixed: Free space on drive was shown delayed on startup (32/64)
16.09.16 Fixed: Lister: Viewing file with BOM (UTF-16 or UTF-8): Cursor would sometimes not show up at all until it is moved, e.g. until a cursor key is pressed (64)
16.09.16 Fixed: HTTPS downloads could hang at the end when not using OpenSSL (due to incorrect error handling) (32/64)
15.09.16 Added: New SSL/TLS implementation: support TLSv1.1 and TLSv1.2, and report the protocol in the connection log (32/64)
32 bit:
64bit:
32/64 bit:
Total Commander 9.0 beta 16
Total Commander 9.0 beta 16 is available now!
This time there is just one new function:
- cm_100percent now accepts a parameter: If >0, it sets the panel width (in percent) of the active panel. If <0, it sets the panel width (in percent) of the left window (1..100%). Example: cm_100percent 70
Most included languages are updated now, except for Swedish and Korean!
Christian Ghisler
28.09.16 Release Total Commander 9.0 beta 16 (32/64)
28.09.16 Fixed: Configuration - Options - View mode, Apply after deleting a mode -> revert view modes on tab to 0 (default) if a mode was deleted or inserted before that mode (32/64)
28.09.16 Fixed: Configuration - Options - View mode, Apply after deleting a mode -> revert view modes on tab to 0 (default) if number higher than available view modes (32/64)
28.09.16 Fixed: Crash in quick search when trying to enter a search text while TC was frozen (32/64)
28.09.16 Fixed: Windows 10 bug: Alt+Tab away from Configuration - Options - Misc after clicking on a disabled control in that dialog caused redraw errors (64)
28.09.16 Fixed: Change Attribute dialog: Accept date and time where there is more than one separator between each value, e.g. 10//22////2016 (32/64)
28.09.16 Fixed: Do not use semi-transparent bitmaps with alpha channel on Windows 2000 when resizing, otherwise the icons could get a black background (32/64)
28.09.16 Fixed: Use 16-bit colors for icons on Windows 9x/ME/2000, otherwise dimmed icons look ugly, dithered with white instead of dimmed (32/64)
28.09.16 Fixed: File list icons could have black background on Windows 2000, need to use old scaling method without alpha blending (32/64)
28.09.16 Fixed: Do not open notification about new version while the startup screen or settings dialog are open (32/64)
27.09.16 Fixed: Starting TC with locked bitlocker drive on current tab and BitlockerAlwaysDecrypt=1 option could lead to infinite asking for password if user didn't enter it (note that 32-bit works differently, it switches to c:\) (64)
27.09.16 Fixed: Vertical button bar: Show icons centered also when button size<small icon size, e.g. 15px/16px (32/64)
27.09.16 Fixed: Switch away from tab with "locked but directory changes allowed", while not in locked root -> tab color was restored to the locked root, but not the tab icon (32/64)
26.09.16 Added: cm_100percent now accepts a parameter: If >0, it sets the panel width (in percent) of the active panel. If <0, it sets the panel width (in percent) of the left window. Example: cm_100percent 70 (32/64)
25.09.16 Fixed: Switching to server with command line: cd \\servername requiring user name+password would sometimes show the "Reading directory" dialog in front of the login/password dialog (32/64)
25.09.16 Fixed: View modes: Right clicking on tab which wasn't active when starting TC sometimes didn't check the current view mode (32/64)
23.09.16 Fixed: Sometimes the right file panel couldn't get focused (happens when only the right panel window handle is recreated) (64)
Download:
32:
64:
32/64:
Total Commander 9.00 beta 17
PostPosted: Wed Oct 05, 2016 1:43 pm Post subject: Total Commander 9.0 beta 17 available Reply with quote
Total Commander 9.0 beta 17 is available now!
Please report bugs here in the TC 9.0 beta bug report forum, ONE BUG PER MESSAGE! If you reported a bug for older beta versions, please check whether it has been fixed! There should be a hint in the readme.
Except for Sweditsh, all included languages are updated now! Korean was translated by paid service Gengo, but the author has no knowledge of Total Commander - so if you find an error, please report it.
