DziadDalf
cFosSpeed 9.05 build 2067
+ cFosSpeed can now evaluate IPv6 routing info. IPv6 traffic is now used
by the driver and displayed in the status window and counted in "spd ns".
The next step will be to inspect packets and prioritize traffic.
x Hopefully fixed a rare bluescreen where cFosSpeed ran out of kernel stack
space, if RWIN expansion was enabled. Thanks to BenYeeHua for bug report
and dump file.
DziadDalf
cFosSpeed 9.05 build 2070
+ Added IPv6 to spd ports / stat_infos.
+ MPEG Dash is now detected if the content-type is either "text" or
"application/...". Thanks again Lo0olz for dumps.
x Fixed IPv6 prefix length for adapter's primary IPv6 address.
x Fixed half-open session counter after "spd ns".
- "Open cFosSpeed console" is now available as well in the context menu under
Traffic Shaping, since Win8 doesn't offer the start menu any more.
cFosSpeed 9.05 Build 2071 Beta
cFosSpeed 9.05 Build 2071 Beta:
Changes:
x Fixed colors in settings dialog.
x Fixed a bug in RWIN expansion that caused TCP streams to stop.
DziadDalf
cFosSpeed 9.05 build 2073
+ RWIN expansion, RX shaping, ICMPv6/UDP ping latency measurement & packet
decoding now support IPv6.
+ Updated NDIS offload options for IPv6
+ Re-introduced avg. segment size display in "spd cons". Use "spd cons -ass" :)
- The msslimit variable has been removed and replaced by the mtu_limit
variable. In IPv4 MTU = MSS+40, so if you had msslimit set to 1400,
you want to set mtu_limit now to 1440.
- The "spd stat_infos" command has been renamed to "spd port_stats".
cFosSpeed 9.05 Build 2075 Beta
cFosSpeed 9.05 build 2075
+ Added -ipv4, -ipv6 rules.
+ Added -icmpv6-type rule that only matches IPv6 packets.
- Converted all other filter rules to IPv6, where applicable.
x Fixed faulty lowering of statistical max. rx-speed when port was opened.
Thanks to unknown cfosspeed user.
cFosSpeed beta 9.05 build 2080
cFosSpeed 9.05 build 2080
x Fixed missing status window under Windows XP for WAN connections. Thanks
to Dirk Boschatzke for bug report.
x Fixed floating point problem that caused bluescreen.
- Removed "missing DLLs" again, they were not needed.
