cFosSpeed 9.03 build 2044
* New skin in Metro style. Have fun! :)
+ Tweaked behaviour of auto hide on fullscreen, so it respects manual
window closing and auto-open/hide settings better.
+ After the status windows was closed 3 times, cFosSpeed will now ask
you if you want to disable auto-open/auto-hide.
x Fixed a bug in current connections dialog with spaces in filename.
cFosSpeed 9.05 Build 2063 Beta
From the data we see in the crash reports you send us, we see a lot of crashes caused by viruses or malfunction of security software. So from now on the crash handler will try to report if the crash was caused by a virus or malfunctioning software (which installs "hooks"). So you can take measures to increase system stability, e.g. clean your system, update your security software, etc.
Added more trace output to dump.txt file.
Added new "spd gset dump_sessions 5": delete dump file if no RWIN expansion took place.
cFosSpeed 9.05 Build 2064 Beta
Changes in 9.05 Build 2064 Beta:
Hopefully fixed a bug in RWIN expansion that caused downloads to hang. Thanks to MaXzzz for testing and dump files.
DziadDalf
cFosSpeed 9.05 build 2065
+ Improved stream detection for Youtube. They are using MPEG Dash and
report the content-type as text. So cFosSpeed now tries to look into
the first few bytes of the HTTP body to detect video streamy. Thanks
to Lo0olz for the help.
