DziadDalf
DziadStos'u i al'cioropatoli
cFosSpeed 9.65 build 2166
x Fixed a rare hang in speedsrv.dll. Thanks to Willian Oliveira.
- The service spd.exe will now automatically restart if crashed. If you want
to stop it, you need to use the "sc stop cfosspeeds" (that's "cfosspeed" with
an "s") command from an admin console.
DziadDalf
cFosSpeed 9.65 build 2172
x Fixed a problem with "Next" button for de-installation.
cFosSpeed 9.65 build 2171
+ If your router supports UPnP, the values of maxrx, maxtxacked and maxtxraw
are checked against the router provided values. If our values are too high,
they are limited to the ones provided by the router.
x When uninstalling the program, clicking "Next" on the welcome screen had
no effect.
DziadDalf
cFosSpeed 10.03 build 2191
+ UPnP max upstream/downstream values of 525 kbytes are now ignored for cable
users. This workaround should fix the "525k" bug. Thanks to ayanamist
and other in the forum.
cFosSpeed 10.03 build 2190
+ You can now change the interval between route change checks by setting
routing_check_interval=XX in file global.ini, section [param] with the
value in msec as XX. The minimum value is 1000.
- cFosSpeed driver does no longer read its file locations from registry
System branch, but from SOFTWARE. If you experience start problems,
please inform us!
This should keep cFosSpeed working even after a Windows upgrade from
one major version to the next.
DziadDalf
cFosSpeed 10.03 build 2192
+ The Traffic Shaping setup now only shows adapters with supported
interfaces, ie. Ethernet or WWAN.
+ UPnP max upstream/downstream values of 64 kbytes are now ignored for cable
users as well. Thanks to pictus.
+ UPnP max upstream/downstream values of 1.25, 12.5 and 125 mbytes and very
small values are now ignored. Thanks to Mister X and liujohn.
x Corrected prioritization info for League of Legends. Thanks to F. Müller.
DziadDalf
cFosSpeed 10.03 build 2194
x Fixed missing import for XP. Anyway... People, it's time to move on.
upgrade your Windows sometime soon!
x Installer now displays a message box if the driver installation can only be
performed after a reboot.
DziadDalf
cFosSpeed 10.05 build 2200
+ The Virtual Wi-Fi can now be started by cFosSpeed automatically at system
start time. This feature can be activated in the Wi-Fi Access Point menu.
Thanks to Fernando.
x Fixed virtual adapter detection. Thanks to Georgios Nikitas.
