Re: cFos Software - wersje rozwojowe
cFosSpeed 6.51 build 1843 Beta
x Fixed serious bug in -l7-prot, -udp-prog, -tcp-prog and -prog filter rules
when they were used with negation (like -l7-prot !@user.ini/normalprots).
This caused program and protocol settings to misfunction if you had made
changes to them (changes are recorded in user.ini and filter rules contain
negations to read them properly). This bug was introduced in since
v5.13.1694. Thanks to km for his bug reports.
x The installer started the status window with elevation. Fixed.
cFosSpeed 6.51 Build 1851 Beta
cFosSpeed 6.51 build 1851
- Updates to Logitech G19 skin.
- Tested cFosSpeed with "teaming". We used an Intel Gigabit ET Dual Port
Server Adapter and their most recent teaming software v16.2. Please note:
The route to the Internet must go through the virtual teaming adapter,
not through one of the individual teamed adapters.
cFosSpeed 6.61 build 1870 Beta
+ From now on, installation archives contain both x86 and x64 flavours of
cFosSpeed. The right Setup is started automatically. Furthermore, the
archives are packed with LZX, resulting in a higher compression.
DziadDalf
cFosSpeed 6.61 build 1875 Beta
x If a ping_dest has been set by the user we accept ping replies ("pongs")
to any TTL. Otherwise, only ping replies to TTLs 2-4 are accepted. Thanks
to tomtores for inspiration.
x Fixed a rare bluscreen.
- To comply with the Windows design guides, cFosSpeed now stores all global
and Traffic Shaping related data in \ProgramData\cFos\cFosSpeed directory.
All user specific data, like selected language and skins, are stored in
\Users\\Appdata\Local\cFos\cFosSpeed.