05.10.16 Release Total Commander 9.0 beta 17 (32/64)
05.10.16 Fixed: When entering large directories, wait with handling messages for up to 1.9 seconds - still safe to avoid freezing, but keeps keyboard input made by user (32/64)
05.10.16 Fixed: Do not watch for changes in "Computer" virtual folder when ShowExtraDrives doesn't have value 4 added (show drives with no drive letters like phones) (32/64)
05.10.16 Fixed: Remote desktop connection: Show shared drives when connecting, hide them when disconnecting (32/64)
05.10.16 Fixed: Remote desktop connection: Local drives shared via "Local resources" options were not visible in TC (WNetOpenEnum failed) (32/64)
05.10.16 Fixed: Don't try to show the bitlocker unlock dialog while the registration screen is still up (switch to local drive instead, as TC 8.x) (32/64)
05.10.16 Fixed: Button F3, F4 etc. in bottom bar could wrap to two lines when button too narrow (64)
05.10.16 Fixed: Quick search filter was lost after using file context menu, causing a full refresh by mistake (32/64)
04.10.16 Fixed: Comments: Problems copying comment from UTF-8-encoded comment file to OEM-encoded comment file on systems with codepage other than 1252 (32/64)
04.10.16 Fixed: Comments: Problems copying comment from OEM-encoded comment file to UTF-8-encoded comment file on systems with codepage other than 1252 (comment not visible, line breaks lost) (32/64)
04.10.16 Fixed: Comments: Default type set to one of the Unicode types, enter non-Unicode comment via Ctrl+Z -> last character was cut (32/64)
04.10.16 Fixed: Move file (F6) which is currently opened and locked by a program will copy the file, but deleting the original will fail -> show different error dialog (32/64)
04.10.16 Fixed: Hold down space on a file, then press Tab while space is still down -> the footer could be wrong (32/64)
04.10.16 Fixed: Missing identifiers for new commands in WCMICONS.INC (32/64)
04.10.16 Fixed: For consistency with the 32-bit version, don't drive drive icons from icon lib dimmed when hovering over them (64)
04.10.16 Fixed: Search dialog: Save "Search for" combobox when starting a search and the string has changed, not only when closing the dialog (32/64)
30.09.16 Fixed: Configuration - Options - View mode, Apply after deleting a mode -> revert view modes on tab to 0 (default) if a mode was deleted or inserted before that mode (64)
30.09.16 Fixed: Configuration - Options - View mode, Apply after deleting a mode -> revert view modes on tab to 0 (default) if number higher than available view modes (64)
30.09.16 Fixed: Folder tabs: Default view mode, toggle "Priority", click "Apply" -> icons for default view mode tabs were only changed when switching to these tabs (32/64)
30.09.16 Fixed: Folder tabs: When disabling folder tab icons, an empty placeholder was shown on tabs where a user mode icon with priority option was defined (32/64)
30.09.16 Fixed: Abort counting space in file system plugin subdirs (Alt+Shift+Enter or Spacebar) when disconnecting or closing the program (32/64)
29.09.16 Fixed: Windows 10 bug: Alt+Tab away from Configuration - Options - Misc after clicking on a disabled control in that dialog still caused redraw errors -> we need to focus a different control (list of pages) (64)
29.09.16 Added: Updated tc7z.dll and tc7z64.dll with latest dlls from 7z1603-extra.7z (7zxa.dll and x64\7zxa.dll ) (32/64)
29.09.16 Fixed: FTPS: Suggest to use OpenSSL dlls in the log window when connection fails because the operating system doesn't support session re-use (e.g. Linux with Wine) (32/64)
29.09.16 Fixed: FTP connection dialog: Automatically check passive mode option when checking SSL/TLS, it doesn't work with active mode (32/64)
32 bit:
64 bit:
32/64 bit:
Total Commander 9.0 release candidate RC1
PostPosted: Wed Oct 12, 2016 2:57 pm Post subject: Total Commander 9.0 release candidate 1 available Reply with quote
Total Commander 9.0 release candidate 1 is available now!
This is still a pre-release version, but sufficiently stable for every day use.
This version mainly fixes bugs, but also includes the new icon library for button bar and main menu, in addition to the older icon library. You can choose the library during the first start, or later via right click on one of the button bars.
Except for Swedish, all included languages are updated now! Korean was translated by paid service Gengo, but a Korean user of Total Commander is currently reviewing and updating it.
