cFosSpeed 7.01 Build 1936 Beta
cFosSpeed 7.01 build 1936
* Added WMI support. cFosSpeed creates a WMI class 'cfosspeed_perf_data'
in the namespace \root\cfos which has all known skin variables as
properties (see
for details).
This allows WMI utilities to display the same information as in the
cFosSpeed status window. There is a little demo of how to access the
cFosSpeed WMI data: wmi_demo.hta in the cFosSpeed dialog folder.
cFosSpeed 7.01 Build 1939 Beta
cFosSpeed 7.01 Build 1941 Beta
cFosSpeed 7.01 build 1941
x When RWIN Expansion was switched on especially slow connections would become
very unresponsive when downloading. Hopefully fixed. Thanks to Michael32
for bug report.
cFosSpeed 8.01 build 1965 Beta
- If you had several IPs set for your network card, cFosSpeed would have used
them in unspecific order, depending on the ARP requests sent. Now cFosSpeed
should always use the primary IP.
cFosSpeed 8.01 Build 1969 Beta
+ Added expand_rwin variables to output of "spd tcb".
+ The WMI provider in cFosSpeed now also supports GetObject/GetObjectAsync,
so more flexible WMI scripts are possible.
x Fixed a bug in RWIN expansion. This bug caused prevented connections to
certain servers. Thanks to Marcus Rüppel for his help.
This could improve download speed with some servers as well.
x It could have happened that class delays were still set after rx-shaping was
switched off (you could see that with "spd classes"). That would have
resulted in unnecessary delays. Fixed.
x Improved error handling if cFosSpeed service could not be deleted on update
install.
x Hopefully fixed a crash. Thanks to Bartosz Polański for dump files.
x Small fix for RWIN expansion. Still looking for the big fish, so more debug
output was added. Thanks to Marcus Rüppel.
