DziadDalf
cFosSpeed 8.03 build 2007
+ cFosSpeed setup will pop up a warning box if programs are running which are
known (at least sometimes) to cause problems when installing/deinstalling.
We recommend you close these programs before continuing the setup.
x Fixed percentage display in connection overview.
x Changed minimum speeds for bulk data detection to 30 kb/s rx and 6 kb/s tx.
Thanks to Michael32 for the hint.
x Temporary prioritisations will now affect newly created connects as well.
They are deleted if you manually override them or when the machine is
rebooted.
DziadDalf
cFosSpeed 8.03 build 2009
x Temporary prioritisations are now deleted when the Internet connection is
terminated or the machine is rebooted.
+ Added support to set priority if program name is "unknown" or "routed".
+ Link to features.htm on desktop is no longer created for prereleases.
Thanks to Sublogics and Contor for the idea.
+ Added "spd prioritise pair <program> <protocol> <class>" command to set
temporary prios for the program/protocol pair. The new current connections
dialog now uses this command.
cFosSpeed 8.03 Build 2012 Beta
[copyblock]Changes in 8.03 Build 2012 Beta:
Made the prioritization buttons in the current connections dialog more responsive.[/copyblock]
DziadDalf
cFosSpeed 8.03 build 2015
+ Added "spd slot X get/set/add categories CAT1:CAT2:..." command. This will
set the slot X programs and protocols to all programs/protocols that are in
one the listed categories. A category is the text before the frist "," in
settings.ini/user.ini. Example: the line "gw2.exe=Games,Guild Wars 2" in
section [highprogs] puts the program "gw2.exe" in the category "Games".
+ Added "spd slot show" command to show all settings for all slots.
+ Added nettalk_tx, nettalk_rx and nettalk_max modes for slots.
x Fixed a bug in installation DLL.
cFosSpeed 8.03 build 2017
+ Re-vamped dialogs. They are now easier to use, faster and in the new
Window 8 style.
+ As part of the dialog re-vamp we changed the Traffic Analysis dialogs
so it is easier to use and consistent with the prioritization dialogs.
Instead of adding protocols/programs to slots, you now assign groups
as they appear in the prioritization dialogs. If you like to also
add indididual programs or protocols, you can do so with spd commands.
cFosSpeed 8.03 build 2018
x Fixed bug in slot handling: all data was counted to "User" and none to the
other categories. Thanks to Lo0olz for bug report.
x Fixed bugs in new dialogs.
cFosSpeed 9.01 build 2030
+ Tamed querying of TCP/UDP programs names. Thanks to Litfal for bug report.
x Fixed missing images for dialogs.
x Usage graph is back.
- Switched slot order so that net talk is now in the last slot.
cFosSpeed 9.01 Build 2031 Beta
x Fixed bugs in the budget configuration dialog. Thanks to dj_hetick.
x Fixed range and mode settings in Budget Graph dialog. Thanks to Vel.
x Fixed a bug in the full screen detection routine. Thanks to DJ Deipotent
persistently reporting it :)
x Fixed a hang in installation.