Christian Ghisler
32 bit:
64bi:
32/64 bit:
Total Commander 9.0 RC2 Release Candidate 2
October 19, 2016: Total Commander 9.0 release candidate 2 (rc2) is now available for download. This is a bugfix release. There are a lot of new features in TC9, see this forum post for the most important. This is still a pre-release version, but sufficiently stable for every day use. It includes both the old and new icons for the main menu and button bar(s)
19.10.16 Release Total Commander 9.0 release candidate 2 (RC2) (32/64)
19.10.16 Added: Separate quick view (Ctrl+Shift+Q): Show * behind "Lister" text to distinguish the quick view window from normal Lister windows (32/64)
19.10.16 Fixed: Separate quick view (Ctrl+Shift+Q) would not open maximized (after being stored via menu) (32/64)
19.10.16 Fixed: Show big link icon for LNK files (instead of default file icon with/without link overlay) when icons for EXE/LNK are disabled (32/64)
19.10.16 Fixed: Use button bar tooltips from English if there is no INC file for a language, and the command isn't in the main menu either (32/64)
19.10.16 Fixed: Search dialog showed up with narrow unresizable window on Windows 9x/ME (due to bugfix for Windows 10 on 05.09.16) (32)
19.10.16 Fixed: Show vertical button bar when using 2 panels above each other (Vertical arrangement) via menu Start - Vertical button bar -> context menu items for vertical bar were missing (32/64)
19.10.16 Fixed: Automatic column width in file panels wrong when using 2 panels above each other (Vertical arrangement) and vertical buttonbar (32/64)
19.10.16 Fixed: Hover with mouse over buttonbar, using flat unstyled buttons -> do not draw current button frame over button which is already down (32/64)
19.10.16 Fixed: Updated installer for CD version to functions of new self-extracting installer (32/64)
19.10.16 Fixed: The uninstaller didn't remove some newer files (32/64)
18.10.16 Added: New icon library for main menu and button bars is now included also in 48x48 pixel size (16x16, 24x24, 32x32, 48x48) (32/64)
18.10.16 Added: Synchronize dirs: Compare by content: Compare single files from each side by selecting just the two files and choosing "Compare..." from the context menu (32/64)
18.10.16 Fixed: Alt+F10 tree wouldn't save paths longer than about 500 characters (32/64)
18.10.16 Fixed: Dialog for choosing the default icon library: Show icons centered horizontally (32/64)
18.10.16 Fixed: Vertical button bar: Open overflow menu (bar too high), right click any item -> menu to edit main bar instead of verical bar was shown (32/64)
18.10.16 Fixed: Checkboxes in text search section of search dialog were too high, causing overlap (64)
18.10.16 Fixed: Switch from full view with custom view mode to tree -> custom background color remained below tree items (32/64)
18.10.16 Fixed: New default non-bold font was never used for new users because the installer was writing to [Configuration] -> use new font if FirstTime=0 wasn't set on first TC start (32/64)
18.10.16 Fixed: Press SPACEBAR on folder -> '?' was no longer shown in size column until the size was calculated (32/64)
18.10.16 Fixed: Some USB link cables seem to need other GUID to connect (32/64)
18.10.16 Fixed: Passing plugin name via command line no longer worked, e.g. TOTALCMD.EXE /o /r="\\\Secure FTP" (32/64)
18.10.16 Fixed: Compare by content, local file with ftp, save remote, return to TC -> panel could switch from ftp to local directory on some Windows versions (32/64)
18.10.16 Fixed: tsclient drives were sometimes not appearing when connecting to remote computer where TC was already running (32/64)
18.10.16 Fixed: No drive tips in drive dropdown combobox for tsclient drives (32/64)
18.10.16 Fixed: Icons for tsclient wrong when using icons from Explorer - use icons displayed in \\tsclient path instead (32/64)
16.10.16 Fixed: Alt+F10 tree only showed root level when using natural sorting+sort dirs by name options (32/64)
16.10.16 Fixed: Search function: Load/Save last search options (checkboxes) each time when opening/closing the search dialog, to better support standalone search (32/64)
16.10.16 Fixed: Start TC with fresh INI and without key -> dialog to choose default icon library was shown the first two times TC was started, not just the first time (32/64)
16.10.16 Fixed: Search function: Ignore "Search in" field when using ev: prefix, otherwise Everything would be called for each given start path (32/64)
16.10.16 Fixed: cm_LeftViewModeList, cm_RightViewModeList and cm_SrcViewModeList now accept a view mode number>0 or view mode name as parameter in button bar, starter menu, or internal command (32/64)
14.10.16 Fixed: Right click on tab header, open tab in other panel -> view modes were not copied. Note: Locked state will NOT be copied! (32/64)
14.10.16 Fixed: Configuration - Options - Icons: Switching from internal to Explorer drive icons only changed the drive bar and tabs, not the drive dropdown combobox (32/64)
14.10.16 Fixed: Close TC while a locked tab was the active tab, then start TC with parameters /T /L="c:\directory" -> the locked tab sometimes lost the '*', and the new tab had the wrong tab title (32/64)
14.10.16 Fixed: Left panel: Set view mode which shows/hides icon in tabs, causing the number of tab rows to change -> file panel wasn't resized correctly (32/64)
13.10.16 Fixed: Search function: Drives dialog not working in x64 version (test dialog shown) (64)
32 bit:
64 bit:
32/64 bit:
Total Commander 9.0 RC3 Release Candidate 3
PostPosted: Wed Oct 26, 2016 2:59 pm Post subject: Total Commander 9.0 release candidate 3 available Reply with quote
Total Commander 9.0 release candidate 3 is available now!
