DziadDalf
cFosSpeed 8.03 build 1995
+ Improved bulk detection; it should be more stable now. Please report if
there is unexpected behaviour.
+ Added -bulk, -tx-bulk, -rx-bulk filter expressions. They are true if any
direction, resp. direction rx, resp. direction tx is in bulk mode. Only
TCP connections can be in bulk mode, not UDP.
DziadDalf
cFosSpeed 8.03 build 1996
+ Added Unknown_Bulk l7-protocol with default priority.
- Unknown, Unknown_Bulk, Teredo and Teredo_Bulk l7-protocols all have default
priority. We recommend not to assign a different priority, because with
default priority the program prioritisation will take care of it. And if
there is not entry for the program the final bulk rule will classify bulk
data as "low" and non-bulk as "default".
DziadDalf
cFosSpeed 8.03 build 1997
+ Sending of usage reports finally added.
x Fixes in Setup to improve handling of rare update-installation issue:
On update install, Windows might report the need to reboot after removal of
the old cFosSpeed devices, before you can install them again. Setup now
honours this.
cFosSpeed 8.03 Build 2000 Beta
Changes in 8.0.3 Build 2000:
Fixed bad ping values in "spd ts" display.
Re-arranged context menu a bit. Removed the "Effects" menu. cFosSpeed now always uses fade-in and slide animations. Also moved "Always on Top", "Auto-Open", "Click Through" options to the "Window Settings" menu and made them global for all windows.
DziadDalf
cFosSpeed 8.03 build 2001
* Added new filters -tx-lite, -rx-lite and -lite. The idea is to detect
"lite data streams", i.e. streams of data that are low volume and not bulk
data in nature.
x Fixed a problem with Youtube bulk-sending with BSTREAM protocol (which is
set to "default" priority). The connection would be classified as "low".
In our protocol and program logic "default" means "fall-through" and then
the last -bulk rule changes the class to low. In general, this is intended,
but not with BSTREAM, so we excluded it from the -bulk rule. Thanks to
Ukjent for his report.
cFosSpeed 8.03 build 2004 Beta
x When prioritizing a connection to lowest, it vanished from the list. Fixed.
+ Added percentage display for resent packets in "spd netstat".
- Changed some compiler settings in an attempt to find memory corruption bug
introduced in build 2002. Please report if this version still crashes.
cFosSpeed 8.03 Build 2005 Beta
Changes in 8.03 Build 2005 Beta:
Hopefully the x86 build work again without crashes. Give a big hand to Gothico and all other users, who provided dump files.
More dialog changes.
cFosSpeed 8.03 build 2006 Beta
x Fixed link in new current connections dialog under IE 10.
- The Current Connections dialogs (old and new) now have the same application
ID as the options dialogs. Only one of them can be used at the same time.
This prevents overwriting prioritization settings from one dialog with
another when both dialogs would be open simultaneously.
