cFosSpeed 6.61 Build 1897 Beta
cFosSpeed 6.61 build 1897
- We're still searching for the 100% CPU load problem. Again,. we added new
debug output to cfosspeed.exe. Please send us your procdump dumps if
cfosspeed.exe takes up all the CPU time of one of your cores.
cFosSpeed 6.61 Build 1898 Beta
cFosSpeed 6.61 build 1898
x Finally! We found and fixed the 100% CPU load problem.
Thanks to all helpful hands that have sent us dumps again and again :) To
name a few: Frank M. (whose dump finally opened my eyes), natostancof, Saua,
Steve B, Ythan, Paladin, Sz. J., BORLAND, Lam, Pumm0r. Please excuse me if
I forgot you.
x Fixed bugs in online budgets dialog.
cFosSpeed 7.01 Build 1920 Beta
cFosSpeed 7.01 build 1920
x The on-the-fly prioritization dialog did not allow you to permanently
prioritize programs, which weren't already permanently prioritized.
Fixed.
cFosSpeed 7.01 Build 1921 Beta
cFosSpeed 7.01 build 1921
+ cFosSpeed now checks every 2 days for program news. If there are any,
it displays the mail symbol in the status window and opens a url if
clicked. This feature is on by default. If you are not interested in
program news, you can turn it off in the context menu under "Options".
x Fixed missing ml-string.
cFosSpeed 7.01 Build 1922 Beta
cFosSpeed 7.01 build 1922
x On some machines spd.exe consumed a lot of CPU power and accessed the
registry heavily. Fixed. Thanks to Empyter.
x On some machines the status window is not alwaysw displayed after sleep.
Hopefully fixed. :)
cFosSpeed 7.01 Build 1925 Beta
cFosSpeed 7.01 build 1925
! cFosSpeed will now automatically expand Windows' TCP RWIN as needed!
With our new "Automatic RWIN expansion" cFosSpeed will expand the RWIN (and
the matching window scaling) to a value that allows a download with full
speed and a delay of 100 msec.
This makes system-wide settings of "GlobalMaxTcpWindowSize" or
"TcpWindowSize" (under XP) superfluous and will keep your downloads fast even
if Windows 7 "auto-tuning" feature doesn't work for you.
As an added goodie it will provide fast download even for programs that
can not achieve full download speed because they provide too small buffers to
the Windows TCP/IP interface, like Cygwin SCP.
You can change the maximum delay, but that affects memory consumption:
cFosSpeed needs (delay in seconds) * (downloadspeed in bytes/sec) bytes,
i.e. for a DSL line with 25 mbits/s (about 3000 kbytes/s) the memory
requirement is 0.1 sec * 3000000 bytes/sec = 300 kbytes. To change this
time use the "spd gset expand_rwin_dest_time " command.
DziadDalf
cFosSpeed 7.01 build 1927
x Fixed a bug which prevented connections to be displayed by the keyboard
LED script. Thanks to yashpalshah for the report.
- Added memory debugging.
+ Added Slovenian language. That makes a total of 33 languages supported.
Even more languages are downloadable from our web site, here:
cFosSpeed 7.01 Build 1928 Beta
cFosSpeed 7.01 build 1928
x cFosSpeed now installs on Windows 8 Consumer Preview. Thanks for all
feedback!
- Improved setupapi log file support.
