DziadDalf
DziadStos'u i al'cioropatoli
cFosSpeed 10.11 build 2246
! Removed support for Windows XP and Windows Vista. Now, the minimum
supported operating system is Windows 7. If you require cFosSpeed for
Windows XP or Vista, you can download version 10.10.2238 from
- Switched off TCP checksumming in cFosSpeed. If you desire, you can switch
it back on by using "spd gset checksum_tcp 1 -save", but it is quite
time consuming and its use is marginal.
