cFosSpeed 9.61 Build 2131 Beta
cFosSpeed 9.61 build 2131
x The saved window position is now used if at least one corner of the
window is visible on one monitor. Thanks to Marc Schulz.
x Fixed a bluescreen when port was opened/closed. Thanks to cloverdew.
- Changed context menu internals. If you had problem with context menu
in the past, please test again.
cFosSpeed 9.61 Build 2133 Beta
Fixed a bug that caused packet duplication in Wireshark and with VMware in bridged network card mode. Maybe this bug also fixes problems encountered with Kaspersky Anti-Virus. This fix can be disabled with the command "spd gset filter_fix 0 -save". The count of filtered packets is printed with the "spd fcstat" command.
cFosSpeed 9.63 Build 2140 Beta
Added VDSL as medium. Setting this and switching on MTU optimization could result in a 2% speed increase.
Connections with protocols UNKNOWN and UNKNOWN_BULK are first matched against program names and only afterwards against protocols. Thus, if no proper protocol is detected, program prios take over (if possible, that is, if the program is listed and its prio is != normal) and only if those don't match, then protocol prio is used (but again, only if that is not set to normal).
Fixed bug in TCP MSS optimization. This could have fixed a bug in bulk detection as well.
Hopefully fixed a bluescreen while deinstalling.
Changed headings and switches in "spd cons" from mss/lss/ass to mtu/ltu/atu, since they now show IP-agnostic values (MTU is TCP segment size minus TCP/IP header length, which is different in IPv4 and IPv6).
DziadDalf
cFosSpeed 9.65 build 2152
+ UPnP router speed values are displayed on "spd speed" under "router="
+ The current connections dialog now displays the program icon. Also the
'+' and '-' buttons highlight to make it clearer that you can temporarily
change the priority.
x Window auto arrange is no longer done when window positions are locked.
- Internal changes of library use.
DziadDalf
cFosSpeed 9.65 build 2157
x Fixed a crash in router speed detection. Thanks to MISTER X.
+ If the network class installer is locked by another program, the cFosSpeed
installer now displays the culprit.
+ Added "spd slot <x> show" and "spd slot reset" commands.
DziadDalf
cFosSpeed 9.65 build 2158
! cFosSpeed now uses another API to get information about routing interfaces.
You may need to configure your Traffic Shaping settings in the Options ->
Settings -> Preferences Traffic Shaping settings. We hope to address
conflicts with other network components with this change.
+ You can now disable UPnP router detection by setting the key detect_igd=0 in
file c:\programdata\cfos\cfosspeed\global.ini, section [param].
x Fixed an spd.exe service crash in the UPnP device detection. This should
also fix the problem with non-functioning current connections dialog.
x Expiration pop-ups came up with every start. Fixed.
- cFosSpeed will not modify network bindings anymore, regardless of the
Traffic Shaping settings. If you want to unbind cFosSpeed from a certain
network card, you can do this in the standard Windows adapter settings
dialogs.
- Improved resilience against other filter drivers messing up cFosSpeed's area
in NDIS packets.
DziadDalf
cFosSpeed 9.65 build 2159
! Changed name of key to disable UPnP router detection: set key router_info=0 in
file c:\programdata\cfos\cfosspeed\global.ini, section [param] or use
"spd gset router_info 0 -save".
x Again: Fixed an spd.exe service crash in the UPnP device detection. This
should also fix the problem with non-functioning current connections dialog.
DziadDalf
cFosSpeed 9.65 build 2161
+ UPnP device info is now cached to improve access to "unreliable" UPnP
devices.
x Hopefully fixed an longstanding, yet rare bug that caused bluescreens if
RWIN expansion was active.
cFosSpeed 9.65 build 2160
+ If UPnP router detection detects the medium of your Internet connection
and cFosSpeed's medium setting is still on "Adaptive", it is now changed
accordingly.
