cFosSpeed 9.05 Build 2090 Beta
Changelog
cFosSpeed 9.05 build 2090 * Added Smartphone-Skin support. You can now access the cFosSpeed status window from other devices within your LAN via HTTP. For example open the webpage
from your smartphone to access the cFosSpeed status (assuming your local IP address is 192.168.2.100). This is especially useful in fullscreen mode, when you play a game or watch a video. Smartphone-Skin support keeps you informed about your network activity even when the normal cFosSpeed status window is not visible. If you try it with the browser on your local machine, no username/pwd is needed. From other machines, the user name is "cfosspeed" and the password can be setup by specifying the server_password= key in the file c:\programdata\cfos\cfosspeed\global.ini, section [All]. Use ! as first letter. That will cause it to be encrypted on first use.
cFosSpeed 9.05 Build 2093
Changes:
+ Improved Layer-7 detection of HTTP based protocols, e.g. most of the
streaming protocols.
x Fixed crash in priorization dialog. Thanks to M. Mortezaei.
cFosSpeed 9.05 Build 2099 Beta
cFosSpeed 9.05 build 2099
+ In addition to the phone skins: You can now also open the Current Connections
dialog from your phone or tablet and view or prioritize individual
connections. Use this URL on your phone or tablet:
http://[Your IP address]:1487/cfosspeed/console.htm
x The Current Connections dialog would not start under XP when skin button
was used. Fixed.
x Fixed a rare crash. Thanks to chris birk.
cFosSpeed 9.05 Build 2100 Beta
hangelog
x Hopefully fixed a crash in speedsrv.dll. Thanks to Ben Yee Hua.
x Our firewall wasn't adapted to IPv6. Fixed. Thanks to Ben Yee Hua.
cFosSpeed 9.05 Build 2103 Beta
cFosSpeed 9.05 build 2103
+ Skin Windows can now also auto-arranged at the top right corner of the
screen. You can select this in the "Window settings" menu.
x Improved the way multiple skin windows are auto-arranged. Thanks to Ben
Yee Hua again.
cFosSpeed 9.05 Build 2104 Beta
Fixed missing import under XP.
All spd commands were a bit slow in responding, since trace.txt was always flushed to disk. That bug was introduced in v9.03.2042 and could cause stuttering in music playback. Fixed. Thanks to Ben Yee Hua.
Fixed a bug with window positions, when no previous position was given.
SSL_C_BULK now has priority 'normal', because many video streams use SSL nowadays.
cFosSpeed 9.05 Build 2108 Beta
Added Layer 7 SRTP detection for SSL connections. If your Voice over IP connection is encrypted with SSL, cFosSpeed can now detect this and prioritize accordingly.
In preparation for the upcoming HTTP/2.0 standard, we improved Layer 7 SSL SPDY detection. This also reduces false positives.
Fixed trace file handling: trace files were not flushed properly. This bug was introduced in build 2104.
Fixed bug that caused long DPC execution times and thus could cause stuttering in music playback.
cFosSpeed 9.61 Build 2130 Beta
cFosSpeed 9.61 build 2130
x Fixed a bug under Win XP where the current connections dialog produced an
error when started from the skin window.
x Fixed bluescreen in TLS protocol detection. Thanks to OliMuc.