This version mainly fixes bugs. There is also a new 16x16 pixel main icon for the 64-bit version, where the text '64' can be read more easily.
Christian Ghisler
26.10.16 Release Total Commander 9.0 release candidate 3 (RC3) (32/64)
26.10.16 Fixed: Close quick search dialog when user presses Ctrl+Q, otherwise some plugins like SLister can hang Total Commander (32/64)
26.10.16 Fixed: Use old file list icons from TC8.x when wincmd.ini contains IconLib=filename.dll even if the linked name is invalid, otherwise the user cannot switch between old and new icons via settings (32/64)
26.10.16 Fixed: Synchronize dirs: Click on buttons <- -> etc. not working after double clicking on path in main window to open directory hotlist (64)
26.10.16 Fixed: Hide "Everything" search option on Windows NT4/9x/ME because Everything.exe doesn't work on these Windows versions (32)
26.10.16 Fixed: Recompiled 32-bit 7zip dll with Visual C++ 6.0 to make it work also on Windows 9x/ME (32)
26.10.16 Fixed: Unpack 7zip files: new 7zip unpacker dll could cause TC to hang in overwrite dialog if the callback was called from a background thread. Also updated 7zip dlls to 16.4.0.0 (32/64)
25.10.16 Fixed: Crash in synchronize dirs after edit, re-compare (with save), edit, then "recompare from here" (32/64)
24.10.16 Fixed: Compare by content: Extra line combobox must be disabled initially, because "show only differences" is unchecked (32/64)
24.10.16 Fixed: "LastSearchOptions" was still saved to wincmd.ini when TC was closed, it should only be saved when the search dialog is closed (64)
24.10.16 Added: Main icon: Made text "64" on the 16x16 pixel icon larger, better readable (64)
24.10.16 Fixed: Create checksums: Sort files differently (by directory, then by name) when creating checksums in branch view (32/64)
24.10.16 Fixed: Create checksums: Overwrite dialog was shown by mistake when getting checksums of several files in same folder with option "separate checksum files for each directory" (32/64)
24.10.16 Fixed: cm_SrcViewModeList didn't accept view mode names as parameter, only view mode numbers (32/64)
24.10.16 Fixed: Show context menu item to show vertical button bar also when right clicking on splitter panel between 2 file panels above each other (32/64)
24.10.16 Fixed: Splitter panel between the two panels: Make double click easier by not moving it on the first mouse down (32/64)
23.10.16 Fixed: Auto update check function: Added possibility to disable auto update checks, or set longer interval via auto-update server response (32/64)
21.10.16 Fixed: Button bar: Hovered button was 1 pixel too low when not using themed buttons (32/64)
32:
64:
32/64:
helium
16 Czerwiec 2010
Total Commander 9.0 RC4 (November 2, 2016)
02.11.16 Fixed: Compare by content: "Only show differences" must be disabled before recomparing, e.g. when file was changed externally, or user chooses different file encoding (32/64)
02.11.16 Fixed: Opening files/programs with ENTER: Do not resolve links/reparse points pointing to complete paths (only to relative paths, except when faulty IE10 is installed), otherwise the file may no open (32/64)
02.11.16 Fixed: Default icon library for button bar was set to other than wcmicons.dll -> revert to wcmicons.dll when the other dll is no longer available (32/64)
02.11.16 Fixed: Update quick view window while quick search is up -> temporarily set focus in active panel to prevent hang in plugin SLister. Closing quick search on Ctrl+Q no longer needed! (32/64)
01.11.16 Fixed: Main menu: When additional icon dlls have their own inc file, it will be used instead of wcmicons.inc for the entire main menu (32/64)
01.11.16 Added: Configuration - Button bar: additional icon dlls can now have their own inc file. If the index differs from the wcmicons.inc file, the icon will be locked to that dll (doesn't change automatically when switching to other dll) (32/64)
01.11.16 Fixed: Move view mode -> view modes assigned to tabs below that position were reverted to default only in active panel (32/64)
01.11.16 Fixed: Delete view mode -> view modes assigned to tabs below that position were reverted to default only in active panel (32/64)
01.11.16 Fixed: Delete view mode active in current tab, click on "Default" view mode, then "Apply" -> current tab view mode was sometimes not reverted to the default (32/64)
