DziadDalf
cFosSpeed 10.11 build 2259
+ cFosSpeed may now remove more expired DNS names from the refresh list.
+ New experimental feature: setting "spd gset patch_dns_ttl XXX" enforces
a minimum DNS TTL of <XXX> seconds. This may be useful to prevent constant
DNS refreshes of names with very low TTLs.
x Fixed IPV6 DNS detection.
DziadDalf
cFosSpeed 10.15 build 2280 -- 08-Sep-2016
! Drivers are now signed my Microsoft, thus they should work even under the
Anniversary Update of Windows 10, version 1607 (Redstone1). Plus they are
signed by us with a EV certificate, so Windows SmartScreen always approves
them as genuine.
+ Changed the dialogs from HTA to normal HTML. Since they are displayed in
the normal browser, they are much faster now.
+ The "Add Program" feature in the program prioritization dialog now only
takes .exe files, which are currently used for data transmission. This
prevents a lot of .exe files entered into the prioritization which never
actually transfer data. As a consequence you need to run the program
which you want to prioritize in order to appear in the list.
- Due to browser security, the IP blocklist in the dialog is now hard-
coded to blocklist.txt in c:\programdata\cfos\cfosspeed. You can still
use other names or directories if you change the user.ini file manually.
- Switched to Visual Studio 2015 Update 3.
DziadDalf
cFosSpeed 10.15 build 2281 -- 14-Sep-2016
x Fixed a bug in the preferences dialog where Traffic Shaping settings could
not be changed with the new dialogs. Thanks to Stefano.
x Fixed IP block list handling in new dialogs. Thanks to Stef and Contor.
x Fixed missing text in dialog. Thanks to Frank Bertsch.
DziadDalf
cFosSpeed 10.21 build 2283
+ The "Add Program" dialog now lets you select between currently used
programs and all programs you used.
x Fixed a caching problem with the new dialogs. The "restore defaults"
button should now work again.
x Fixed empty statistics values in the usage graph.
