cFosSpeed 8.01 Build 1971 Beta
cFosSpeed 8.01 build 1971
x If the un/update-installation fails because the service could not be
deinstalled, the installed will now return a proper error message asking you
to reboot and try again.
DziadDalf
cFosSpeed 8.03 build 1982
+ Added global variable min_hops. Usually, cFosSpeed will start with TTL 2
or 3 for ping timings and increase the TTL until a decent destination is
found. The min_hops setting can be used to force cFosSpeed to use a higher
minimum TTL. Thanks to Kullorki for inspiration.
+ Added a messagebox that is opened if cFosSpeed driver was not loaded.
This could happen when you upgrade your system from Windows 7 to Windows 8.
You need to reinstall cFosSpeed to fix that.
cFosSpeed 8.03 Build 1983 Beta
cFosSpeed 8.03 build 1983
x Deinstallation will now work gracefully, if driver was not installed, but
service was still installed.
DziadDalf
cFosSpeed 8.03 build 1984
+ Improved HTTP Layer 7 detection. Now cFosSpeed also checks re-used
HTTP connections for streaming. This way especially Youtube videos
should be detected more reliably.
+ Added Guild Wars 2 (gw2.exe) to program prioritization list.
cFosSpeed 8.03 build 1986 Beta
x Fixed a bluescreen that was introduced in beta 1984. Thanks to Daniel Hänel
and Andrey Chernov for dump files.
DziadDalf
a dla mnie gdzie im dump'a wysłałem zaraz po instalacji 1984 bo mi sypało bluescreen'y co chwila i tak samo z 1985 było :ireful :mad: :lanie :k......
cFosSpeed 8.03 build 1988 Beta
x Tried to fix a Windows 8 bluescreen with DPC_WATCHDOG_VIOLATION (0x133).
Thanks to kittler2 for the dump files.
cFosSpeed 8.03 build 1989 Beta
x Hopefully fixed a problem with the fix for Windows 8 bluescreen with
DPC_WATCHDOG_VIOLATION from build 1988. :)
x Fixed problems in current connections dialog with filename that contain
spaces.
DziadDalf
cFosSpeed 8.03 build 1990
x Builds 1988 and 1989 were actually 1987 builds. Fixed.
x More fixes for filenames that contain spaces in "Prioritize this connection"
dialog.
- Changes in column sorting in console dialog.
- Improved error reporting in installer.