01.11.16 Fixed: Ctrl+PageDown could no longer be used to enter archives with no extension (32/64)
31.10.16 Added: Get file details (size, time, attributes) from Everything 1.4 or newer via new RPC call if available (32/64)
30.10.16 Fixed: Everything dlls are no longer needed, replaced by internal code calling the Everything service directly. Necessary because the dlls didn't support the new Everything 1.4 functions yet (32/64)
30.10.16 Fixed: Open archive below a junction/reparse point -> the path changed to the junction target, which would only be needed for opening files/folders externally (32/64)
30.10.16 Fixed: Updated to latest unrar.dll from
, the included one was still a beta version (5.40 beta 2 -> final) (32/64)
30.10.16 Fixed: Configuration - Options - Color: Draw grayed text in comboboxes if they are disabled (32/64)
30.10.16 Fixed: Also disable (draw grayed) the labels in Configuration - Options - View modes for disabled comboboxes (32/64)
30.10.16 Fixed: Synchronize dirs: Click on buttons <- -> etc. sometimes still not working after double clicking on path in main window to open directory hotlist -> open hotlist only on mouse up event (64)
Total Commander 9.0 RC 5
Fixed: Reduced automatic update checks to once per day, ramdomly after 0h9h morning to better distribute the server load (32/64)
Fixed: Various problems watching for mobile device arrivals/removals, eg USB devices disappearing from Alt+F1 list, wrong labels etc (32/64)
Fixed: Synchronize with certain archives, option "Only selected" checked -> recompare after sync gave empty results because the selection was lost (32/64)
Fixed: Further reduced CPU usage of main thread, caused by a timer which shouldn't always be running (32/64)
Fixed: Archive where deeper directories are stored before others, eg /dir1/dir2 before /dir1 -> timestamp for /dir1 was shown incorrectly (32/64)
Fixed: Automatically changed view mode was lost on tab with "locked but dir changes allowed" after 2 or more directory changes and restarting TC (32/64)
Fixed: Configuration - Options - View modes: Never apply current view mode in configuration dialog to target panel, only to source panel (32/64)
Fixed: Configuration - Options - View modes: Only apply auto view mode filter to current tab when on "Auto Switch Mode" page (32/64)
Fixed: Configuration - Options - View modes: Try to preserve previous view modes on tabs even when deleting or re-ordering view modes (32/64)
Fixed: Directory hotlist, choose item with dirs for both sides -> separate tree for inactive panel wasn't updated when using 2 separate trees (32/64)
Fixed: Context menu for file, press hotkey which doesn't exist in the menu -> close the context menu, as in TC 32-bit (64)
Fixed: Catch exception "Printer selected is not valid" in "Print" - "File list" dialog box (32/64)
Fixed: Search via "Everything" 13x and older 14x caused access violation when no file/folder was found with the given search string (32/64)
Fixed: Themed listbox cursor was drawn in footer (directly below file list) during quick search (32)
Fixed: Ctrl+Q quick view in archive on pdf file not showing anything while quick search dialog was open (32/64)
Fixed: Quick view in archive not working when invoking cm_SrcQuickview with mouse (OK via command line or hotkey) (32/64)
Fixed: Shift+F4 always created a new file when entering a name without extension, even when the file already existed (32/64)
Fixed: The following option didn't work in 64-bit: Main menu: When additional icon dlls have their own inc file, it will be used instead of wcmiconsinc for the entire main menu (64)
32bits
64bits
Total Commander 9 (beta RC6)
16.11.16 Release Total Commander 9.0 release candidate 6 (RC6) (32/64)
16.11.16 Added: Update check function now sends user to
when there is a new version (32/64)
16.11.16 Fixed: Reduced maximum width for maximized lister window to 29900 pixel (64-bit)/16000 pixel (32-bit) in the hope to fix a (not reproduced) bug in "snap to top" function (32/64)
16.11.16 Fixed: Catch floating point exceptions also when loading Lister plugins, to fix crash in Imagine (32/64)
15.11.16 Fixed: Current tab color was sometimes saved incorrectly when closing TC (32/64)
