cFosSpeed 6.61 Build 1882 Beta
cFosSpeed 6.61 build 1882
+ Changed the look of the current connections dialog. It also now has a
"Freeze" button to stop periodical update of the current connections.
x Fixed broken context menu entries introduced in build 1881.
x Column sorting in console dialog works again.
x Fixed a bug where newer dialog html files would not overwrite the old
ones during an update installation.
DziadDalf
cFosSpeed 6.61 build 1883
x Fixed a long-standing bug, where the status window would disappear
after stand-by/wake up.
+ The program and protocol prioritization dialogs now have a button
to restore the prioritization settings to their default values.
+ The program prioritization dialog now allows you to suggest a newly added
program to the cFos team, so we can include it in future releases.
DziadDalf
cFosSpeed 6.61 build 1884
! The -weight class parameter that is specified in the default settings does
now specify the weight of all rx-streams in a class and no longer the weight
of a single stream. This helps to keep fast sending streams of low priority
(like P2P) slower and higher prio streams faster. A exacter regulation is
still in development.
+ Added -delay parameter for classes. With this you can make sure packets in
that class are sent only after a minimum delay time in the queue. That is,
-delay cann add some ADDITIONAL delay for packets. By default, all delays
are set to 0, i.e. no additional delays are introduced.
+ Added -class filter expression. This allows filtering after the class of a
TCP stream, i.e. you could use the filter "-tx -higher -class lower -c lower"
to filter out all TCP ACKs of streams that are classified as lower.