15.11.16 Fixed: Crash in function cm_ShowFileUser when releasing a buffer. Note: Function requires that TC is run as administrator (32/64)
15.11.16 Fixed: Environment variables were not working in [buttonbar] DefaultLib entry (32/64)
15.11.16 Fixed: Properties of files inside a ZIP archive: Show method 95 as "LZMA(XZ)" instead of just 95 (32/64)
15.11.16 Added: New tcmdlzma.dll and tclzma64.dll version 16.4.0.0, compiled from official 7zip sources, used for lzma compressed ZIP files (32/64)
15.11.16 Added: New method to download key directly to TC directory (32/64)
15.11.16 Fixed: Ctrl+N, https download was not working with new sChannel library when using a http proxy (32/64)
32 bit:
64 bit:
Total Commander 9.0a RC 2
Fixed: Multi-rename tool retried with 10000 different target names if the source file was locked by another app, slowing down the rename function
Fixed: Lister, search function: Allow to search for OEM-specific characters like the line drawing characters in OEM/DOS mode
Fixed: Internal associations could not longer be defined for *.url files
Fixed: Configuration - button bar: Upper preview window (entire bar) didn't show icon if the icon file name was given in double quotes
Added: Content plugins: "size" field now supports 4 additional types: bkMGT, bkMGT2, bkMG3, bkMGT3: T is with Terabytes, 3 is 2 digits after the decimal point (and at least 1 before it)
Fixed: Content plugin field selection dialog: Right click on plugin field - "Copy to clipboard" was not working
Fixed: Brief view: Extension could switch from aligned to attached to file name when making window smaller
Fixed: Quick search filter was lost when deleting files from archive
Fixed: Faster loading of directories (especially on network shares) with option "Overlay icons" enabled, by moving the name parsing to the background thread
Fixed: Lister: could not copy OEM text to clipboard in binary and hex mode, it was copied as ANSI text
Fixed: Hex search in Lister not always working with OEM font set, and "Respect case" not checked
Added: The replacement of the Photos app with Windows Image Viewer can now be disabled in Files - Associate With..., the option is only shown for affected extensions like jpg
Fixed: Search with 'Everything': Detect versions older than 1.3 and warn user that version 1.3 or newer is needed
Fixed: Dialog box for choosing the default icon library: Automatically check second radio button (lower icon lib) when user chooses library from dropdown combobox
Fixed: Dialog box "Drive not found" was using a very small font size on high DPI devices
Fixed: Trying to drag files from WindowsFonts to other program made TC unresponsive to mouse clicks; the actual drag problem cannot be fixed because Fonts stores the files for a virtual folder (64)
Fixed: Do not remember position of separator between the two file panels when closing separate quick view window
Added: wincmd.ini, UseEverythingInstance option now supports environment variables
Fixed: Classic theme: Multi-rename tool buttons "+" and "#" did not show cyrillic characters, just ???? (64)
Fixed: FTP connection on tab: When drive letters are shown on the tab, change # to connection number when the connection on that tab is established
Fixed: FTP connection on locked tab (with dir changes allowed) not working: Couldn't switch to that tab with mouse click, click on "" didn't go to locked dir, restarting TC with that tab in foreground changed title. Note: after restarting, click on tab title to reconnect
Fixed: Reload shield overlay icon when user changes icon size in file list
32bits
64bits
Total Commander 9.0a RC 3
Fixed: Dimmed icons (for hidden files) were drawn incorrectly on Windows 2000 and older if the background color wasn't white (32)
Fixed: Lister, html view: was not recognized as UTF-8 encoding header (32/64)
Fixed: Search function: When saving search and overwriting an existing search with different upper-/lowercase characters, there was a (correct) overwrite warning, but the search appeared twice in the list (64)
Fixed: When preloading icons from system image list, draw the icon already in the background thread (hidden), because the icon seems to be loaded only when drawn (32/64)
Fixed: F6 move: Skipping empty dirs by appending |** to second input line didn't work when moving within the same drive (32/64)
Fixed: Hide "Themed cursor" checkbox in configuration dialog on systems older than Windows XP (32/64)
Fixed: Separate quick view window was closed when choosing directory from directory hotlist or history in other panel (32/64)
Fixed: Drag&Drop to other file panel not possible while separate quick view window was shown (32/64)
Fixed: Alt+F5 pack dialog was shown on wrong (primary) screen when the last used packer was a plugin (caused by focus change) (64)
Fixed: Content plugin field selection dialog: extra text (xxx) after size field units wasn't removed when adding a field (64)
Added: wincmdini [Configuration] SkippedFileCopy=100 or more: Option to set a different delay (in ms) at start of a file operation during which a user can be asked whether he wants to overwrite a file (32/64)
Fixed: Delay-load Windows drive icons when not using the drive buttonbar Disable via wincmdini [Configuration] LoadDriveIconsInBackground=0 (32/64)
Fixed: Internal command SELECTFILES (and also SELECTFILESB, SELECTFILESD etc) didn't work with saved selections in the form >Saved_selection any more (32/64)
32bits
64bits
andhla
20 Wrzesień 2015
Total Commander 9.10 beta 1
New functions in Total Commander 9.10:
User interface:
  • Support for multiple screens with different densities (DPI) per screen on Windows 10 (requires latest release version, "Creators Update", or newer).
  • Support for Windows 10 fall Creators Update, mainly OneDrive online only file support
  • Set font quality (e.g. force antialiasing on/off)
  • Support new pseudo environment variables from values described
    - just leave out the FOLDERID_ prefix, e.g. %$AccountPictures%
File operations:
  • "New folder" (F7) can now use the same placeholders as the multi-rename tool (e.g. date+time), and create multiple directories in one step using a counter
  • "New text file" (Shift+F4) now supports the same placeholders as the multi-rename tool
  • "New text file" (Shift+F4) now also works in archives, on FTP servers, and with file system plugins
  • Option to use latest "Everything" tool in Alt+Shift+Enter/Spacebar free space calculations
  • Internal 7zip unpacker: Support background unpacking
Lister:
  • Support touch screen scrolling+text selection
  • Support Unicode names when loading images via Irfanview (needs new Unicode version of Irfanview)
Compare by content:
  • Set width in binary mode to 8, 16, 24 or 32 bytes
Multi-rename tool:
  • New placeholders for inserting current date+time
32bits
64bits
andhla
20 Wrzesień 2015
Release Total Commander 9.10 beta 2 (32/64)
Fixed: Couldn't delete an NTFS link in a protected directory like "Program files" pointing to a file if the target file was deleted (32/64)
Fixed: Compare by content: "Save as" dialog had wrong size on secondary screen with different DPI (32)
Fixed: Main configuration dialog: Fixed problems with font sizes when moving dialog box between different dpi screens (32/64)
Fixed: Lister (F3) could start with wrong font size on Windows 10 Creators Update when its position wasn't saved by the user yet (64)
Fixed: Lister (F3) could start with tiny window on Windows 10 Creators Update when its position wasn't saved by the user yet (32)
Fixed: Search for office xml in archives could sometimes cause a crash, depending on the searched office file contents (32/64)
Fixed: Search for office xml in archives -> zip file containing .docx/.xlsx/etc. files would remain opened/locked after the search ended (32/64)
Fixed: Ctrl+Right/Left arrow no longer jumped to file under the cursor in the target window (32/64)
Fixed: F7 and Shift+F4: Allow to create numbered folders/files also in specified path, e.g. <1-5>c:\dir\test[C] or <1-5>[%temp%]\test[C] (32/64)
Added: Environment variable placeholders: Append backslash to paste only last part of path, other char to replace \ with, e.g. [%TEMP%\] -> temp, [%TEMP%_] -> c_temp
Fixed: Synchronize dirs: Icons on directional buttons and checkboxes between the two sides were not scaled on higher dpi screens (32/64)
Fixed: Updated the frequently asked questions (FAQ) in the help file (32/64)
Fixed: Only use user-defined font for groupbox top position calculation on secondary screen with different dpi than main screen (64)
Fixed: Limit width of custom message dialog (e.g. when showing disk full error) to 2/3 of the current screen width - break longer lines in the middle at spaces or backslashes (32/64)
Fixed: Search with ev: prefix (Everything unfiltered search): ignore the current directory even when a backslash is present, e.g. "ev:tv/ artist" to find files containing "artist" in dirs ending with "tv" (32/64)
Fixed: Unpack 7zip file with internal 7zip unpacker (no 7zip plugin installed) via menu or Alt+F9 -> no "Background" button was shown (32/64)
Fixed: Decode MIME-Encoded files: Still problems with nested boundaries in MIME files (32/64)
Fixed: Standalone Synchronize dirs (started via /S=S parameter): tab headers were not themed (64)
Fixed: Copying subdirs from OneDrive not working with IgnoreLinks option set on Windows 10 Fall Creators Update (32/64)
Fixed: Deleting non-empty subdirs from OneDrive not working on Windows 10 Fall Creators Update (32/64)
Added: Help for F7 and Shift+F4: Examples for placeholders, especially for multi-item creation like <1-10>[C:2] (32/64)
Added: Support environment variables in multi-rename tool, F7 and Shift+F4: [%USERNAME%] or [%USERNAME%1-5] (32/64)
Fixed: Position and size of standalone compare dialog wasn't saved on exit (64)
Fixed: Position and size of standalone search/sync/compare dialog was wrong on high DPI screens (32)
Fixed: Font in hint window (tooltip) for files and buttons too small on Windows 10 Creators Update, on main screen only (64)
Fixed: Main settings dialog: Line height in list on the left (list of settings pages) not correct after changing DPI (32)
Fixed: Configuration - Options - Fonts: DPI value wasn't stored correctly any more on Windows versions older than Windows 10 Creators Update (32/64)
Fixed: "Compare by content": Label "bytes" was badly aligned with combobox (it's not possible to align it 100% correctly for all fonts) (64)
Fixed: "Compare by content": Label "bytes" was not translated - use string 1330 (32/64)
Fixed: "Search in separate process" dialog, list of text search plugins: checkboxes were missing (32/64)
Fixed: "Search in separate process" dialog, list of text search plugins: lines too high (64)
Fixed: "Search in separate process" dialog: Lines in search results were too high (32/64)
Fixed: cm_switchlongnames not working with wincmd.ini set to read only (32/64)
Fixed: New help topic "Environment variables" had some problems with line breaks (32/64)
Fixed: Auto update check function would report beta versions even with AutoUpdateCheck=2, which should report only release versions (32/64)
32bits
64bits
andhla
20 Wrzesień 2015
Release Total Commander 9.10 beta 3 (32/64)
Fixed: Lister: menu line spacing wrong when using OverrideDPI options (64)
Fixed: Comments didn't work for file names longer than 127 characters from UTF-16 Unicode files (32/64)
Fixed: Icons in tabs: Icons from desktop.ini and from custom view modes different when using 32x32 icons in file list (32/64)
Fixed: Configuration - Button bar: Icon wrong for buttons other than the current one when icon name didn't have extension (32/64)
Fixed: Files - Internal associations: Only standard icon was shown for programs with no extension, e.g. cmd /c instead of cmd.exe /c (32/64)
Fixed: Always show link overlay for junctions (also pseudo OneDrive junctions) even when overlays are disabled (32/64)
Fixed: Synchronize dirs: Didn't work with directories in OneDrive folder on Windows 10 Fall Creators Update preview (32/64)
Fixed: Synchronize dirs: Load also larger (24x24 and 32x32) custom equal icons if available from content plugins (32/64)
Fixed: Unpack 7zip file with internal 7zip unpacker: Couldn't pause operation when in background (32/64)
Fixed: Help file: Column alignment in samples in help for F7/Shift+F4 (32/64)
Fixed: Scaling of fonts in file hints was different from 32-bit version (64)
Fixed: F7 and Shift+F4: Combobox in 32-bit and 64-bit versions was set to different dropdown count (10 and 100). Set to 30 for both (32/64)
Fixed: FTP toolbar: Wrong font size in FTP log list when using a different encoding than "Western" for dialog font (64)
Fixed: Synchronize dirs: icons for unequal [=/=] and unknown [?] were shown incorrectly (32/64)
32bits
64bits
